查看: 13483|回复: 14
[求助] calibre 下做LVS 报错:Different numbers of instances. 求指教
发表于 2017-6-21 16:08:42 | 显示全部楼层 |阅读模式
我在calibre做LVS的时候遇到nets、ports和instance的错误,经处理现在只剩Different numbers of instances.这个主要错误了,但是这么弄都没有解决,下面是我的report,求指教
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         sense.lvs.report
LAYOUT NAME:              /home/LHG/gp/lib/LVS/sense.sp ('sense')
SOURCE NAME:              /home/LHG/gp/sense/ICC/ICC_0301/sense_test0619_derivePG.spi ('sense')
RULE FILE:                /home/LHG/gp/lib/LVS/_LVS_RC_Calibre_015um_HV18V_1P4M_v0.09a_
CREATION TIME:            Wed Jun 21 16:55:04 2017
CURRENT DIRECTORY:        /home/LHG/gp/lib/LVS
USER NAME:                gp
CALIBRE VERSION:          v2011.2_34.26    Wed Jul 6 05:20:56 PDT 2011
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of instances.
  Error:    Connectivity errors.
  Warning:  Ambiguity points were found and resolved arbitrarily.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      sense                         sense
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD"
   LVS GROUND NAME                        "VSS"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       YES
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       YES
   LVS EXPAND UNBALANCED CELLS            YES
   LVS FLATTEN INSIDE CELL                NO
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   LVS SPICE IMPLIED MOS AREA             NO
   // LVS SPICE MULTIPLIER NAME
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE SCALE X PARAMETERS           NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            YES
   SOURCE CASE                            YES
   LVS COMPARE CASE                       NAMES
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     50
   LVS PROPERTY RESOLUTION MAXIMUM        65536
   // LVS SIGNATURE MAXIMUM
   // LVS FILTER UNUSED OPTION
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // Device Type Map
   LVS DEVICE TYPE                        LDDNMOS "nch_hva_mac" [ D=D G=G S=BS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDNMOS "nch_hviah_mac" [ D=D G=G S=BS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDNMOS "nch_hviam_mac" [ D=D G=G S=BS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDNMOS "nch_hvish_16d5_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDNMOS "nch_hvish_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDNMOS "nch_hvism_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nch_hvs_16d5_mac" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nch_hvs_mac" SOURCE LAYOUT
   LVS DEVICE TYPE                        NMOS "nch_hvsm_mac" SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDPMOS "pch_hva_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDPMOS "pch_hvs_16d5_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDPMOS "pch_hvs_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        LDDPMOS "pch_hvsm_mac" [ D=D G=G S=S ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        DIODE "pdddio_hv_3t" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        DIODE "pdio_hv_3t" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   LVS DEVICE TYPE                        RESISTOR "rhvnwhvpw" "rndd" "rnod_m" "rnodrpo_m" "rnodw_m" "rnpo1_dis" "rnpo1rpo_dis"
                                                   "rnpo1w_dis" "rnwod_m" "rpddhvnw_hvpw_4t" "rpod_m" "rpodw_m" "rppo1rpo_dis"
                                                   "rppo1w_dis" [ POS=PLUS NEG=MINUS ]  SOURCE LAYOUT
   // Reduction
   LVS REDUCE SERIES MOS                  NO
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 NO
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           YES
   LVS REDUCE PARALLEL CAPACITORS         YES
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
   LVS REDUCE  pdddio_hv_3t  PARALLEL
   LVS REDUCE  pdio_hv_3t  PARALLEL
   LVS REDUCE  rhvnwhvpw  PARALLEL [ TOLERANCE l 0 ]
   LVS REDUCE  rhvnwhvpw  SERIES PLUS MINUS [ TOLERANCE w 0 ]
   LVS REDUCE  rndd  PARALLEL [ TOLERANCE l 0 ]
   LVS REDUCE  rndd  SERIES PLUS MINUS [ TOLERANCE w 0 ]
