查看: 2606|回复: 2
[求助]急盼大虾帮助!
发表于 2004-4-23 15:54:07 | 显示全部楼层 |阅读模式
subtype word is std_logic_vector(data_width - 1 downto 0);
type memory is array(2**adr_width - 1 downto 0)of word;
逻辑综合同步过:
non locally  static bounds are not supported
这是什么原因呀?
发表于 2004-6-3 20:00:28 | 显示全部楼层
[求助]急盼大虾帮助!
你把data-width和adr-width改为实际的数值应该可以吧
发表于 2004-6-18 22:09:17 | 显示全部楼层
[求助]急盼大虾帮助!
both the data_width and adr_width have to be defined as either constants or generics.
When defined as generics, as I remembered, you should use "analyze" and "elaborate" rather than "read" to input your design.
GMT+8, 2025-12-21 14:01 , Processed in 0.019723 second(s), 9 queries , Gzip On, Redis On.
