楼主: shindziharan
C* SP3CTRE231
发表于 2023-6-27 08:26:11 | 显示全部楼层
any new features in 231 comparing with 211?
发表于 2023-6-27 09:14:31 | 显示全部楼层
多谢大佬
发表于 2023-6-27 09:24:45 | 显示全部楼层
Nice job!
发表于 2023-6-27 09:24:47 | 显示全部楼层
感谢大神
发表于 2023-6-27 10:07:30 | 显示全部楼层
Wish you speedy recovery!
发表于 2023-6-27 10:14:47 | 显示全部楼层
thank you
 楼主| 发表于 2023-6-27 15:38:43 | 显示全部楼层
Some of you have asked about the features that appeared in this release, so here's the difference between v23.1 and v21.1.
Six new 'products' have been added, and each of them should naturally have at least one feature, sometimes several, and sometimes some of them repeat those already existing.
I know about 5 new features. I have doubts about one more, but most likely it is as I think. There should be one more, but I can't figure out the conditions for it to appear.
If anyone among you has a graphics card from this list: V100, A100, H100, and at least a 16-core processor in the same system, and you have a 'heavy' transient simulation (millions of devices) that takes a long time to compute on the CPU, and you have installed the new release, and you know how to modify/add features to your license file and are ready to experiment, please write to me in private messages, and I will provide you with the necessary GPU feature and give a couple of tips on setting up your environment, if the simulation fails to launch.
Additionally, you need to install several extra packages (my example is for RHEL8):
cuda-cudart
cuda-toolkit-11-8-config-common
cuda-toolkit-11-config-common
cuda-toolkit-config-common
libcusparse
libcusolver
libcublas
发表于 2023-6-27 16:44:26 | 显示全部楼层
感謝樓主無私分享
发表于 2023-6-29 22:44:17 | 显示全部楼层
shindziharan 发表于 2023-6-27 15:38
Some of you have asked about the features that appeared in this release, so here's the difference be ...
Thanks for sharing. Where can we find the supported nvidia gpu list?
Does 231 only support these nvidia computing GPUs: V100, A100, H100?
Any gaming GPUs such as RTX 3090 or 4090 is supported?
发表于 2023-6-30 10:30:56 | 显示全部楼层
Thanks!
GMT+8, 2025-12-15 04:54 , Processed in 0.018892 second(s), 4 queries , Gzip On, Redis On.
