查看: 3239|回复: 2
[求助] 版图LVS检查出现的错误,请各路大神指导一下,菜鸟感恩
发表于 2020-11-24 08:36:26 | 显示全部楼层 |阅读模式
今天在cadence上跑了LVS,然后结果如厦门所示,请各位指导一下。
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
  Error:    Connectivity errors.
LAYOUT CELL NAME:         1T1C_cell
SOURCE CELL NAME:         1T1C_cell
NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              4         4
Nets:               7         4    *
Instances:          1         1         MN (4 pins)
                     1         1         C (2 pins)
Total Inst:         2         2
       * = Number of objects in layout different from number in source.
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               4          4            0            0
   Nets:                7          4            0            0
   Instances:           1          1            0            0    MN(n33)
                        1          1            0            0    C(mim3)
   Total Inst:          2          2            0            0
o Statistics:
   1 passthrough layout net was found.
o Passthrough Layout Nets And Their Ports:
      (Layout nets which are connected only to ports).
   WL (port: WL),
o Initial Correspondence Points:
   Ports:        BL WL VSS OUT
发表于 2020-11-24 09:43:32 | 显示全部楼层
提供的信息有限,看不出来啊
发表于 2020-11-24 09:51:30 | 显示全部楼层
“厦门”里面描述的不够清楚,把电路和layout截出来看看,rve里面显示的net相关的结果
GMT+8, 2025-12-25 02:33 , Processed in 0.013456 second(s), 4 queries , Gzip On, Redis On.
