查看: 29143|回复: 195
【Springer 2008新书】SDR技术——Adaptive Multi-Standard RF Front-Ends
发表于 2008-2-9 10:38:15 | 显示全部楼层 |阅读模式
Series: Analog Circuits and Signal Processing
Vidojkovic, V., van der Tang, J., Leeuwenburgh, A., van Roermund, A.
2008, Approx. 210 p., Hardcover
ISBN: 978-1-4020-6533-0
Ships in 3 - 5 business days
$129.00
About this book
Table of contents
About this book
The design and use of multi-standard RF transceivers is the way to increase hardware flexibility and functionality, as well as to improve the flexibility of set-makers on the market. In the design of multi-standard RF transceivers the efforts will be directed towards improvement of hardware reusability, reconfigurability, programmability and flexibility. This will result in the launching of a software-defined radio.
Since the radio environment is variable, the application of adaptivity in RF transceivers results in the reduction of their power consumption. Eventually, it is reasonable to believe that RF front-ends will be smart in the sense that they will be able to monitor the radio environment and to adapt themselves to the changes in this environment paving the way for a cognitive radio.
Adaptive Multi-Standard RF Front-Ends investigates solutions, benefits, limitations and costs related to multi-standard operation of RF front-ends and their adaptivity to variable radio environments. Next, it highlights the optimization of RF front-ends that allow achieving of maximal performance with a certain power budget while targeting full integration. Also, it investigates possibilities for low-voltage low-power circuit topologies in CMOS technology.
The concepts and considerations presented in this book have been validated through the design and implementation of the reconfigurable multi-band DECT/Bluetooth RF front-end in 0.18 um CMOS technology.
The successful design and implementation of the reconfigurable DECT/Bluetooth RF front-end is the result of systematic approach through all the steps in the design flow of a multi-standard front-end starting with the system level design, continuing with the circuit level design and implementation, and ending with the validation based on measurements.
Written for:
Graduate level students, researchers and professionals in the area of analog circuit design, RF and wireless communications, designers of electronic integrated circuits for radio frequencies, PhD students in the field of electronic integrated circuits
Keywords:
  • CMOS analog integrated circuits
  • adaptive radio receivers
  • multi-standard radio receivers
  • radio receivers
[ 本帖最后由 benemale 于 2008-2-9 10:45 编辑 ]
Adaptive Multi-Standard RF Front-Ends.part1.rar
3.89 MB, 下载次数: 819 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Adaptive Multi-Standard RF Front-Ends.part2.rar
3.89 MB, 下载次数: 780 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Adaptive Multi-Standard RF Front-Ends.part3.rar
3.84 MB, 下载次数: 785 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-9 20:46:15 | 显示全部楼层
thanks
发表于 2008-2-9 21:41:16 | 显示全部楼层
不错,新书,谢谢。
发表于 2008-2-9 22:37:59 | 显示全部楼层
新书,不错啊,下再看看
发表于 2008-2-9 23:12:25 | 显示全部楼层
Table of contents Glossary. Abbreviations. 1 Introduction. 1.1 The state-of-the-art in multi-standard RF transceivers. 1.2 Scope. 1.3 Outline. 2 Front-end architecture selection. 2.1 A generic front-end architecture. 2.2 A set of front-end architectures. 2.3 Selection criteria. 2.4 Selection of a suitable front-end architecture. 2.5 Summary. 3 Broad-band polyphase filters. 3.1 Passive polyphase filter topology. 3.2 RC polyphase filters and their applications. 3.3 Design considerations. 3.4 Summary. 4 Analysis of low-IF architectures. 4.1 Noise and voltage gain analysis in a low-IF front-end. 4.2 Linearity analysis. 4.3 Image rejection analysis. 4.4 Summary. 5 RF and building block specifications. 5.1 RF specifications. 5.2 Distribution of building block specifications. 5.3 Summary. 6 A low-voltage folded switching mixer. 6.1 Transconductors for folded switching mixers. 6.2 AC-coupled folded switching mixer with current-reuse. 6.3 Simulation and experimental results. 6.4 Mixer benchmarking. 6.5 Summary. 7 Multi-band reconfigurable complex mixer. 7.1 1.9 - 2.4 GHz reconfigurable complex mixer. 7.2 1.9 - 2.4 GHz conventional complex mixer. 7.3 Summary. 8 Reconfigurable multi-band LNA. 8.1 Design considerations. 8.2 Design procedure. 8.3 Design example. 8.4 A reconfigurable multi-band DECT/Bluetooth LNA. 8.5 Summary. 9 Reconfigurable multi-band RF front-end. 10 Conclusions. A RF, system and bulding block specifications. B Noise factor of a two-port network. C Noise factor of a passive RF block. References.
发表于 2008-2-9 23:14:48 | 显示全部楼层
Table of contents
1 Introduction.
1.2 Scope.
1.3 Outline.
2.5 Summary.
4.4 Summary.
5.3 Summary.
6.5 Summary.
7.3 Summary.
8.3 Design example.
8.5 Summary.
10 Conclusions.
References.
发表于 2008-2-10 06:57:19 | 显示全部楼层
thanks!
发表于 2008-2-10 14:16:55 | 显示全部楼层
这可是真正的新书!
发表于 2008-2-11 23:45:09 | 显示全部楼层
看看啥话头
发表于 2008-2-11 23:49:34 | 显示全部楼层
好东西看看
GMT+8, 2025-10-22 03:47 , Processed in 0.023398 second(s), 7 queries , Gzip On, Redis On.
