查看: 3474|回复: 3
modelsim problem,help!!
发表于 2003-9-4 20:53:48 | 显示全部楼层 |阅读模式
I use input I/O, everything is ok, but after I change it to bidirectional I/O, in modelsim pe 5.5, it shows the red signal which means undefined, who can tell me why and how to deal with it.
thanks
发表于 2003-9-4 21:06:38 | 显示全部楼层
双向口要用三态门来控制,否则会有数据冲突(红色除了代表信号为定义,也可以是数据冲突)。code可以贴出来看看么?
 楼主| 发表于 2003-9-5 18:54:36 | 显示全部楼层
thanks, bravelu
but I am not clear about how to use three-states gate to control the bidirectional port?
can you give me a sample?  phoenix-y@sohu.com
thanks a lot!
发表于 2003-9-5 19:53:28 | 显示全部楼层
module bidir
clk,
direc, // direction of data;
data
input clk;
input direc;
inout [7:0] data;
wire clk;
wire direc;
wire [7:0] data;
reg [7:0] data_tmp;
reg [7:0] target_reg; // this is the internal register you want to read or write.
assign data = direc?data_tmp:8'hzz;
always@(posedge clk)
begin
  if(direc)
      data_tmp<=target_reg;
  else
      target_reg<=data;
end
endmodule
GMT+8, 2025-12-26 05:19 , Processed in 0.026889 second(s), 7 queries , Gzip On, Redis On.
