查看: 2322|回复: 1
[求助] frequency setting in GSR file
发表于 2019-11-29 11:17:57 | 显示全部楼层 |阅读模式
when Redhawk run power calculation, it will use frequencies defined in .timing file.
but we will also set FREQ and FREQ_OF_MISSING_INSTANCE  keyword in GSR for missing instances which are not covered by STA file.
so I want to know the differences of these two Keyword?
it's the priority issues or others?
发表于 2024-7-9 11:38:47 | 显示全部楼层
Do you have the answer? Ask for help
GMT+8, 2025-12-4 00:44 , Processed in 0.012684 second(s), 4 queries , Gzip On, Redis On.
