查看: 2214|回复: 2
[求助] dft_drc时报error,新手,咋改
发表于 2020-5-7 16:06:55 | 显示全部楼层 |阅读模式
扫描链插入成功了,想报覆盖率,但是执行dft_drc  -coverage_estimate时报错,同类型的两个error,实在不知道咋改。以下是记录:
design_vision> dft_drc -coverage_estimate
In mode: Internal_scan...
  Design has scan chains in this mode
  Design is scan routed
  Post-DFT DRC enabled
Information: Starting test design rule checking. (TEST-222)
23:49:01 (snpslmd) OUT: "Test-DFTC-TMAX" root@localhost.localdomain
  Loading test protocol
  ...basic checks...
  ...basic sequential cell checks...
  ...checking vector rules...
Error: illegal context (Procedure "multiclock_capture" is missing design clock "data_source" in clock parameters). (V8-1)
Error: illegal context (Procedure "allclock_capture" is missing design clock "data_source" in clock parameters). (V8-2)
Error: illegal context (Procedure "allclock_launch" is missing design clock "data_source" in clock parameters). (V8-3)
Error: illegal context (Procedure "allclock_launch_capture" is missing design clock "data_source" in clock parameters). (V8-4)
Error: miscounted items (Force clocks has 1 values instead of 2 in procedure "multiclock_capture"). (V10-1)
Error: miscounted items (Force clocks has 1 values instead of 2 in procedure "allclock_capture"). (V10-2)
Error: miscounted items (Force clocks has 1 values instead of 2 in procedure "allclock_launch"). (V10-3)
Error: miscounted items (Force clocks has 1 values instead of 2 in procedure "allclock_launch_capture"). (V10-4)
23:49:05 (snpslmd) IN: "Test-DFTC-TMAX" root@localhost.localdomain
Error: Could not perform design rule checking. (TEST-1311)
0
新手求救~~~~
 楼主| 发表于 2020-5-8 09:52:47 | 显示全部楼层
顶顶
发表于 2020-11-13 16:24:18 | 显示全部楼层
请问这个问题楼主解决了吗,我也遇到了
GMT+8, 2025-10-31 08:10 , Processed in 0.014664 second(s), 6 queries , Gzip On, Redis On.
