查看: 2947|回复: 0
[求助] 用gds出fram时,抽不出pin
发表于 2018-1-31 14:44:34 | 显示全部楼层 |阅读模式
抽的命令如下: create_macro_fram -library_name $mw_lib -cell_name $mw_cell_name -treat_all_blockage_as_thin_wire -identify_macro_pin_by_pin_text -m9_pin_text_layers 85   ;
Pin text是RDL text层,但是create_macro_fram 选项没有rdl pin text layer的选项,所以用的-m9_pin_text_layers 选项,然后layer number用的是rdl text number
GMT+8, 2025-12-30 22:06 , Processed in 0.014102 second(s), 4 queries , Gzip On, Redis On.
