查看: 3603|回复: 4
[求助] Need Crack of latest Synopsis VCS-MX for Linux
发表于 2020-5-4 16:00:06 | 显示全部楼层 |阅读模式
Do any one have latest crack of VCS-MX for linux. Any latest crack will be fine.
发表于 2020-5-4 16:46:35 | 显示全部楼层
 楼主| 发表于 2020-5-5 17:46:57 | 显示全部楼层
hitzhabc 发表于 2020-5-4 16:46
http://bbs.eetop.cn/thread-878045-1-2.html
or
http://bbs.eetop.cn/forum.php?mod=viewthread&tid=87754 ...
Thank you so much. I also found vcs_mx 2018 version which is compatible with my vivado.
http://bbs.eetop.cn/forum.php?mod=viewthread&tid=876222&page=1#pid10200685
can you please confirm if it is cracked version or I have to do some thing after installing it.
发表于 2020-5-5 18:44:42 | 显示全部楼层
http://bbs ...
如果是2018版本,论坛里有好用的license生成工具。需要利用自己的mac地址生成license就好了。如果是2019版本以及以后的,利用我给你的两个帖子的方法,patch,然后制作license。
发表于 2023-3-4 23:50:17 | 显示全部楼层
thanks
GMT+8, 2025-11-27 23:22 , Processed in 0.017100 second(s), 3 queries , Gzip On, Redis On.
