查看: 2203|回复: 2
[求助] vdb目录拷贝到别的电脑不能运行urg
发表于 2023-7-23 21:26:58 | 显示全部楼层 |阅读模式
系统:CentOS7 -> Ubuntu 20.04
版本:Synopsys VCS 2020 -> Synopsys VCS 2016
背景:在CentOS7系统中生成的覆盖率文件test.vdb,拷贝到Ubuntu系统中用urg命令生成覆盖率报告,会报错,报错信息如下,搜了很多也没找到解决方法,求大神解答。
为什么要拷贝呢,因为在安装的Ubuntu系统中运行不了项目,所以在CentOS7中运行,但是CentOS7中运行不了urg命令(会报错,报错信息见 https://bbs.eetop.cn/thread-952944-1-1.html 如果大神可以解决也麻烦帮忙看看),在Ubuntu中可以运行,所以我在CentOS7中运行并生成vdb文件,拷贝到Ubuntu中查看,此时遇到了下面的报错。
报错信息:
$ urg -lca -dir test.vdb/
INFO : The directory  'test.vdb/' passed to the URG command line is generated from a 64-bit simulation kernel. Hence, '-full64' is automatically added to the URG command line and URG would generate the reports with Full64 VCS installation.
URG Version L-2016.06 Copyright (c) 1991-2016 by Synopsys Inc.
20:12:02 (snpslmd) OUT: "VCSTools_Net" super@ubuntu
20:12:02 (snpslmd) IN: "VCSTools_Net" super@ubuntu
Warning-[LCA_FEATURES_ENABLED] Usage warning
  LCA features enabled by '-lca' argument on the command line.  For more
  information regarding list of LCA features please refer to Chapter "LCA
  features" in the VCS/VCS-MX Release Notes
Load Failed:
Error-[UCAPI-FLF] Ucapi file loading failed
  Error occurred while loading file
  'test.vdb/snps/coverage/db/shape/fsm.verilog.shape.xml'.
Corrupt design found:
Error-[UCAPI-DESCORR] Design found corrupted
  The database directory 'test/test_riscv_arithmetic_basic_test_0' may have
  been corrupted. Please try regenerating it. If the problem still persists,
  please contact vcs_support@synopsys.com for information.
Warning-[URG-LTF] Load test failed
  Skipping test 'test/test_riscv_arithmetic_basic_test_0' as error occurred
  while loading the test.
  The test directory may have been corrupted. Please try regenerating it. If
  the problem still persists, please contact vcs_support@synopsys.com for
  information.
Error-[URG-NVAT] No test found
  URG could not find any valid test.
  Please use the -dir option to specify the test directories to report.
发表于 2024-7-24 11:34:28 | 显示全部楼层
找到解决办法了吗,哥
发表于 2025-6-26 17:37:12 | 显示全部楼层
需要对libucapi.so做一下Patch.补丁可以参考这篇贴子,SynopsysMonoSlayer的作者@TerraWilly 提供了针对不同版本VCS和Verdi的修复
GMT+8, 2025-10-26 04:27 , Processed in 0.018789 second(s), 4 queries , Gzip On, Redis On.
