查看: 1963|回复: 6
[求助] 使用脚本抽取CDL会报error:undefined variable - mgc_rve_load
发表于 2023-4-18 17:48:17 | 显示全部楼层 |阅读模式
悬赏20资产未解决
参考网上大神搞了个抽取cdl的脚本,报如下error
Error* load/loadstring: undefined variable - mgc_rve_load_export_netlist_template_file
下面是脚本代码
  1. #!/bin/csh -f
  2. set cellname = $2
  3. set library = $1
  4. set include_file = "`pwd`/source.added"
  5. cat << EOF >! si.env
  6. simLibName = "$library"
  7. simCellName = "$cellname"
  8. simViewName = "schematic"
  9. simSimulator = "auCdl"
  10. netlistType = "Connection By Order"
  11. hnlNetlistFileName = "$cellname.cdl"
  12. incFile = "$include_file"
  13. simNotIncremental = 't
  14. simReNetlistAll = nil
  15. simViewList = '("auCdl" "schematic")
  16. simStopList = '("auCdl")
  17. resistorModel = ""
  18. shortRES = 2000.0
  19. preserveRES = 't
  20. checkRESVAL = 't
  21. checkRESSIZE = 'nil
  22. preserveCAP = 't
  23. checkCAPVAL = 't
  24. checkCAPAREA = 'nil
  25. preserveDIO = 't
  26. checkDIOAREA = 't
  27. checkDIOPERI = 't
  28. checkCAPPERI = 'nil
  29. simPrintInhConnAttributes = 'nil
  30. checkScale = "meter"
  31. checkLDD = 'nil
  32. pinMAP = 'nil
  33. preserveBangInNetlist = 'nil
  34. shrinkFACTOR = 0.0
  35. globalPowerSig = ""
  36. globalGndSig = ""
  37. displayPININFO = 't
  38. preserveALL = 't
  39. setEQUIV = ""
  40. incFILE = ""
  41. auCdlDefNetlistProc = "ansCdlSubcktCall"
  42. EOF
  43. cat /dev/null >! netlist
  44. $CDSHOME/tools/dfII/bin/si -batch -command netlist
    复制代码
请问这个问题应该怎么处理?
发表于 2023-4-18 18:07:07 | 显示全部楼层
亲自验证脚本没有问题啊
发表于 2023-4-18 20:03:43 | 显示全部楼层
先source 一下你的virtuoso 环境变量再运行脚本试试
 楼主| 发表于 2023-4-19 09:15:52 | 显示全部楼层
是.cdsenv吗?试了一下还是不行。
 楼主| 发表于 2023-4-19 09:17:43 | 显示全部楼层
maomao198477 发表于 2023-4-18 18:07
亲自验证脚本没有问题啊
代码应该是没问题的,为什么我会报error呢?奇怪
发表于 2023-4-20 17:15:57 | 显示全部楼层
#在这里快速回复#CDSHOME/tools/dfII/bin/si这个路径对吗
发表于 2023-4-20 17:40:02 来自手机 | 显示全部楼层
脚本在哪里运行的?怎么运行的。
GMT+8, 2025-9-14 03:29 , Processed in 0.016781 second(s), 3 queries , Gzip On, Redis On.
