查看: 2517|回复: 2
[求助] 在用K7芯片例化一个MAC核的例子工程中包一个顶层出现错误,求大神指点
发表于 2019-11-19 16:37:38 | 显示全部楼层 |阅读模式
悬赏100资产未解决
我用K7芯片在ISE生成一个MAC核,例子工程编译没有错误,但是我在例子工程之中包了一层我自己的顶层就出现了这个错误,怎么解决?
Place:1073 - Placer was unable to create RPM[BUFIO_RPMs] for the component U1/U1/trimac_fifo_block/trimac_block/rgmii_interface/bufio_rgmii_rx_clk of type BUFIO for the following reason.
The reason for this issue:
Some of the logic associated with this structure is locked. This should cause the rest of the logic to be locked. A problem was found at site TIEOFF_X0Y214 where we must place BUFIO U1/U1/trimac_fifo_block/trimac_block/rgmii_interface/bufio_rgmii_rx_clk in order to satisfy the relative placement requirements of this logic. It is not legal to place this component in this site.  The following components are part of this structure:
   IOB33V   RGMII_RXC_0<0>
Pack:1654 - The timing-driven placement phase encountered an error.
发表于 2019-11-19 22:01:04 | 显示全部楼层
看看生成工程中constraint有些东西是不是要包到你的工程里
 楼主| 发表于 2019-12-16 09:12:36 | 显示全部楼层
顶一顶
GMT+8, 2025-9-13 13:44 , Processed in 0.013707 second(s), 3 queries , Gzip On, Redis On.
