查看: 2604|回复: 1
[求助] DC workshop lab1 求助
发表于 2023-5-24 15:06:43 | 显示全部楼层 |阅读模式
我在做论坛里的DC Lab workshop 2017.9,用的是芯王国的环境,design compiler 2018.06。
前面没有问题,Task2 check_library时候报错:Error: The check_library command failed to run. Check the installation of Library Compiler. (LCSH-3)
略过这一步,后面compile_ultra则会报错:
Information: Sequential output inversion is enabled.  SVF file must be used for formal verification. (OPT-1208)
  Loading target library 'cb13fs120_tsmc_max'
Error: The target library does not contain all required gates.
Either a NOR, or an AND and an OR gate (two-input) is required for mapping. (OPT-102)
Error: Compile has abnormally terminated.  (OPT-100)
请问是哪里出了问题?是要装library compiler吗?但是library compiler不是在dc里内置的吗?没有library compiler会对compile产生影响吗?
 楼主| 发表于 2023-5-24 16:28:41 | 显示全部楼层
是在windows下解压格式出现的错误,此贴终结
GMT+8, 2025-12-14 02:58 , Processed in 0.012304 second(s), 4 queries , Gzip On, Redis On.
