楼主: whb610
紧急求助
发表于 2021-2-7 21:19:28 | 显示全部楼层
这么说吧,论坛上各种古怪的安装软件的问题,通过以下命令估计能解决90%以上…
yum install -y redhat-lsb.i686 redhat-lsb.x86_64 ksh zsh xterm python3
yum update -y
 楼主| 发表于 2021-2-8 09:05:53 | 显示全部楼层
z81203 发表于 2021-2-7 14:31
1)用vi打开lmgrd,转换成hex模式,可以看到/lib64/ld-lsb-x86-64.so.3,
2)但redhat7的/lib64下没有ld-ls ...
感谢感谢
 楼主| 发表于 2021-2-8 09:43:25 | 显示全部楼层
lmgrd已经好了,非常感谢您的帮助,我的ic616也有类似问题,能再次帮我看一下吗,启动virtuoso的提示:        WARNING: HOST <localhost.localdomain> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
/eda/cadence/IC/IC616/tools/bin/cdsGetOABinPath: line 87: /eda/cadence/IC/IC616/tools/bin/cds_root: Permission denied
ERROR: Could not find Cadence installation root for
Make sure that cdsGetOABinPath is part of the Cadence installation.
virtuoso:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2021-2-8 14:05:10 | 显示全部楼层
whb610 发表于 2021-2-8 09:43
lmgrd已经好了,非常感谢您的帮助,我的ic616也有类似问题,能再次帮我看一下吗,启动virtuoso的提示:   ...
抱歉,这个帮不到你,很久不用c家的工具了,手头也没有。
 楼主| 发表于 2021-2-8 14:27:12 | 显示全部楼层
好的,谢谢
GMT+8, 2025-12-27 04:46 , Processed in 0.015429 second(s), 3 queries , Gzip On, Redis On.
