查看: 2244|回复: 1
[求助] sigma delta adc 连续时间 DAC 比较器
发表于 2021-3-8 17:23:29 | 显示全部楼层 |阅读模式
求问continuous time sigma delta adc中的excess loop delay为何总是考虑dac的delay而不是考虑quantizer的delay(比如comparator)?
 楼主| 发表于 2021-3-10 08:57:40 | 显示全部楼层
the important quantity in a ct sigma delta modulator is the “loop delay”,which we define as the total delay between the sampling clock edge and the edge of the DAC output。the quqntizer delay and the DAC delay are often represented by a single delay block,and the combination of these two delays is often referred to as the sigma delta modulator 's excess loop delay.
GMT+8, 2025-12-23 13:40 , Processed in 0.012512 second(s), 5 queries , Gzip On, Redis On.
