发表于 2021-9-1 15:55:54
显示全部楼层
- " Vim with all enhancements
- source $VIMRUNTIME/vimrc_example.vim
- " Use the internal diff if available.
- " Otherwise use the special 'diffexpr' for Windows.
- if &diffopt !~# 'internal'
- set diffexpr=MyDiff()
- endif
- function MyDiff()
- let opt = '-a --binary '
- if &diffopt =~ 'icase' | let opt = opt . '-i ' | endif
- if &diffopt =~ 'iwhite' | let opt = opt . '-b ' | endif
- let arg1 = v:fname_in
- if arg1 =~ ' ' | let arg1 = '"' . arg1 . '"' | endif
- let arg1 = substitute(arg1, '!', '\!', 'g')
- let arg2 = v:fname_new
- if arg2 =~ ' ' | let arg2 = '"' . arg2 . '"' | endif
- let arg2 = substitute(arg2, '!', '\!', 'g')
- let arg3 = v:fname_out
- if arg3 =~ ' ' | let arg3 = '"' . arg3 . '"' | endif
- let arg3 = substitute(arg3, '!', '\!', 'g')
- if $VIMRUNTIME =~ ' '
- if &sh =~ '\<cmd'
- if empty(&shellxquote)
- let l:shxq_sav = ''
- set shellxquote&
- endif
- let cmd = '"' . $VIMRUNTIME . '\diff"'
- else
- let cmd = substitute($VIMRUNTIME, ' ', '" ', '') . '\diff"'
- endif
- else
- let cmd = $VIMRUNTIME . '\diff'
- endif
- let cmd = substitute(cmd, '!', '\!', 'g')
- silent execute '!' . cmd . ' ' . opt . arg1 . ' ' . arg2 . ' > ' . arg3
- if exists('l:shxq_sav')
- let &shellxquote=l:shxq_sav
- endif
- endfunction
- exec 'cd ' . fnameescape('D:\MyCode')
- " gVim Setup
- "set smarttab " 根据文件中其他地方的缩进空格个数来确定一个 tab 是多少个空格
- set tabstop=4 " 表示一个 tab 显示出来是多少个空格
- set shiftwidth=4 " 每一级缩进是多少个空格
- set expandtab " 将tab扩展成空格
- set number " 打开行号
- set guifont=Consolas:h12
- colorscheme desert " 色彩方案
- set lines=40 columns=120 "启动时窗口大小
- :set backspace=indent,eol,start
- :set paste
- " :map ?--定制映射
- " :ab --定制简写
- " Add File Header
- :map <F1> :call AddHeader()<CR>
- function AddHeader()
- call append(0, "//=======================================================================")
- call append(1, "// Company : ")
- call append(2, "// Filename : .v")
- call append(3, "// Author : Rongye")
- call append(4, "// Created On : ".strftime("%Y-%m-%d %H:%M"))
- call append(5, "// Last Modified : ")
- call append(6, "// Description : ")
- call append(7, "// ")
- call append(8, "// ")
- call append(9, "//=======================================================================")
- endfunction<Enter>
- "对齐注释
- :map duiqi3 0f/i <ESC>073ldw
- " Add Modify Time
- :map <F2> :w<CR>:6d<CR>:call AddModify()<CR>
- function AddModify()
- call append(5, "// Last Modified : ".strftime("%Y-%m-%d %H:%M"))
- endfunction
- " Add Module
- :ab modu module MODULE_NAME<Enter>#(<Enter> <ESC>04ldwi parameter <ESC>048ldwi WIDTH <ESC>060ldwi = 8 <ESC>072ldwi //<Enter><Esc>4Xi)<Enter>(<Enter> <ESC>04ldwi //Input<Enter> <ESC>04ldwi input <ESC>048ldwi clk <ESC>072ldwi ,<Enter> <ESC>04ldwi input <ESC>048ldwi rst_n <ESC>072ldwi ,<Enter> <ESC>04ldwi input <ESC>048ldwi en <ESC>072ldwi ,<Enter> <ESC>04ldwi input <ESC>024ldwi [WIDTH-1:0] <ESC>048ldwi data_i <ESC>072ldwi , //<Enter> <ESC>04ldwi //Output<Enter> <ESC>04ldwi output <ESC>016ldwi reg <ESC>024ldwi [WIDTH-1:0] <ESC>048ldwi data_o <ESC>072ldwi //<Enter>);<Esc>^4X$i<Enter><Enter><Enter><Enter>endmodule<Esc>kkk
- " Add input/output
- :ab inpu1 input <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi input_name <Esc>072ldwi , //
- :ab outp1 output <ESC>016ldwi reg <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi output_name <Esc>072ldwi , //
- " Add reg
- :ab reg1 reg <Esc>048ldwi reg_name <Esc>072ldwi ; //
- :ab reg2 reg <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi reg_name <Esc>072ldwi ; //
- " Add wire
- :ab wire1 wire <Esc>048ldwi wire_name <Esc>072ldwi ; //
- :ab wire2 wire <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi wire_name <Esc>072ldwi ; //
- " Add parameter
- :ab para1 parameter <ESC>048ldwi NAME_WIDTH <ESC>060ldwi = 8 <ESC>072ldwi , //
- " Add always statement
- :ab zuhe always @(*)begin<Enter><Enter><Enter>end<Esc>kk
- :ab shixu always @(posedge clk or negedge rst_n)begin<Enter>if(!rst_n)begin<Enter><Enter>end<Enter>else begin<Enter><Enter>end<Enter><Esc>4Xiend<Esc>kk
- " Add if / else statement
- :ab if1 if(!rst_n)begin<Enter><Enter>end<Esc>kk
- :ab else1 else begin<Enter><Enter>end<Esc>kk
- " Add case statement
- :ab case1 case()begin<Enter>1'b0:;<Enter>1'b1:;<Enter>default:;<Enter><Esc>4Xiendcase<Esc>kk
- " Add Counter
- :ab jishu reg <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi cnt <Esc>072ldwi ; //<Enter>always @(posedge clk or negedge rst_n)begin<Enter>if(!rst_n)begin<Enter>cnt <= 4'd0;<Enter>end<Enter>else if(cnt==4'd9)begin<Enter>cnt <= 4'd0;<Enter>end<Enter>else begin<Enter>cnt <= cnt + 1'd1;<Enter>end<Enter>end<Enter><Esc>
- " Add FSM_2
- :ab fsm2 reg <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi state_current <Esc>072ldwi ; //<Enter>reg <Esc>024ldwi [NAME_WIDTH-1:0] <Esc>048ldwi state_next<Enter>reg <Esc>048ldwi FSM_out <Esc>072ldwi ; //<Enter><Enter>always @(posedge clk or negedge rst_n)begin<Enter>if(!rst_n)begin<Enter>state_current <= IDLE;<Enter>end<Enter>else begin<Enter>state_current <= state_next;<Enter>end<Enter>end<Enter><Enter><Enter>always @(*)begin<Enter>FSM_out = 1'b0;<Enter>case(state_current)<Enter>IDLE:begin<Enter>if(FSM_in)<Enter>state_next = S1;<Enter>else<Enter>state_next = state_current;<Enter>end<Enter>S1:begin<Enter>if(FSM_in)<Enter>state_next = S2;<Enter>else<Enter>state_next = state_current;<Enter>end<Enter>S2:begin<Enter>if(FSM_in)begin<Enter>FSM_out = 1'b1;<Enter>state_next = IDLE;<Enter>end<Enter>else<Enter>state_next = state_current;<Enter>end<Enter><Enter>default:state_next = IDLE;<Enter>endcase<Enter>end<Enter>
复制代码