   LVS REDUCE  rnod_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnod_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnodrpo_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnodrpo_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnodw_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnodw_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnpo1_dis  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnpo1_dis  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnpo1rpo_dis  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnpo1rpo_dis  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnpo1w_dis  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnpo1w_dis  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rnwod_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rnwod_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rpddhvnw_hvpw_4t  PARALLEL [ TOLERANCE l 0 ]
   LVS REDUCE  rpddhvnw_hvpw_4t  SERIES PLUS MINUS [ TOLERANCE w 0 ]
   LVS REDUCE  rpod_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rpod_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rpodw_m  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rpodw_m  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rppo1rpo_dis  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rppo1rpo_dis  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCE  rppo1w_dis  PARALLEL [ TOLERANCE lr 0 ]
   LVS REDUCE  rppo1w_dis  SERIES PLUS MINUS [ TOLERANCE wr 0 ]
   LVS REDUCTION PRIORITY                 PARALLEL
   LVS SHORT EQUIVALENT NODES             NO
   // Filter
   LVS FILTER  D(pphvnwdnwpsub_dio_iso)  OPEN LAYOUT
   LVS FILTER  D(pphvnwpsub_dio_iso)  OPEN LAYOUT
   LVS FILTER  D(pphvnwpsub_dio_iso_ac)  OPEN LAYOUT
   LVS FILTER  D(pphvpwdnwhvnw_dio_iso)  OPEN LAYOUT
   // Trace Property
   TRACE PROPERTY  mn(nch)  l l 0
   TRACE PROPERTY  mn(nch)  w w 0
   TRACE PROPERTY  mp(pch)  l l 0
   TRACE PROPERTY  mp(pch)  w w 0
   TRACE PROPERTY  q(pdhvnwps10)  a a 0
   TRACE PROPERTY  q(pdhvnwps2)  a a 0
   TRACE PROPERTY  q(pdhvnwps5)  a a 0
   TRACE PROPERTY  q(pdhvnwps8)  a a 0
   TRACE PROPERTY  q(phvnwps10)  a a 0
   TRACE PROPERTY  q(phvnwps2)  a a 0
   TRACE PROPERTY  q(phvnwps5)  a a 0
   TRACE PROPERTY  q(phvnwps8)  a a 0
   TRACE PROPERTY  q(pv)  a a 0
   TRACE PROPERTY  d(dn)  a a 0
   TRACE PROPERTY  d(dp)  a a 0
   TRACE PROPERTY  d(dw)  a a 0
   TRACE PROPERTY  d(hvnwdio_hv)  a a 0
   TRACE PROPERTY  d(ndddio_hv)  a a 0
   TRACE PROPERTY  d(ndio_hv)  a a 0
   TRACE PROPERTY  r(m1)  r r 2
   TRACE PROPERTY  r(m2)  r r 2
   TRACE PROPERTY  r(m3)  r r 2
   TRACE PROPERTY  r(nd)  r r 2
   TRACE PROPERTY  r(ni)  r r 2
   TRACE PROPERTY  r(nr)  r r 2
   TRACE PROPERTY  r(ns)  r r 2
   TRACE PROPERTY  r(pd)  r r 2
   TRACE PROPERTY  r(pi)  r r 2
   TRACE PROPERTY  r(pr)  r r 2
   TRACE PROPERTY  r(ps)  r r 2
   TRACE PROPERTY  r(wo)  r r 2
   TRACE PROPERTY  r(wr)  r r 2
   TRACE PROPERTY  r(m4)  r r 2
   TRACE PROPERTY  nch_hva_mac  w w 0
   TRACE PROPERTY  nch_hva_mac  l l 0
   TRACE PROPERTY  nch_hviah_mac  w w 0
   TRACE PROPERTY  nch_hviah_mac  l l 0
   TRACE PROPERTY  nch_hviam_mac  w w 0
   TRACE PROPERTY  nch_hviam_mac  l l 0
   TRACE PROPERTY  nch_hvish_16d5_mac  w w 0
   TRACE PROPERTY  nch_hvish_16d5_mac  l l 0
   TRACE PROPERTY  nch_hvish_mac  w w 0
   TRACE PROPERTY  nch_hvish_mac  l l 0
   TRACE PROPERTY  nch_hvism_mac  w w 0
   TRACE PROPERTY  nch_hvism_mac  l l 0
   TRACE PROPERTY  nch_hvs_16d5_mac  l l 0
   TRACE PROPERTY  nch_hvs_16d5_mac  w w 0
   TRACE PROPERTY  nch_hvs_mac  l l 0
   TRACE PROPERTY  nch_hvs_mac  w w 0
   TRACE PROPERTY  nch_hvsm_mac  l l 0
   TRACE PROPERTY  nch_hvsm_mac  w w 0
   TRACE PROPERTY  pch_hva_mac  w w 0
   TRACE PROPERTY  pch_hva_mac  l l 0
   TRACE PROPERTY  pch_hvs_16d5_mac  w w 0
   TRACE PROPERTY  pch_hvs_16d5_mac  l l 0
   TRACE PROPERTY  pch_hvs_mac  w w 0
   TRACE PROPERTY  pch_hvs_mac  l l 0
   TRACE PROPERTY  pch_hvsm_mac  w w 0
   TRACE PROPERTY  pch_hvsm_mac  l l 0
   TRACE PROPERTY  pdddio_hv_3t  area area 0
   TRACE PROPERTY  pdio_hv_3t  area area 0
   TRACE PROPERTY  rhvnwhvpw  l l 0
   TRACE PROPERTY  rhvnwhvpw  w w 0
   TRACE PROPERTY  rndd  l l 0
   TRACE PROPERTY  rndd  w w 0
   TRACE PROPERTY  rnod_m  lr lr 0
   TRACE PROPERTY  rnod_m  wr wr 0
   TRACE PROPERTY  rnodrpo_m  lr lr 0
   TRACE PROPERTY  rnodrpo_m  wr wr 0
   TRACE PROPERTY  rnodw_m  lr lr 0
   TRACE PROPERTY  rnodw_m  wr wr 0
   TRACE PROPERTY  rnpo1_dis  lr lr 0
   TRACE PROPERTY  rnpo1_dis  wr wr 0
   TRACE PROPERTY  rnpo1rpo_dis  lr lr 0
   TRACE PROPERTY  rnpo1rpo_dis  wr wr 0
