[求助] 求一份Cadence的PDF,主题是 Advanced Optimization(AOP)
发表于 2025-3-2 02:24:46 | 显示全部楼层
这个功能非常有用,很好
发表于 2025-3-3 14:37:16 | 显示全部楼层
Thanks
发表于 2025-3-7 14:34:59 | 显示全部楼层
会飞的鸟儿 发表于 2025-3-1 22:23
请问您解决了吗,我也遇到了相同的问题
添加feature即可
发表于 2025-3-7 15:47:23 | 显示全部楼层
SMaxwell 发表于 2025-3-7 14:34
添加feature即可
不行,feature原来就有,我用了pubkey对ic231isr11进行了破解,其他功能均正确,就是AOP不能用,推测就是api.jar
这个java文件没被破解,后面破解了一下,log上也不报错了,也不运行了,现在我又恢复成原样了,如果有java版的pubkey破解可以分享一下吗,可能是我找的破解包不对
发表于 2025-3-7 16:00:57 | 显示全部楼层
会飞的鸟儿 发表于 2025-3-7 15:47
不行,feature原来就有,我用了pubkey对ic231isr11进行了破解,其他功能均正确,就是AOP不能用,推测就是 ...
确实,我以为看报错添加那个VVO的feature就行了,结果我试了也不行,看来这个就是不太好破解。按照eetop所说的查feature的方法,也添加了VVO_Assembly和VVO_Explorer的feature还是不行。其实报错说的是license而不是feature的事。。
报错信息:“Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035) ; SIGN or SIGN2 Required in License Certificate (-516,4035)
Run 'lic_error LMF-01513' for more information.
02:56:32.193 [main] ERROR com.cadence.dso.OptimizerApi.LicenseChecker - Failed to find license Virtuoso_Variation_Option”
看着像SIGN2没过验证,我也不知道怎么破解了。。。
发表于 2025-7-17 17:42:07 | 显示全部楼层
发表于 2025-7-19 08:42:46 | 显示全部楼层
thanks
发表于 2025-7-19 09:16:37 | 显示全部楼层
thks yur sharing
发表于 2025-8-15 15:40:56 | 显示全部楼层
发表于 2025-9-13 21:38:23 | 显示全部楼层
thanks
GMT+8, 2025-10-17 05:26 , Processed in 0.015813 second(s), 3 queries , Gzip On, Redis On.
