楼主: shindziharan
C* SP3CTRE231
发表于 2023-6-25 17:22:19 | 显示全部楼层
thanks
 楼主| 发表于 2023-6-25 17:45:20 | 显示全部楼层
test_123 发表于 2023-6-25 16:42
来个21.1 isr19
Check your uploads in the cloud drive, hotfixes 15, 16, 18, and 19 should appear there. The theme for version 211 is currently under review by the administrator after editing.
And for lalala2018
Yes, this version supports GPU. If you have Nvidia Tesla V100, A100, or H100, you can give it a try. As far as I know, you just need to add the "+gpu" option to the command line for your simulation, and of course, this only works with Spectre X.
发表于 2023-6-26 15:20:30 | 显示全部楼层
you r a such nice guy, thanks you a lot
发表于 2023-6-26 16:08:49 | 显示全部楼层
thank you a lot!
发表于 2023-6-26 16:14:30 | 显示全部楼层
thank you a lot!
发表于 2023-6-26 16:41:20 | 显示全部楼层
New release of Sxxxxxx?  Looks good.
发表于 2023-6-26 16:58:13 | 显示全部楼层
What does the message mean? "MDBENzEwMjY3N0ZGQjMzMEU0RUMwM0VCMjMzNkMwMjUgIEJhc2VfU1BFQ1RSRTIzLjEwLjA2M1xCYXNlX1NQRUNUUkUyMy4xMC4wNjNfbG54ODZfMW9mMi50YXI= RkZDMEY3MDRBNDM0MDcyQzZDRjM3QTE5N0E3NDg0MzEgIEJhc2VfU1BFQ1RSRTIzLjEwLjA2M1xCYXNlX1NQRUNUUkUyMy4xMC4wNjNfbG54ODZfMm9mMi50YXI= NzZEQkQ3NTA4RjNDMTk5NTVBNkE2N0Q3M0U1NjIyMUIgIEJhc2VfU1BFQ1RSRTIzLjEwLjA2M1xCYXNlX1NQRUNUUkUyMy4xMC4wNjNfUkVBRE1FLWNoZWNrc3Vtcy5tZDU= QkM4OTVEMkExRjgxMDBEQTA4NzYyMzdBRDFFM0JGNkMgIEJhc2VfU1BFQ1RSRTIzLjEwLjA2M1xCYXNlX1NQRUNUUkUyMy4xMC4wNjNfUkVBRE1FLXJlbGVhc2VfaW5mb19zcGVjdHJlMjMxLnBkZg== NzAyMTJBNkZFMEEyMjhGQkQwMjlEM0JEMEY5QTg2ODEgIEJhc2VfU1BFQ1RSRTIzLjEwLjA2M1xCYXNlX1NQRUNUUkUyMy4xMC4wNjNfUkVBRE1FLXNwZWN0cmUyMzEudHh0"
发表于 2023-6-26 17:05:51 | 显示全部楼层
base64编码,文件md5
发表于 2023-6-26 21:19:19 | 显示全部楼层
thank you for sharing
发表于 2023-6-27 07:16:53 | 显示全部楼层
Does S23 require new features in license file?
GMT+8, 2025-12-15 04:54 , Processed in 0.017664 second(s), 3 queries , Gzip On, Redis On.