   TRACE PROPERTY  rnpo1w_dis  lr lr 0
   TRACE PROPERTY  rnpo1w_dis  wr wr 0
   TRACE PROPERTY  rnwod_m  lr lr 0
   TRACE PROPERTY  rnwod_m  wr wr 0
   TRACE PROPERTY  rpddhvnw_hvpw_4t  w w 0
   TRACE PROPERTY  rpddhvnw_hvpw_4t  l l 0
   TRACE PROPERTY  rpod_m  lr lr 0
   TRACE PROPERTY  rpod_m  wr wr 0
   TRACE PROPERTY  rpodw_m  lr lr 0
   TRACE PROPERTY  rpodw_m  wr wr 0
   TRACE PROPERTY  rppo1rpo_dis  lr lr 0
   TRACE PROPERTY  rppo1rpo_dis  wr wr 0
   TRACE PROPERTY  rppo1w_dis  lr lr 0
   TRACE PROPERTY  rppo1w_dis  wr wr 0
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         sense
SOURCE CELL NAME:         sense
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             85        85
Nets:           74753     74753
Instances:      69777     69777         MN (4 pins)
                 64145     64145         MP (4 pins)
Total Inst:    133922    133922
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             85        85
Nets:           26251     26251
Instances:        357       357         MN (4 pins)
                  5876      5876         MP (4 pins)
                     1         1         OAI_3_1 (5 pins)
                     1         1         SDW3 (4 pins)
                     2         2         SUP3 (4 pins)
                   212       212         SPDW_2_1 (4 pins)
                     3         3         SPDW_2_1_1 (5 pins)
                  3053      3053         SPDW_2_2 (5 pins)
                    10        10         SPDW_2_2_1 (6 pins)
                   150       150         SPDW_2_2_2 (7 pins)
                     2         2         SPDW_3_2 (6 pins)
                   188       188         SPUP_2_1 (4 pins)
                     1         1         SPUP_2_1_1 (5 pins)
                   163       163         SPUP_2_2 (5 pins)
                   151       151         SPUP_2_2_1 (6 pins)
                     1         1         SPUP_3_2 (6 pins)
                 14890     14890         _invv (4 pins)
                   597       597         _invx2v (4 pins)
                   378       378         _nand2v (5 pins)
                    34        34         _nand3v (6 pins)
                   168       168         _nand4v (7 pins)
                   220       220         _nor2v (5 pins)
                    25        25         _nor3v (6 pins)
                   165       165         _nor4v (7 pins)
                   832       832         _sdw2v (4 pins)
                 11268     11268         _smn3v (5 pins)
                 18071     18071         _smp2v (4 pins)
                     4         4         _smp3v (5 pins)
                   161       161         _xr2v (5 pins)
                     1         1         _xra2v (5 pins)
Total Inst:     56985     56985
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net VDD                                                   VDD
       (_nand2v):sup1                                            ** missing connection **
         X28/X1241/M4(757.825,124.715):b
         X28/X1241/M4(757.825,124.715):d
         X28/X1241/M3(758.485,124.715):b
         X28/X1241/M3(758.485,124.715):s
       ** missing connection **                                  XU13672/M3:b
       ** missing connection **                                  XU13672/M3:s
       (_invx2v):sup1                                            ** unmatched connection **
         X50/X395/M1(1515.955,185.630):b
         X50/X395/M1(1515.955,185.630):s
         X50/X408/M10(1522.685,189.570):b
         X50/X408/M10(1522.685,189.570):s
         X49/X643/M5(1348.975,122.370):b
         X49/X643/M5(1348.975,122.370):s
         X49/X643/M4(1348.315,122.370):b
         X49/X643/M4(1348.315,122.370):d
         X48/X374/M3(1365.475,108.930):b
         X48/X374/M3(1365.475,108.930):s
         X48/X374/M2(1364.815,109.365):b
         X48/X374/M2(1364.815,109.365):d
         X48/X372/M3(1349.635,115.650):b
         X48/X372/M3(1349.635,115.650):s
         X48/X372/M2(1348.975,116.085):b
         X48/X372/M2(1348.975,116.085):d
         X42/X689/M3(1060.765,152.030):b
         X42/X689/M3(1060.765,152.030):s
         X42/X689/M2(1061.425,151.595):b
         X42/X689/M2(1061.425,151.595):d
         X42/X688/M3(1056.145,152.030):b
         X42/X688/M3(1056.145,152.030):s
         X42/X688/M2(1056.805,151.595):b
