楼主: Vanty
[求助] 折叠共源共栅差转单cascode补偿
 楼主| 发表于 2024-8-21 11:31:00 | 显示全部楼层
zhanweisu33 发表于 2024-8-20 18:47
影响相位裕度,
可以把论文分享一下
请问影响相位裕度的原理是什么呢
论文 Y. Kusuda, “A 60 V Auto-Zero and Chopper Operational Amplifier With 800 kHz Interleaved Clocks and Input Bias Current Trimming”, IEEE J. Solid-State Circuits, vol. 50, no.12, pp. 2804-2813, Dec. 2015.
 楼主| 发表于 2024-8-21 11:32:37 | 显示全部楼层
JiahuiShen 发表于 2024-8-20 09:22
Cm2P和Cm2N效果是比较接近的,你可以拿掉Cm2P,同时增加Cm2N,Sansen书上有讲这个 ...
sasen书上有这个结构,但是没有具体分析这个电容,sansen书上只用了Cm2N
 楼主| 发表于 2024-8-21 11:33:46 | 显示全部楼层
已发
 楼主| 发表于 2024-8-21 11:35:13 | 显示全部楼层
diabol 发表于 2024-8-20 02:28
You can do simulation without Cm2P : Connect as Unit-Gain buffer and a square input 0.9V -> 1.1V - ...
请问是因为相位裕度变了吗(有或者没有Cm2p的两种情况下)
 楼主| 发表于 2024-8-21 11:37:46 | 显示全部楼层
我的理解是Cn2p不补偿的话相当于小信号电流分成了两部分,红色一部分受到密勒补偿极点影响蓝色部分却没有,所以这个电容是需要对称的,或者加大Cm2N去满足Cm2p的效果,不知道我的理解对不对,请您指教一下
 楼主| 发表于 2024-8-21 11:40:08 | 显示全部楼层
影响相位裕度,
可以把论文分享一下
 楼主| 发表于 2024-8-21 11:41:19 | 显示全部楼层
发表于 2024-8-21 18:19:38 | 显示全部楼层
   Push-pull stage can be seen as two parallel singal path.
   Designer need to make two path as balance as possible.
   Otherwise , the Bode plot will has additional pole/zero pairs.
   Will these P/Z pairs change PM?
   Maybe, it depends on the P/Z pairs position.
   Too near unit gain, then PM will change.
GMT+8, 2025-12-21 11:18 , Processed in 0.108853 second(s), 4 queries , Gzip On, Redis On.
