查看: 4995|回复: 24
[资料] C家sdc sign off 工具
发表于 2024-2-7 02:36:23 | 显示全部楼层 |阅读模式
下面是sdc signoff 的template:
  1. #################
  2. ## Tool setup
  3. #################
  4. ## turning on the runtime/memory consumption
  5. usage -auto -elapse
  6. set base_name [file tail [info script]]
  7. ## creating a reporting directory for each build
  8. set buildno [get_db program_version]
  9. set rptdir "reports_${buildno}"
  10. if {![file exists ${rptdir}]} { file mkdir ${rptdir} }
  11. ## Log/report file setup
  12. if {[get_db log_file] == ""} then { set_db log_file [file join ${rptdir}
  13. ${base_name}.log] }
  14. ## if need to use more CPUs
  15. # set_multi_cpu_usage -local_cpu 16 -keep_license true
  16. ## Write out the naming rules if needed
  17. # set_db / .hdl_reg_naming_style %s_reg%s
  18. # set_db / .hdl_array_naming_style %s_%d
  19. ## From here, it is same as simplified init_design flow in stylus
  20. ## reading technology libraries
  21. read_libs [list \
  22. <path>/one.lib \
  23. <path>/two.lib \
  24. ]
  25. ## Reading RTL files, same as in Genus
  26. read_hdl <files>
  27. elaborate <top>
  28. ## you can also use file list
  29. # read_hdl -f <file_list>
  30. # elaborate <top>
  31. report_design_data > [file join ${rptdir} ${base_name}.report_design_data.rpt]
  32. report_black_box -detail > [file join ${rptdir} ${base_name}.report_black_box.rpt]
  33. ## when running first time, pause and see if the design elaboration is clean
  34. # suspend
  35. ## reading consgrtaints
  36. read_sdc [list \
  37. <path>/one.sdc \
  38. <path>/two.sdc \
  39. ]
  40. init_design
  41. ## Reporting SDC summary
  42. report_sdc > [file join ${rptdir} ${base_name}.report_sdc.verbose.rpt]
  43. report_sdc -status fail -verbose >> [file join ${rptdir}
  44. ${base_name}.report_sdc.verbose.rpt]
  45. report_rule_check -category CONSTRAINT_LINT -status fail -verbose > [file join
  46. ${rptdir} ${base_name}.sdc_lint.verbose.rpt]
  47. report_rule_check -category CONSTRAINT_LINT -status fail -verbose -spreadsheet [file
  48. join ${rptdir} ${base_name}.sdc_lint.verbose.xlsx]
  49. ## Dump the clock grouping information
  50. report_clock_group > [file join ${rptdir} ${base_name}.report_clock_groups.rpt]
  51. ## when running first time, pause and see if the constraints linting is clean
  52. # suspend
  53. ## Running SDC SignOFF checks
  54. verify_timing_intent
  55. ## reports SDC SignOff results
  56. report_rule_check -category CONSTRAINT_SIGNOFF -status fail -verbose > [file join
  57. ${rptdir} ${base_name}.report_timing_intent.rpt]
  58. report_rule_check -category CONSTRAINT_SIGNOFF -status fail -verbose -spreadsheet [file
  59. join ${rptdir} ${base_name}.report_timing_intent.xlsx] ; ## Microsoft xlsx output
  60. ## exit at the end
  61. exit
    复制代码
 楼主| 发表于 2024-2-7 02:49:49 | 显示全部楼层
LITMUS23.20.100.txt (84 Bytes , 下载次数: 143 )
发表于 2024-2-7 07:58:12 | 显示全部楼层
谢谢
发表于 2024-2-7 09:28:05 | 显示全部楼层
kan e kan
发表于 2024-2-7 09:29:54 | 显示全部楼层
感謝分享 3Q3Q
发表于 2024-2-7 09:37:04 | 显示全部楼层
非常感谢,可以和S家的对比一下
发表于 2024-2-7 10:22:04 | 显示全部楼层
感谢分享,学习学习
发表于 2024-2-7 11:05:45 | 显示全部楼层
感谢分享
发表于 2024-2-7 19:52:37 | 显示全部楼层
kadnkan
发表于 2024-2-7 22:24:38 | 显示全部楼层
謝謝分享。
GMT+8, 2025-12-9 20:31 , Processed in 0.025166 second(s), 4 queries , Gzip On, Redis On.