         X42/X688/M2(1056.805,151.595):d
         X36/X553/M3(983.545,165.470):b
         X36/X553/M3(983.545,165.470):s
         X36/X553/M2(984.205,165.035):b
         X36/X553/M2(984.205,165.035):d
         X36/X552/M3(821.185,158.750):b
         X36/X552/M3(821.185,158.750):s
         X36/X552/M2(821.845,158.315):b
         X36/X552/M2(821.845,158.315):d
         X35/X624/M3(1016.545,152.030):b
         X35/X624/M3(1016.545,152.030):s
         X35/X624/M2(1017.205,151.595):b
         X35/X624/M2(1017.205,151.595):d
         X35/X623/M3(984.655,155.970):b
         X35/X623/M3(984.655,155.970):s
         X35/X623/M2(983.995,156.405):b
         X35/X623/M2(983.995,156.405):d
         X35/X620/M3(936.685,152.030):b
         X35/X620/M3(936.685,152.030):s
         X35/X620/M2(937.345,151.595):b
         X35/X620/M2(937.345,151.595):d
         X35/X619/M3(895.765,145.310):b
         X35/X619/M3(895.765,145.310):s
         X35/X619/M2(896.425,144.875):b
         X35/X619/M2(896.425,144.875):d
         X35/X618/M3(859.465,145.310):b
         X35/X618/M3(859.465,145.310):s
         X35/X618/M2(860.125,144.875):b
         X35/X618/M2(860.125,144.875):d
         X35/X615/M3(776.755,155.970):b
         X35/X615/M3(776.755,155.970):s
         X35/X615/M2(776.095,156.405):b
         X35/X615/M2(776.095,156.405):d
         X28/X1633/M4(567.565,142.530):b
         X28/X1633/M4(567.565,142.530):s
         X28/X1633/M3(566.905,142.965):b
         X28/X1633/M3(566.905,142.965):d
         X28/X1453/M3(764.425,152.030):b
         X28/X1453/M3(764.425,152.030):s
         X28/X1453/M2(765.085,151.595):b
         X28/X1453/M2(765.085,151.595):d
         X28/X1452/M3(729.895,155.970):b
         X28/X1452/M3(729.895,155.970):s
         X28/X1452/M2(729.235,156.405):b
         X28/X1452/M2(729.235,156.405):d
         X28/X1451/M3(688.315,149.250):b
         X28/X1451/M3(688.315,149.250):s
         X28/X1451/M2(687.655,149.685):b
         X28/X1451/M2(687.655,149.685):d
         X28/X1450/M3(660.145,152.030):b
         X28/X1450/M3(660.145,152.030):s
         X28/X1450/M2(660.805,151.595):b
         X28/X1450/M2(660.805,151.595):d
         X28/X1448/M3(611.755,155.970):b
         X28/X1448/M3(611.755,155.970):s
         X28/X1448/M2(611.095,156.405):b
         X28/X1448/M2(611.095,156.405):d
         X28/X1447/M3(596.125,152.030):b
         X28/X1447/M3(596.125,152.030):s
         X28/X1447/M2(596.785,151.595):b
         X28/X1447/M2(596.785,151.595):d
         X28/X1446/M3(595.255,142.530):b
         X28/X1446/M3(595.255,142.530):s
         X28/X1446/M2(594.595,142.965):b
         X28/X1446/M2(594.595,142.965):d
         X28/X1445/M3(593.275,142.530):b
         X28/X1445/M3(593.275,142.530):s
         X28/X1445/M2(592.615,142.965):b
         X28/X1445/M2(592.615,142.965):d
         X28/X1443/M3(582.715,155.970):b
         X28/X1443/M3(582.715,155.970):s
         X28/X1443/M2(582.055,156.405):b
         X28/X1443/M2(582.055,156.405):d
         X28/X1440/M3(533.875,155.970):b
         X28/X1440/M3(533.875,155.970):s
         X28/X1440/M2(533.215,156.405):b
         X28/X1440/M2(533.215,156.405):d
         X28/X1439/M3(525.505,152.030):b
         X28/X1439/M3(525.505,152.030):s
         X28/X1439/M2(526.165,151.595):b
         X28/X1439/M2(526.165,151.595):d
         X28/X1438/M3(503.065,142.530):b
         X28/X1438/M3(503.065,142.530):s
         X28/X1438/M2(503.725,142.965):b
         X28/X1438/M2(503.725,142.965):d
         X28/X1435/M3(487.225,138.590):b
         X28/X1435/M3(487.225,138.590):s
         X28/X1435/M2(487.885,138.155):b
         X28/X1435/M2(487.885,138.155):d
         X28/X1434/M3(459.955,142.530):b
         X28/X1434/M3(459.955,142.530):s
         X28/X1434/M2(459.295,142.965):b
         X28/X1434/M2(459.295,142.965):d
         X28/X1433/M3(428.935,142.530):b
         X28/X1433/M3(428.935,142.530):s
         X28/X1433/M2(428.275,142.965):b
         X28/X1433/M2(428.275,142.965):d
         X28/X1432/M3(386.245,145.310):b
         X28/X1432/M3(386.245,145.310):s
         X28/X1432/M2(386.905,144.875):b
         X28/X1432/M2(386.905,144.875):d
         X28/X1431/M3(384.265,145.310):b
         X28/X1431/M3(384.265,145.310):s
         X28/X1431/M2(384.925,144.875):b
         X28/X1431/M2(384.925,144.875):d
         X28/X1430/M3(318.925,145.310):b
         X28/X1430/M3(318.925,145.310):s
