楼主: chudong
关于Power-On-Reset的问题
发表于 2008-11-2 23:21:36 | 显示全部楼层
关键要看你的POR的用途。
检测的电源是从芯片外部提供的,还是经过内部的regulator 过来的。根据它们驱动能力的不同,以及负载电容的大小来确定上点速度。
发表于 2008-11-11 09:13:23 | 显示全部楼层
:lol:lol
发表于 2008-11-17 18:23:48 | 显示全部楼层
the rising time can be very different when drived using normal power supply or power amplifier. design should consider all cases.
发表于 2009-3-5 17:28:58 | 显示全部楼层
牛人还是很多 啊
发表于 2009-3-6 06:40:03 | 显示全部楼层
Pls note that a robust POR should be
(1) correct reset regardless of VDD ramping speed(us, ms, even second)
(2) correst reset and release insensitive to VDD glitch or noise
(3) reset pulse width well controlled vs PVT under the same VDD ramping speed.
(4) No power consumption and independent any other block
Pls also note that  POR is very important especially in compex SOC system.  To design a good POR sometimes is even difficult than you design a ADC or other analog block because as you may know, very few papers talking about POR but millions of paper talking about ADC -
hopefully it helps you and gald to hear about your POR is so much robust.
发表于 2009-3-7 14:31:39 | 显示全部楼层
进来学习一下。。。。
发表于 2009-3-8 23:36:09 | 显示全部楼层
学习一下
发表于 2009-3-9 13:51:13 | 显示全部楼层
原帖由 prof3 于 2009-3-6 06:40 发表
(3) reset pulse width we ...
   Thank you !!!  强人啊
发表于 2009-3-26 20:01:23 | 显示全部楼层
kan kan
发表于 2010-5-15 11:57:14 | 显示全部楼层
不错呀。感觉很难
GMT+8, 2025-12-30 13:04 , Processed in 0.018945 second(s), 3 queries , Gzip On, Redis On.
