查看: 1504|回复: 0
[原创] 求教,PEX寄生提取时出现 undefined primary layer 错误
发表于 2023-10-14 16:59:24 | 显示全部楼层 |阅读模式
如题所示,使用calibre - PEX 寄生提取时出现如下错误,
-----  CALIBRE xRC::HIERARCHICAL PARASITIC EXTRACTOR - EXECUTIVE MODULE    -----
ERROR: Layer n_poly contains shapes, appears in PEX MAP with undefined primary layer
ERROR: Layer p_poly contains shapes, appears in PEX MAP with undefined primary layer
ERROR: Layer rupolym_dp contains shapes, appears in PEX MAP with undefined primary layer
FATAL ERROR: Rules check against design data failed, exiting...
                  CALIBRE xRC WARNING / ERROR Summary
                        xRC Warnings  =  30
                          xRC Errors  =  4
*** Calibre finished with Exit Code: 1 ***
GMT+8, 2025-9-19 12:42 , Processed in 0.014456 second(s), 4 queries , Gzip On, Redis On.