         X28/X1430/M2(319.585,144.875):b
         X28/X1430/M2(319.585,144.875):d
         X28/X1429/M3(315.625,145.310):b
         X28/X1429/M3(315.625,145.310):s
         X28/X1429/M2(316.285,144.875):b
         X28/X1429/M2(316.285,144.875):d
         X28/X1427/M3(266.575,142.530):b
         X28/X1427/M3(266.575,142.530):s
         X28/X1427/M2(265.915,142.965):b
         X28/X1427/M2(265.915,142.965):d
         X28/X1424/M3(229.615,142.530):b
         X28/X1424/M3(229.615,142.530):s
         X28/X1424/M2(228.955,142.965):b
         X28/X1424/M2(228.955,142.965):d
         X28/X1419/M3(171.535,142.530):b
         X28/X1419/M3(171.535,142.530):s
         X28/X1419/M2(170.875,142.965):b
         X28/X1419/M2(170.875,142.965):d
         X28/X1418/M3(168.445,145.310):b
         X28/X1418/M3(168.445,145.310):s
         X28/X1418/M2(169.105,144.875):b
         X28/X1418/M2(169.105,144.875):d
         X28/X1416/M3(138.745,142.530):b
         X28/X1416/M3(138.745,142.530):s
         X28/X1416/M2(139.405,142.965):b
         X28/X1416/M2(139.405,142.965):d
         X28/X1415/M3(136.765,142.530):b
         X28/X1415/M3(136.765,142.530):s
         X28/X1415/M2(137.425,142.965):b
         X28/X1415/M2(137.425,142.965):d
         X28/X609/M1(146.455,135.810):b
         X28/X609/M1(146.455,135.810):s
         X28/X753/M31(146.635,131.855):b
         X28/X753/M31(146.635,131.855):s
         X28/X604/M1(114.115,135.810):b
         X28/X604/M1(114.115,135.810):s
         X28/X742/M31(112.825,135.825):b
         X28/X742/M31(112.825,135.825):s
         X27/X971/M5(729.415,116.085):b
         X27/X971/M5(729.415,116.085):s
         X27/X547/M31(734.545,118.415):b
         X27/X547/M31(734.545,118.415):s
         X27/X409/M1(147.775,108.930):b
         X27/X409/M1(147.775,108.930):s
         X27/X503/M31(140.545,102.225):b
         X27/X503/M31(140.545,102.225):s
         X25/X230/M1(741.115,75.330):b
         X25/X230/M1(741.115,75.330):s
         X25/X236/M10(737.285,75.330):b
         X25/X236/M10(737.285,75.330):s
         X28/X606/M1(130.615,122.370):b
         X28/X606/M1(130.615,122.370):s
         X27/X501/M31(129.325,115.665):b
         X27/X501/M31(129.325,115.665):s
         X27/X405/M1(111.475,118.430):b
         X27/X405/M1(111.475,118.430):s
         X28/X743/M31(103.075,122.385):b
         X28/X743/M31(103.075,122.385):s
  2    Net VSS                                                   VSS
       (_nand2v):sup2                                            ** missing connection **
         X28/X1241/M1(757.825,126.620):b
         X28/X1241/M0(758.485,126.620):b
         X28/X1241/M0(758.485,126.620):d
       ** missing connection **                                  XU12510/M0:b
       ** missing connection **                                  XU12510/M0:d
       ** missing connection **                                  XU12511/M0:b
       ** missing connection **                                  XU12511/M0:d
       ** missing connection **                                  XU12512/M0:b
       ** missing connection **                                  XU12512/M0:d
       ** missing connection **                                  XU12513/M0:b
       ** missing connection **                                  XU12513/M0:d
       ** missing connection **                                  XU12515/M0:b
       ** missing connection **                                  XU12515/M0:d
       ** missing connection **                                  XU12517/M0:b
       ** missing connection **                                  XU12517/M0:d
       ** missing connection **                                  XU12519/M0:b
       ** missing connection **                                  XU12519/M0:d
       ** missing connection **                                  XU12520/M0:b
       ** missing connection **                                  XU12520/M0:d
       ** missing connection **                                  XU12523/M0:b
       ** missing connection **                                  XU12523/M0:d
       ** missing connection **                                  XU12524/M0:b
       ** missing connection **                                  XU12524/M0:d
       ** missing connection **                                  XU12516/M0:b
       ** missing connection **                                  XU12516/M0:d
