楼主: jjjjjzy
[求助] cdl转schematic后电阻尺寸异常
 楼主| 发表于 2021-6-2 13:55:54 | 显示全部楼层
jzr1989 发表于 2021-6-2 13:49
看起来是正确的,结果如何呢
仍然行不通。log文件提示如下:
Importing SUBKCT 'rupolym_m' in Library 'res0601'
        Master Cellview Found in tsmcN28::rupolym_m::symbol
        Skipping import for subckt: rupolym_m
Instance: XR1
        Instance has master: 'rupolym_m' model/subtype: 'rupolym_m'
        Created instance 'XR1'.
                Instance Terminal: Created net net029
                Created connection between net 'net029' and term 'PLUS'
                Instance Terminal: Found net AVSS
                Created connection between net 'AVSS' and term 'MINUS'
                Created connection between net 'AVSS' and term 'BULK'
                CDF parameter not found for 'lr'. User property will be cretated
                Created propName='lr'; propType='float'; propVal='1.6e-05'.
                CDF parameter not found for 'wr'. User property will be cretated
                Created propName='wr'; propType='float'; propVal='1e-06'.
                CDF Type is 'string' and the value given in netlist is 'float' - hence converting to 'string'
                In CDF...                Created propName='m'; propType='string'; propVal='1'.
不知您有何看法呢?拜托了。
GMT+8, 2025-12-29 00:27 , Processed in 0.011830 second(s), 4 queries , Gzip On, Redis On.
