查看: 2659|回复: 3
[求助] pt 生成sdf的时候报了非常多driver/load pin miss的error是为什么?
发表于 2022-6-22 11:10:41 | 显示全部楼层 |阅读模式
错误如下Driver pin 'XXX' is missing in the RC annotation for net 'XXXX'.  Ignoring the incomplete RC annotation. (PARA-006)
Load pin 'XXXX' is missing in the RC annotation for net 'rst_n'.  Ignoring the incomplete RC annotation. (PARA-006)
网表和spf文件确认过了是对应的
搜索
复制
发表于 2022-6-22 11:12:37 | 显示全部楼层
pt不认spf吧?应该用spef
 楼主| 发表于 2022-6-22 11:41:42 | 显示全部楼层
        0 error(s)
        Format is DSPF
        Annotated nets                   :
        Annotated capacitances           :
        Annotated resistances            :
        Reduced coupling capacitances    :
能认
 楼主| 发表于 2022-6-22 11:49:29 | 显示全部楼层
lzqxiang 发表于 2022-6-22 11:12
pt不认spf吧?应该用spef
换成了spef 还是一样的报错,pin missing
GMT+8, 2025-12-26 12:21 , Processed in 0.017688 second(s), 4 queries , Gzip On, Redis On.
