楼主: rifat_rally
request for lic of DVT IDE for vscode
发表于 2023-12-18 09:04:26 | 显示全部楼层
very good!!!
发表于 2023-12-19 22:50:43 | 显示全部楼层
请教一下,dvt插件启动的时候报错
Language Server did not start because launch command terminated with exit code 1
这个是怎么回事
 楼主| 发表于 2023-12-20 01:35:21 | 显示全部楼层
etopjp 发表于 2023-12-19 22:50
请教一下,dvt插件启动的时候报错
Language Server did not start because launch command terminated with ...
download the dvt eclipse IDE from eetop or anywhere you found with pre cracked.
find and extrac the ro.amiq.dvt.flclient-*.**.jar
install vscode. Install DVT IDE for Visual Studio Code extension.
Change the latest version to the same version you downloaded the eclipse IDE with pre cracked.
open extesion folder in vscode command section by pressing Ctrl+Shift+P
find the same jar file and replace it with the extracted one from downloaded pre cracked IDE.
set the license and hone directory from windows environment variable.
restart your PC. It should work.
发表于 2023-12-20 22:45:37 | 显示全部楼层
find and extrac th ...
what should the license and home directory be ?
thanks
 楼主| 发表于 2023-12-21 01:38:52 | 显示全部楼层
thanks
I set the DVT_HOME directory as dvt win version installed path. should work with any
I put the license.dat file at the same location. should work with any location. lic veriable is DVT_LICENSE_FILE
发表于 2023-12-27 18:24:31 | 显示全部楼层
Hello, my vscode dvt can start normally, but when I enter the code, such as "alwa", the code prompt "always @ posedge, etc." does not pop up. Do you know what I should do? This situation does not occur in DVT eclipse. Use "alt+/" to jump out of code completion.
发表于 2023-12-27 19:45:30 | 显示全部楼层
I found a solution, it's a shortcut conflict, but I still don't know how to make it turn on by default instead of always using "ctrl+space"
发表于 2024-1-31 13:03:40 | 显示全部楼层
Thanks
发表于 2024-2-6 10:32:49 | 显示全部楼层
I put the li ...
Hi, I meet the same issue, also display "[dvt] Language Server did not start because launch command terminated with exit code 1!" in VScode.
I installed VScode and the latest dvt extension, reverted to the older version(ver.22.1.16), replaced the jar file, and set DVT_HOME and DVT_LICENSE_FILE in configuration of dvt extension.  I do not know what cause the issue. By the way, The DVT Eclipse i installed is dvt_kit-22.1.16-e419-win_64 from eetop, but can not find any license.dat file, can you share the file ?
 楼主| 发表于 2024-2-9 22:16:37 | 显示全部楼层
jar file version have to be same.
GMT+8, 2025-12-26 07:32 , Processed in 0.022028 second(s), 3 queries , Gzip On, Redis On.
