查看: 4789|回复: 1
[求助] Verdi dumpfile 出错无法正确生成波形
发表于 2018-2-24 19:21:45 | 显示全部楼层 |阅读模式
Verdi dumpfile 出错无法正确生成波形*Verdi3* FSDB: the switch FSDB file size might not match the input size(1024MB) because of perfoe=rmance concerns.
*Verdi3* FSDB:to have the FSDB file size matvh the input size(1024MB),set the FSDB_ENV_PRECISE_AUTOSWITCH enviroment, though the dumping performance might decrease.
报错如上
在脚本中我设置$fsdbAutoSwitchDumpfile(1024,"fsm.fsdb",500),
请问是什么原因????????
发表于 2021-11-12 09:34:11 | 显示全部楼层
解决办法就是,在环境变量中将FSDB_ENV_PRECISE_AUTOSWITCH设为1,
我的环境变量写在.bashrc里面
export FSDB_ENV_PRECISE_AUTOSWITCH=1
GMT+8, 2025-9-13 13:31 , Processed in 0.015660 second(s), 3 queries , Gzip On, Redis On.
