查看: 2390|回复: 1
[讨论] verilog use $random, why random seed be force changed?
发表于 2020-10-3 16:31:56 | 显示全部楼层 |阅读模式
//How use $random with seed?
//This is the verilog standard documentdiscription:
//The seed argument controls the numbers that$random returns so that different seeds generate different random streams. Theseed argument shall be an integral variable. The seed value should be assignedto this variable prior to calling $random.
//I did a test.
  1. `ifndef DLY
  2. `define DLY 1
  3. `endif
  4. module tb_top;
  5. reg             clk_bus;
  6. reg             brst_n;
  7. reg [31:0] frame_cnt;
  8. reg [31:0] cnt;
  9. initial begin
  10.     brst_n = 1'b1;
  11.     #1;
  12.     brst_n = 1'b0;
  13.     #100;
  14.     brst_n = 1'b1;
  15.     #1000000000;
  16.     //$finish;
  17. end
  18. initial begin
  19.     clk_bus = 1'b0;
  20.     forever #5 clk_bus = ~clk_bus;
  21. end
  22. always @ (posedge clk_bus or negedge brst_n) begin
  23.     if (~brst_n)
  24.         cnt[31:0] <= #`DLY 'd0;
  25.     else
  26.         cnt[31:0] <= #`DLY cnt + 1;
  27. end
  28. always @ (posedge clk_bus or negedge brst_n) begin
  29.     if (~brst_n)
  30.         frame_cnt[31:0] <= #`DLY 32'd0;
  31.     else if (cnt==1000)
  32.         frame_cnt[31:0] <= #`DLY frame_cnt + 1;
  33. end
  34. integer end_dly;
  35. initial begin
  36.     end_dly = 1;
  37.     while (1) begin
  38.         @(posedge clk_bus);
  39.         if (cnt==1001) begin
  40.             #`DLY end_dly = $random(frame_cnt[7:0]);//luoy why random seed(frame_cnt[7:0]) be force changed?
  41.         end
  42.     end
  43. end
  44. initial begin
  45.         //wait ((in_data_drv.frm_cnt == 1) && (in_data_drv.mb_y_cnt == 90));
  46.         $fsdbDumpfile("tb_top.fsdb");
  47.         $fsdbDumpvars(tb_top, 0);
  48. end
  49. endmodule
  50.
    复制代码
//frame_cnt be force changed from 32'h1 to 32'hce.
 楼主| 发表于 2020-10-5 10:05:37 来自手机 | 显示全部楼层
有人遇到过吗?
GMT+8, 2025-12-25 15:50 , Processed in 0.014459 second(s), 5 queries , Gzip On, Redis On.