       ** missing connection **                                  XU12518/M0:b
       ** missing connection **                                  XU12518/M0:d
       ** missing connection **                                  XU12521/M0:b
       ** missing connection **                                  XU12521/M0:d
       ** missing connection **                                  XU12522/M0:b
       ** missing connection **                                  XU12522/M0:d
       ** missing connection **                                  XU12514/M0:b
       ** missing connection **                                  XU12514/M0:d
       (_invx2v):sup2                                            ** unmatched connection **
         X50/X395/M0(1515.955,187.100):b
         X50/X395/M0(1515.955,187.100):s
         X50/X408/M1(1522.685,188.100):b
         X50/X408/M1(1522.685,188.100):s
         X49/X643/M1(1348.975,120.820):b
         X49/X643/M1(1348.975,120.820):s
         X49/X643/M0(1348.315,120.820):b
         X49/X643/M0(1348.315,120.820):d
         X48/X374/M1(1365.475,107.380):b
         X48/X374/M1(1365.475,107.380):s
         X48/X374/M0(1364.815,107.380):b
         X48/X374/M0(1364.815,107.380):d
         X48/X372/M1(1349.635,114.100):b
         X48/X372/M1(1349.635,114.100):s
         X48/X372/M0(1348.975,114.100):b
         X48/X372/M0(1348.975,114.100):d
         X42/X689/M1(1060.765,153.580):b
         X42/X689/M1(1060.765,153.580):s
         X42/X689/M0(1061.425,153.580):b
         X42/X689/M0(1061.425,153.580):d
         X42/X688/M1(1056.145,153.580):b
         X42/X688/M1(1056.145,153.580):s
         X42/X688/M0(1056.805,153.580):b
         X42/X688/M0(1056.805,153.580):d
         X36/X553/M1(983.545,167.020):b
         X36/X553/M1(983.545,167.020):s
         X36/X553/M0(984.205,167.020):b
         X36/X553/M0(984.205,167.020):d
         X36/X552/M1(821.185,160.300):b
         X36/X552/M1(821.185,160.300):s
         X36/X552/M0(821.845,160.300):b
         X36/X552/M0(821.845,160.300):d
         X35/X624/M1(1016.545,153.580):b
         X35/X624/M1(1016.545,153.580):s
         X35/X624/M0(1017.205,153.580):b
         X35/X624/M0(1017.205,153.580):d
         X35/X623/M1(984.655,154.420):b
         X35/X623/M1(984.655,154.420):s
         X35/X623/M0(983.995,154.420):b
         X35/X623/M0(983.995,154.420):d
         X35/X620/M1(936.685,153.580):b
         X35/X620/M1(936.685,153.580):s
         X35/X620/M0(937.345,153.580):b
         X35/X620/M0(937.345,153.580):d
         X35/X619/M1(895.765,146.860):b
         X35/X619/M1(895.765,146.860):s
         X35/X619/M0(896.425,146.860):b
         X35/X619/M0(896.425,146.860):d
         X35/X618/M1(859.465,146.860):b
         X35/X618/M1(859.465,146.860):s
         X35/X618/M0(860.125,146.860):b
         X35/X618/M0(860.125,146.860):d
         X35/X615/M1(776.755,154.420):b
         X35/X615/M1(776.755,154.420):s
         X35/X615/M0(776.095,154.420):b
         X35/X615/M0(776.095,154.420):d
         X28/X1633/M1(567.565,140.980):b
         X28/X1633/M1(567.565,140.980):s
         X28/X1633/M0(566.905,140.980):b
         X28/X1633/M0(566.905,140.980):d
         X28/X1453/M1(764.425,153.580):b
         X28/X1453/M1(764.425,153.580):s
         X28/X1453/M0(765.085,153.580):b
         X28/X1453/M0(765.085,153.580):d
         X28/X1452/M1(729.895,154.420):b
         X28/X1452/M1(729.895,154.420):s
         X28/X1452/M0(729.235,154.420):b
         X28/X1452/M0(729.235,154.420):d
         X28/X1451/M1(688.315,147.700):b
         X28/X1451/M1(688.315,147.700):s
         X28/X1451/M0(687.655,147.700):b
         X28/X1451/M0(687.655,147.700):d
         X28/X1450/M1(660.145,153.580):b
         X28/X1450/M1(660.145,153.580):s
         X28/X1450/M0(660.805,153.580):b
         X28/X1450/M0(660.805,153.580):d
  3    Net OUT[3]                                                OUT[3]
       (SPUP_2_1):input                                          ** missing connection **
         X33/X469/M5(826.255,84.815):g
       (_sdw2v):in2                                              ** missing connection **
         X33/X469/M2(826.255,86.455):g
       ** missing connection **                                  (SPUP_2_1):input
        XU12522/M3:g
       ** missing connection **                                  XU12522/M0:g
