查看: 3166|回复: 5
[求助] DC综合产生def文件报错:Error: Current design xxx does not have any CTL model attached. ScanDEF generation ca...
发表于 2022-2-16 00:31:12 | 显示全部楼层 |阅读模式
dc_shell> write_scan_def -output $MAPPED_PATH/TOP_SS.def
Error: Current design xxx does not have any CTL model attached. ScanDEF generation cannot proceed.
0
想用DC生成def文件,给ICC做布局布线,但是DC一直报这个错,网上找了个遍都没找到这种情况,有没有大佬遇到过,求解
 楼主| 发表于 2022-2-16 00:32:01 | 显示全部楼层
有没有大佬啊,急
发表于 2022-2-16 08:03:35 | 显示全部楼层
man write_scan_def
 楼主| 发表于 2022-2-16 12:33:05 | 显示全部楼层
maomao198477 发表于 2022-2-16 08:03
man write_scan_def
我按着这个步骤,就卡在insert_dft这,之后又在insert_dft中按照这个步骤:
解决了几个报错,但是又有新的报错了:
dc_shell> insert_dft
Error: No TAP TMS has been specified.
Warning: No TAP TRST or power up reset has been specified.
Information: DFT insertion was not successful. There were unrecoverable processing errors. (TEST-211)
0
这个要咋解决,TAP TMS 是啥???
发表于 2022-2-16 13:28:54 | 显示全部楼层
看一下insert_def之前,dft_drc 的报告,如果有问题的话,insert_def是不会执行的
发表于 2022-5-18 17:14:41 | 显示全部楼层
楼主,我也遇到这样的问题,请问您解决了吗?
GMT+8, 2025-11-20 05:55 , Processed in 0.019190 second(s), 5 queries , Gzip On, Redis On.
