查看: 792|回复: 0
[求助] multi pin connectio
发表于 2024-5-16 16:39:08 | 显示全部楼层 |阅读模式
i   c c 2 有个multi pin connections , 这个怎么fix呢?或者怎么忽略掉。,我设置中 set_app_options -name route.detail.report_ignore_drc -value { {Multiple pin connections}},然后运行check_routes 为何还是会报出Multiple pin connections的错啊
GMT+8, 2025-12-21 15:00 , Processed in 0.012488 second(s), 4 queries , Gzip On, Redis On.
