查看: 10381|回复: 27
[求助] 求助Ubuntu 22.04 中 VCS 2018.09-SP2遇到undefined reference to `pthread_yield\'的错误
发表于 2022-5-23 19:14:53 | 显示全部楼层 |阅读模式
悬赏60资产未解决
问题:
在Ubuntu 22.04中用下面的指令运行VCS
  1. vcs -full64 -Mupdate=0 -cpp g++-4.8 -cc gcc-4.8 -LDFLAGS -Wl,-no-as-needed tb_count.v count.v -R -timescale=1ns/1ns +v2k
    复制代码
提示错误
  1. /usr/bin/ld: /SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/linux64/lib/vcs_save_restore_new.o: in function `SNPSee_907e539fb4bc8f7101eac356af4ce4ed':
  2. ../../OBJ/lib/saverestoreobj/obj-linux64/kernel.o:(.text+0xc41): undefined reference to `pthread_yield'
    复制代码
请问各位大佬有什么方法解决嘛?不知道是哪里搞错了,感谢!另外,dve可以打开。
运行环境:
Win10,AMD 5800H,VM 16 虚拟机,Ubuntu 22.04,gcc有11和4.8版本的,VCS 2018.09-SP2
详细信息:
  1. $ vcs -full64 -Mupdate=0 -cpp g++-4.8 -cc gcc-4.8 -LDFLAGS -Wl,-no-as-needed tb_count.v count.v -R -timescale=1ns/1ns +v2k
  2. *** Using c compiler gcc-4.8 instead of cc ...
  3.                          Chronologic VCS (TM)
  4.        Version O-2018.09-SP2_Full64 -- Sun May 22 12:27:13 2022
  5.                Copyright (c) 1991-2018 by Synopsys Inc.
  6.                          ALL RIGHTS RESERVED
  7. This program is proprietary and confidential information of Synopsys Inc.
  8. and may be used and disclosed only as authorized in a license agreement
  9. controlling such use and disclosure.
  10. Parsing design file 'tb_count.v'
  11. Parsing design file 'count.v'
  12. Top Level Modules:
  13.        tb_count
  14. TimeScale is 1 ns / 1 ps
  15. Starting vcs inline pass...
  16. Warning-[MKE_MUDT] Old makefile exists
  17.   Makefile 'csrc/Makefile' exists. Use -Mupdate to force overwrite.
  18. 1 module and 0 UDP read.
  19.         However, due to incremental compilation, no re-compilation is necessary.
  20. gcc -w  -I/SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/include -O  -fno-strict-aliasing    -c -o amcQwB.o amcQwB.c
  21. if [ -x ../simv ]; then chmod -x ../simv; fi
  22. g++-4.8  -o ../simv   /SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/linux64/lib/vcs_save_restore_new.o -lm -lc -pthread -ldl -Wl,-no-as-needed  -Wl,-rpath=/SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/linux64/lib -L/SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/linux64/lib    -Wl,-whole-archive    -lvcsucli -Wl,-no-whole-archive    objs/amcQw_u1_c.o objs/amcQw_d.o objs/mINIW_d.o amcQwB.o objs/mINIW_u1_c.o   SIM_l.o       rmapats_mop.o rmapats.o rmar.o rmar_nd.o  rmar_llvm_0_1.o rmar_llvm_0_0.o        -lzerosoft_rt_stubs -lvirsim -lerrorinf -lsnpsmalloc -lvfs     -lvcsnew -lsimprofile -luclinative /SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/linux64/lib/vcs_tls.o
  23. /usr/bin/ld: /SynopsysSoftware/VCS/vcs-mx/O-2018.09-SP2/linux64/lib/vcs_save_restore_new.o: in function `SNPSee_907e539fb4bc8f7101eac356af4ce4ed':
  24. ../../OBJ/lib/saverestoreobj/obj-linux64/kernel.o:(.text+0xc41): undefined reference to `pthread_yield'
  25. collect2: error: ld returned 1 exit status
  26. make: *** [Makefile:99: product_timestamp] Error 1
  27. Make exited with status 2
  28. CPU time: .136 seconds to compile + .133 seconds to elab + .159 seconds to link
    复制代码
发表于 2022-5-24 10:42:32 | 显示全部楼层
太新了,没人用过。自己探索吧,我只能说20.04是好的。
 楼主| 发表于 2022-5-24 18:43:10 | 显示全部楼层
我是一路趟坑过来,终于这个我搞不定了
发表于 2022-5-25 04:22:36 | 显示全部楼层
Check this out
vcs -full64 -Mupdate=0 -cpp g++-4.8 -cc gcc-4.8 -LDFLAGS -Wl,-no-as-needed,-lpthread tb_count.v count.v -R -timescale=1ns/1ns +v2k
发表于 2022-5-25 17:32:56 | 显示全部楼层
中文行吗 发表于 2022-5-24 18:43
我是一路趟坑过来,终于这个我搞不定了
试试gcc4.4版本。20.04也不能用4.8
发表于 2022-7-24 18:37:43 | 显示全部楼层
最后解决了吗老哥?
发表于 2022-8-14 22:48:04 | 显示全部楼层
解决了吗+1
发表于 2022-8-25 18:25:04 | 显示全部楼层
我也遇到了这个问题,似乎是Ubuntu 22.04底层的包太新了。 建议换20.04
发表于 2022-8-27 19:07:53 | 显示全部楼层
我是一路趟坑过来,终于这个我搞不定了
大佬,我和你一样也是卡在这里了,dve和verdi都能跑,就是vcs编译不能生成simv文件,请问你解决了吗
发表于 2022-8-27 19:10:20 | 显示全部楼层
有大佬解决了吗
GMT+8, 2025-9-15 05:29 , Processed in 0.016551 second(s), 3 queries , Gzip On, Redis On.
