查看: 760|回复: 0
[求助] ndr不成功问题。
发表于 2024-12-20 15:25:49 | 显示全部楼层 |阅读模式
这是我CTS的设置,只设置了INV。
set cts_inv_cells [list CKINVM12H CKINVM16H  CKINVM20H CKINVM24H  CKINVM4H CKINVM6H CKINVM8H]
foreach libraryname $cts_inv_cells {
  echo "setDontUse $libraryname false"
add_ndr -name cts_w2s2 -width_multiplier {ME3 2 ME4 1} -spacing_multiplier {ME3 2 ME4 1} -via {VI1 2 VI2 2 VI3 2}
create_route_type -name trunk_rule -non_default_rule cts_w2s2 -top_preferred_layer ME4 -bottom_preferred_layer ME3
set_ccopt_property route_type trunk_rule -net_type trunk
#=========== shielding =============
create_route_type \
-name VREF \
-top_preferred_layer ME4 \
-bottom_preferred_layer ME3 \
-preferred_routing_layer_effort high \
-non_default_rule cts_w2s2 \
-shield_net GND \
-shield_side both_side
目前出现三个问题,一是ndr还是按照默认设置,二是shilding没设置成功,缺少shape,不是很理解,三是balance的问题,我本来就没有设置buffer,但是不知道是不是这个原因。
1、#WARNING (NRDB-2120) Special net VREF is missing wiring shapes, will disable tie-net connections to this net.
2、Route type trimming info:
  No route type modifications were made.
**WARN: (IMPCCOPT-1183):        The library has no usable balanced buffers for power domain auto-default, while balancing clock_tree clk_generator_for_tx_clk<1>. If this is not intended behavior, you can specify a list of lib_cells to use with the buffer_cells property.
3、**WARN: (IMPCCOPT-1183):        The library has no usable balanced buffers for power domain auto-default, while balancing clock_tree clk. If this is not intended behavior, you can specify a list of lib_cells to use with the buffer_cells property.
GMT+8, 2025-12-22 05:34 , Processed in 0.011077 second(s), 3 queries , Gzip On, Redis On.
