查看: 3328|回复: 3
[求助] 有没有大佬可以登录candence社区,麻烦帮忙看一个错误的解决方案
发表于 2022-11-22 21:15:08 | 显示全部楼层 |阅读模式
悬赏50资产已解决
最佳答案
查看完整内容
Definition You have upgraded to the Virtuoso IC6.1.X tool suite. You are trying to perform Verilog Import using CIW => File => Import => Verilog In. You have included paths in.cshrc to ncvlog or xmvlog from XCELIUM or Incisive tool suite. LINUX> which ncvlog Or LINUX> which xmvlog Returns the correct path. Still you get the error message as shown in Error Message section. Solution You h ...
发表于 2022-11-22 21:15:09 | 显示全部楼层
Definition
LINUX>  which ncvlog
Or
LINUX>  which xmvlog
Solution
You have set the Virtuoso path:
LINUX>  set path = ( /cds/lnx86/IC617_cd/bin $path )
You do:
LINUX>  which virtuoso
It returns:​
/cds/lnx86/IC617_cd/bin/virtuoso
You rectify this by insuring your path is set correctly using the documented settings $CDSHOME/tools/bin rather than $CDSHOME/bin
set path = ($CDSHOME/tools/bin $CDSHOME/tools/dfII/bin $path)
发表于 2022-11-23 08:41:45 | 显示全部楼层
学习学习
 楼主| 发表于 2022-11-23 09:58:31 | 显示全部楼层
xart 发表于 2022-11-22 21:15
Definition
You have upgraded to the Virtuoso IC6.1.X tool suite. You are trying to perform Verilog  ...
感谢大佬
GMT+8, 2025-12-19 19:42 , Processed in 0.019191 second(s), 5 queries , Gzip On, Redis On.
