查看: 11413|回复: 33
柯明道-overcome latchup failure of a power controller IC
发表于 2007-9-6 17:14:53 | 显示全部楼层 |阅读模式
論文名稱Failure analysis and solutions to overcome latchup failure event of a power controller IC in bulk CMOS technology
期刊S.-H. Chen and Ming-Dou Ker, “On-panel output buffer with offset compensation technique for data driver in LTPS technology,”Microelectronics Reliability, vol. 46, no. 7, pp. 1042-1049, Jul. 2006
摘要        Latchup failure which occurred at only one output pin of a power controller IC product is investigated in this work. The special design requirement of the internal circuits causes the parasitic diode that is inherent between the n-well and p-substrate to be a triggering source of the latchup occurrence in this IC. The parasitic diode of the internal PMOS was easily turned on by an anomalous external signal to trigger the neighbor parasitic Silicon Controlled Rectifier (SCR)
        path which causes latchup event in the CMOS IC product. Some solutions to overcome this latchup failure have been also proposed in this paper.
473_JMR_SHChen_Ker_July_2006.pdf
630.3 KB, 下载次数: 298 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-18 09:21:02 | 显示全部楼层
好东西!
发表于 2009-10-4 19:59:01 | 显示全部楼层
奇怪
這篇在台灣的博碩士論文圖書館竟找不到
只能在這裏抓...
发表于 2009-10-6 22:53:59 | 显示全部楼层
Thanks a lot!
发表于 2010-11-14 21:15:26 | 显示全部楼层
好东西!
发表于 2010-11-15 16:39:16 | 显示全部楼层
nice paper
发表于 2010-11-16 09:54:53 | 显示全部楼层
thanks~~~
发表于 2010-11-18 23:06:28 | 显示全部楼层
thank you ~
发表于 2011-1-21 14:30:01 | 显示全部楼层
回复 1# semico_ljj
发表于 2011-1-21 14:35:02 | 显示全部楼层
回复 9# wangjianping
GMT+8, 2025-12-25 06:15 , Processed in 0.464947 second(s), 7 queries , Gzip On, Redis On.