  4    Net OUT[2]                                                OUT[2]
         X33/X467/M5(785.335,91.535):g
         X33/X467/M2(785.335,93.175):g
        XU12523/M3:g
       ** missing connection **                                  XU12523/M0:g
  5    Net SHL                                                   SHL
       (_invv):in                                                ** missing connection **
         X44/X566/M0(1178.035,220.440):g
         X44/X566/M6(1178.035,219.230):g
         X44/X568/M0(1200.685,207.000):g
         X44/X568/M6(1200.685,205.790):g
       ** missing connection **                                  (_nor2v):in1
        XTX_STB2_tri/M3:g
        XTX_STB2_tri/M9:g
        Xcalib2_tri/M3:g
        Xcalib2_tri/M9:g
  6    Net OUT[13]                                               OUT[13]
         X26/X1035/M5(693.145,88.785):g
         X26/X1035/M2(693.145,87.145):g
        XU12512/M3:g
       ** missing connection **                                  XU12512/M0:g
  7    Net OUT[15]                                               OUT[15]
         X34/X365/M5(867.385,102.225):g
       (_sdw2v):in1                                              ** missing connection **
         X34/X365/M2(867.385,100.585):g
        XU12510/M3:g
       ** missing connection **                                  XU12510/M0:g
  8    Net OUT[14]                                               OUT[14]
         X42/X686/M5(1137.775,131.855):g
         X42/X686/M2(1137.775,133.495):g
        XU12511/M3:g
       ** missing connection **                                  XU12511/M0:g
  9    Net OUT[1]                                                OUT[1]
         X27/X862/M5(101.125,108.945):g
         X27/X862/M2(101.125,107.305):g
        XU12524/M3:g
       ** missing connection **                                  XU12524/M0:g
10    Net OUT[8]                                                OUT[8]
         X26/X1034/M5(462.145,98.255):g
         X26/X1034/M2(462.145,99.895):g
        XU12517/M3:g
       ** missing connection **                                  XU12517/M0:g
11    Net SEN_EN                                                SEN_EN
       (SPDW_2_1):input                                          ** missing connection **
         X26/M7(740.485,99.140):g
       (_smp2v):in2                                              ** missing connection **
         X26/M22(740.485,97.240):g
       ** missing connection **                                  (SPDW_2_1):input
        XU13670/M1:g
       ** missing connection **                                  XU13670/M5:g
12    Net OUT[4]                                                OUT[4]
         X27/X863/M5(534.745,111.695):g
         X27/X863/M2(534.745,113.335):g
        XU12521/M3:g
       ** missing connection **                                  XU12521/M0:g
13    Net OUT[5]                                                OUT[5]
         X27/X864/M5(682.585,104.975):g
         X27/X864/M2(682.585,106.615):g
        XU12520/M3:g
       ** missing connection **                                  XU12520/M0:g
14    Net OUT[6]                                                OUT[6]
         X29/X1229/M5(700.405,178.895):g
         X29/X1229/M2(700.405,180.535):g
        XU12519/M3:g
       ** missing connection **                                  XU12519/M0:g
15    Net OUT[7]                                                OUT[7]
         X34/X366/M5(877.735,118.415):g
         X34/X366/M2(877.735,120.055):g
        XU12518/M3:g
       ** missing connection **                                  XU12518/M0:g
16    Net OUT[11]                                               OUT[11]
         X35/X610/M5(950.995,131.855):g
         X35/X610/M2(950.995,133.495):g
        XU12514/M3:g
       ** missing connection **                                  XU12514/M0:g
17    Net OUT[9]                                                OUT[9]
         X33/X468/M5(793.915,91.535):g
         X33/X468/M2(793.915,93.175):g
        XU12516/M3:g
       ** missing connection **                                  XU12516/M0:g
18    Net OUT[10]                                               OUT[10]
         X28/X1332/M5(703.705,145.295):g
         X28/X1332/M2(703.705,146.935):g
        XU12515/M3:g
       ** missing connection **                                  XU12515/M0:g
