查看: 2715|回复: 5
[求助] cadence中ADEL仿真报错
发表于 2024-3-22 11:56:02 | 显示全部楼层 |阅读模式
Error found by spectre during initial setup.
    ERROR (CMI-2204): V0: Time is not strictly increasing in waveform at 200 us.
Aggregate audit (11:49:22 AM, Fri Mar 22, 2024):
Time used: CPU = 227 ms, elapsed = 241 ms, util. = 94.3%.
Time spent in licensing: elapsed = 141 ms, percentage of total = 58.7%.
Peak memory used = 54.6 Mbytes.
Simulation started at: 11:49:22 AM, Fri Mar 22, 2024, ended at: 11:49:22 AM, Fri Mar 22, 2024, with elapsed time (wall clock): 241 ms.
spectre completes with 1 error, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
各位大佬在仿真的时候遇到过这个问题吗:cadence中vpwl模块,设置成三段可以仿真,四段以上就报错了
发表于 2024-3-22 13:02:19 | 显示全部楼层
时间填错了吧?
发表于 2024-3-22 13:55:47 | 显示全部楼层
檢查第四段時間是否低於第三段時間
 楼主| 发表于 2024-3-23 16:02:11 | 显示全部楼层
解决好啦,是我的参数不对
发表于 2025-4-30 11:06:55 | 显示全部楼层
小天爱学习 发表于 2024-3-23 16:02
解决好啦,是我的参数不对
你好,请问下这个报错你咋解决的?
发表于 2025-5-23 17:10:40 | 显示全部楼层
萌面大大 发表于 2025-4-30 11:06
你好,请问下这个报错你咋解决的?
cadence里面那个vpwl的时间节点必须是递增的,而不是每间隔多少秒
GMT+8, 2025-12-24 23:10 , Processed in 0.015956 second(s), 3 queries , Gzip On, Redis On.
