查看: 3133|回复: 16
[求助] DC lab1出错
发表于 2024-2-13 23:58:54 | 显示全部楼层 |阅读模式
哪位高人指点一下这个错什么原因,怎么改啊
 楼主| 发表于 2024-2-14 09:06:16 来自手机 | 显示全部楼层
顶顶
发表于 2024-2-14 09:46:49 | 显示全部楼层
查了下Synopsys Error Messages的文档
CMD-012
(error) extra positional option '%s'
Description
The command expects some positional arguments and has already received enough. It
might also be the case that this was intended as a dash option and is misspelled.
What Next
Verify that the option given is not a misspelled dash option. If a list is provided directly
instead of as a variable, ensure it is enclosed by curly braces or double quotation marks.
Use -help with the command to verify which arguments are already given.
 楼主| 发表于 2024-2-14 09:57:30 | 显示全部楼层
顶顶顶
发表于 2024-2-14 10:53:14 | 显示全部楼层
setup 文件里有错误吧,option内容写错了
 楼主| 发表于 2024-2-14 12:18:05 | 显示全部楼层
我用的是lab里面的setup文件啊,option内容指的是什么,高人能否细说
 楼主| 发表于 2024-2-14 13:26:26 来自手机 | 显示全部楼层
顶顶顶
发表于 2024-2-14 15:28:08 | 显示全部楼层
你不如把setup文件内容发上来,不然我看不到啊。
发表于 2024-2-14 17:27:09 | 显示全部楼层
看上去是.synopsys_dc.setup有问题,你要上载才能看,否则莫名其妙。
 楼主| 发表于 2024-2-15 00:40:03 来自手机 | 显示全部楼层
顶顶顶
GMT+8, 2025-12-28 10:00 , Processed in 0.026618 second(s), 4 queries , Gzip On, Redis On.
