查看: 5182|回复: 2
[求助] 求教,vcs混合仿真,glbl.v文件编译进默认库,为何找不到 ?
发表于 2018-12-26 17:36:29 | 显示全部楼层 |阅读模式
使用默认的库映射:
-- Default workspace (Current dir)
WORK                            > DEFAULT
DEFAULT                         : .
然后执行下面两条命令
[lq@simuhost vcs]$vlogan -full64 -sverilog +v2k -f filelist_verilog.v +incdir+../../../imports +incdir+../../../MIG_OV_PRG.srcs/sources_1/ip/clk_wiz_sys +incdir+../../../MIG_OV_PRG.srcs/sources_1/ip/clk_wiz_hdmi  +define+GLBL ./glbl.v -l verilog.log
[lq@simuhost vcs]$ vcs -full64 -fsdb -top  WORK.sim_tb_top WORK.glbl -l vcs.log -o simv1
Doing common elaboration
                         Chronologic VCS (TM)
         Version H-2013.06_Full64 -- Thu Dec 27 17:42:41 2018
               Copyright (c) 1991-2013 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Error-[TMENF-IL] Top Module/Entity not found
  Top module/entity/config "WORK.sim_tb_top" is not found in library
  "DEFAULT".
  Top module/entity/config "WORK.glbl" is not found in library "DEFAULT".
Error-[NM] No modules defined
  No modules defined in current design file(s).
3 errors
CPU time: .149 seconds to compile
common elaboration failed
哪里用错了 ?
发表于 2019-2-26 20:33:31 | 显示全部楼层
解决了吗
发表于 2019-7-30 14:20:56 | 显示全部楼层
我也遇到这个问题,咋解
GMT+8, 2025-10-8 20:08 , Processed in 0.011657 second(s), 3 queries , Gzip On, Redis On.
