查看: 2960|回复: 1
请教一个计数器的问题
发表于 2007-9-3 16:57:40 | 显示全部楼层 |阅读模式
设计一个16位的计数器对CLK1计数,上位机通过STRB对当前的计数值进行锁存,CS为计数器的片选,RD为读选通,读取锁存后的计数值
在QUARTUS中仿真,结果正确,可下载到CPLD后,发现即使CLK1没有输入信号,计数器也在计数,即语句CLK1 'event AND CLK1='1'好像没有起作用,counter1<=counter1+'1';一直在运行
下面是程序,请帮我看看原因在哪,我用的型号是MAXII
library IEEE;
use IEEE.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity counter is
port(
         CS:  in std_logic;
         STROBE:  in std_logic;
         CLK1: in std_logic;
         CLR: in std_logic;
         RD:  in std_logic;
         DATA: out std_logic_vector(15 downto 0)
end counter;
architecture behavior of sixcounter is
    signal counter1: std_logic_vector(15 downto 0):=x"0000";      --计数值
    signal counter1_temp: std_logic_vector(15 downto 0):=x"0000";  --锁存值
begin
    COUNT1: process(CS,CLR,CLK1)                     --计数
           begin
            if(CLR='0' AND CS='0') then
                counter1<=x"0000";
            elsif(CLK1 'event AND CLK1='1') then
                 if(counter1=x"FFFF") then
                     counter1<=x"0000";
                  else  counter1<=counter1+'1';
                 end if;
            end if;
         end process COUNT1;
      STRB: process(CS,STROBE)                       --锁存
             begin
              if(STROBE 'event AND STROBE='1') then
                 if(CS='0') then
                   counter1_temp<=counter1;
                 end if;
              end if;
        end process STRB;
      READDATA: process(CS,RD)                       --读取
             begin
             if(CS='0' AND RD='0') then
               DATA<=counter1_temp(15 downto 0);
              else DATA<="ZZZZZZZZZZZZZZZZ";
             end if;
       end process READDATA;
end behavior;
发表于 2007-9-6 15:26:05 | 显示全部楼层
嗨,我没有CPLD 不知道实际效果会如何
不过在quartus 中仿真没有问题
可能你的硬件设计出现问题了吧?
GMT+8, 2025-12-25 00:59 , Processed in 0.027224 second(s), 8 queries , Gzip On, Redis On.
