查看: 2151|回复: 4
[求助] IC617中的diode参数设置
发表于 2023-7-11 15:22:46 | 显示全部楼层 |阅读模式
我最近在学习DCDC,看视频里面的diode的原理图,我照着画了,但是仿真的时候一直报错,有人之前做过diode的symbol吗,请教一下过程。
发表于 2023-7-11 15:24:12 | 显示全部楼层
diode 的symbol 需要使用 diode spectre model
 楼主| 发表于 2023-7-11 17:42:27 | 显示全部楼层
对呀,仿真的时候,提示这样
 楼主| 发表于 2023-7-11 18:09:25 | 显示全部楼层
错误变成这样:  ERROR (SFE-23): "input.scs" 23: The instance `D0' is referencing an undefined model or subcircuit, `subcircuit'. Either include the file containing the definition of `subcircuit', or define `subcircuit' before running the simulation.
Warning from spectre during hierarchy flattening.
发表于 2023-7-12 08:53:30 | 显示全部楼层
需要创建自己的 diode spectre model
spectre -h diode
e.g. mydiode.scs
GMT+8, 2025-10-21 21:38 , Processed in 1.381514 second(s), 4 queries , Gzip On, Redis On.
