楼主: 8i8i9o9o
[求助] CDL 转成 Schematic in cadence
发表于 2019-6-27 22:41:38 | 显示全部楼层
8i8i9o9o 发表于 2019-6-27 19:01
试过了, 还是不行
devMap : nfet nch
propMatch := subtype N
propMap := w w l l m m
termMap :  ?  ?  ?
addProp := model nch
:=  前後須空格
devMap : nfet nch  跟devSelect 有何不同??
发表于 2019-6-28 08:52:32 | 显示全部楼层
ni.log和ni.err文件里面怎么提示的错误
发表于 2019-6-28 09:39:05 | 显示全部楼层
不错,看看
 楼主| 发表于 2019-6-29 11:42:01 | 显示全部楼层
ni.log
Reference Libraries...
tsmc18
basic
analogLib
temp
---- Device-mapping enabled ----
1 subckt(s) found in the netlist file.
        Subckt: DFCND4
Created the CV DFCND4->netlist_tmp.
        MOS Instance: MMI30-M_u2
...Searching for a valid mapping in the dev-map file...
        ...did not find a valInitializing from libInit.il for library tsmc18...
   --  tsmcPdkCIW_T-018-CM-SP-012.il
   --  tsmc18_updateCDFs.ile
   --  tsmc18.cxt
   --  tsmcTool2.cxt
Loading Working place Display File '~/projects/analogip/analog/display.drf'
*WARNING* : Not found - D
ated master cellview: mos->symbol in target library temp.
instName->'MMI30-M_u2' is created.
propName->'m'; propVal->'1' is created.
Usage error.
ni.err
PROCESSING INPUT FILE: netlist
ERROR (CDLIN-47): Failed to find the terminal D in the master cell of instance MMI30-M_u2. Provide the
correct master cell.
 楼主| 发表于 2019-7-4 17:12:30 | 显示全部楼层
peterlin2010 发表于 2019-6-27 22:41
devMap : nfet nch
有空格的
GMT+8, 2025-10-4 03:19 , Processed in 0.014077 second(s), 3 queries , Gzip On, Redis On.
