楼主: rifat_rally
request for lic of DVT IDE for vscode
 楼主| 发表于 2024-2-9 22:18:20 | 显示全部楼层
mozilaam 发表于 2024-2-6 10:32
Hi, I meet the same issue, also display "[dvt] Language Server did not start because launch comman ...
jar file version have to be same. LIC:
Local DVT_CORE 20-NOV-2018 30-2030 "License Created by Study" ANY 08AC473A088EB8EAE540B3961495C
LOCAL DVT_S V 20-NOV-2018 30-DEC-2030 "License Created by Study" ANY 68191 E9606045CB8B90F6AD684DC670C
LOCAL dvt_sv_debug 20-nov-2018 30-dec-2030 "License created by study" ANY 707CF12F252CC EC2EE8F675DCFAD8332
LOCAL
dvt_vhdl_debug 20-nov-2018 30-dec - 2030 "License created by study" ANY 86AE5308407CD115DD5F148EDC811B55
LOCAL dvt_e 20-nov-2018 30 -dec-2030 "License created by study" ANY 0610E531311DB557598474AE4E90D627
LOCAL dvt_e_debug 20-nov-2018 30-dec-2030 "License created by study" ANY BEBB29933B38B37A447BFCF090D9B738
LOCAL dvt_ pss 20-nov-2018 30-dec-2030 "License created by study" ANY 293191FF6A3F9B8CFE41A0DEA60CB025
LOCAL dvt_sv_lint 20-nov-2018 30-dec-2030 "License created by study" ANY 549714A42E27A 360F114F8B734A04A49
发表于 2024-3-16 18:03:49 | 显示全部楼层
加载了license还是出现相同的问题,将DVT回退旧一点的版本左边栏插件图标下出现DVT小图标,但仍然有报错信息:
[dvt] read ECONNRESET    Error: read ECONNRESET at TCP.onStreamRead (node:internal/stream_base_commons:217:20)
可以说下VSCODE和DVT插件安装的是哪个版本吗,以及其他未提及的安装细节信息,谢谢
 楼主| 发表于 2024-3-17 04:32:32 | 显示全部楼层
As I found new version, I have updated to newer one, though old version also worked.
VS code version: 1.87.2
DVT IDE for Visual Studio Code extension version: 23.2.30
new lic:
FEATURE dvt_core dvtlmd 2099.99 29-aug-2119 uncounted \
        11111111111111111111 HOSTID=ANY SIGN2=111111111111
FEATURE dvt_cpp_ext dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sv dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sv_batch dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sv_debug dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sv_lint dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sv_specador dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_vhdl dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_vhdl_debug dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_vhdl_lint dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_vhdl_specador dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_e dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_e_batch dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_e_debug dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_e_specador dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_pass_lint dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sln dvtlmd 2099.99 29-aug-2119 uncounted \
FEATURE dvt_sdl dvtlmd 2099.99 29-aug-2119 uncounted \
 楼主| 发表于 2024-3-17 04:37:15 | 显示全部楼层
mozilaam 发表于 2024-3-16 18:03
加载了license还是出现相同的问题,将DVT回退旧一点的版本左边栏插件图标下出现DVT小图标,但仍然有报错 ...
As I found a newer version, I have switched to it. Though the old version also worked.
发表于 2024-4-12 11:56:36 | 显示全部楼层
谢谢,问题已经解决,我使用vscode 1.85.2, dvt 23.1.3
你使用23.2.30的dvt.flclient版本是2.13是怎样做到的
另外,在使用过程中关闭vscode再重新打开会rebuild工程,如果工程庞大每次打开都rebuild会比较烦扰,在build文件加了dvt_db_location也没起作用,似乎是一个bug,你有碰到过这个现象吗
发表于 2024-4-12 18:50:04 | 显示全部楼层
你使用23.2.30的dvt.flclient版本是2.13是怎样做到 ...
请教一下你的问题是怎么解决的
发表于 2024-4-15 09:31:30 | 显示全部楼层
etopjp 发表于 2024-4-12 18:50
请教一下你的问题是怎么解决的
按13楼的步骤和楼主提供的license,以及vscode和dvt需要特定版本,我用的vscode 1.85.2, dvt 23.1.3没问题
发表于 2024-4-15 21:35:08 | 显示全部楼层
mozilaam 发表于 2024-4-15 09:31
按13楼的步骤和楼主提供的license,以及vscode和dvt需要特定版本,我用的vscode 1.85.2, dvt 23.1.3没问 ...
我试试,多谢!
发表于 2025-1-23 07:40:14 | 显示全部楼层
VS code versio ...
谢谢谢谢谢谢
GMT+8, 2025-12-20 01:46 , Processed in 0.023070 second(s), 4 queries , Gzip On, Redis On.