19    Net OUT[12]                                               OUT[12]
         X35/X609/M5(778.945,129.105):g
         X35/X609/M2(778.945,127.465):g
        XU12513/M3:g
       ** missing connection **                                  XU12513/M0:g
20    Net 400                                                   N935
       (_nand2v):in1                                             ** missing connection **
         X25/X185/M5(84.625,75.765):g
         X25/X185/M0(84.625,73.860):g
        XU13195/M3:g
       ** missing connection **                                  (_smp2v):in1
        XU13195/M8:g
21    Net 402                                                   n2720
         X26/X395/M3(103.735,80.580):g
       (_invv)ut                                               ** missing connection **
         X25/X3/M16(102.265,73.015):d
         X25/X3/M31(102.265,71.375):d
       (_smp2v):in1                                              ** missing connection **
         X26/X395/M8(103.735,82.050):g
       ** missing connection **                                  (_nand2v):in1
        XU13249/M5:g
        XU13249/M0:g
       ** missing connection **                                  (_invv)ut
        Xdata_ch7_reg_7_/M16:d
        Xdata_ch7_reg_7_/M31:d
       (SPDW_2_2):input                                          ** unmatched connection **
         X26/X627/M1(112.135,87.300):g
       (_smp2v):in2                                              ** unmatched connection **
         X26/X627/M5(112.135,88.785):g
       ** unmatched connection **                                (SPDW_2_2):input
        XU14768/M2:g
       ** unmatched connection **                                (_smp2v):in1
        XU14768/M6:g
22    Net 403                                                   N934
         X26/X395/M5(105.745,82.485):g
         X26/X395/M0(105.745,80.580):g
        XU13196/M3:g
        XU13196/M8:g
23    Net 405                                                   n2719
         X26/X396/M3(118.765,80.580):g
         X26/X37/M16(114.145,79.735):d
         X26/X37/M31(114.145,78.095):d
         X26/X396/M8(118.765,82.050):g
        XU13248/M5:g
        XU13248/M0:g
       ** missing connection **                                  (_invv):out
        Xdata_ch7_reg_8_/M16:d
        Xdata_ch7_reg_8_/M31:d
         X27/X747/X1/M1(118.735,100.740):g
         X27/X747/X1/M5(118.735,102.225):g
        XU15788/M2:g
        XU15788/M6:g
24    Net 406                                                   N908
         X26/X396/M5(116.755,82.485):g
         X26/X396/M0(116.755,80.580):g
        XU13206/M3:g
        XU13206/M8:g
25    Net 414                                                   n2718
         X26/X398/M3(141.205,80.580):g
       (_invv):out                                               ** missing connection **
         X25/X4/M16(132.775,73.015):d
         X25/X4/M31(132.775,71.375):d
         X26/X398/M8(141.205,82.050):g
        XU13246/M5:g
        XU13246/M0:g
        Xdata_ch7_reg_9_/M16:d
        Xdata_ch7_reg_9_/M31:d
         X26/X840/X1/M5(142.495,84.815):g
        XU15789/M6:g
26    Net 412                                                   N803
         X26/X398/M5(139.195,82.485):g
         X26/X398/M0(139.195,80.580):g
        XU13246/M3:g
        XU13246/M8:g
27    Net 83                                                    n2671
         X25/X186/M3(588.685,73.860):g
         X25/X186/M8(588.685,75.330):g
        XU13195/M5:g
        XU13195/M0:g
       (_invv):out                                               ** unmatched connection **
         X25/X12/M16(603.205,73.015):d
         X25/X12/M31(603.205,71.375):d
       (_invv):in                                                ** unmatched connection **
         X25/X226/M0(586.225,72.860):g
         X25/X226/M1(586.225,71.390):g
         X47/X340/M5(1376.035,78.095):g
       ** unmatched connection **                                (_invv):in
        XU13863/M0:g
        XU13863/M1:g
       ** unmatched connection **                                (_invv):out
        Xdata_ch12_reg_6_/M16:d
        Xdata_ch12_reg_6_/M31:d
        XU15752/M6:g
28    Net 490                                                   N936
         X25/X186/M5(586.675,75.765):g
         X25/X186/M0(586.675,73.860):g
        XU13194/M3:g
        XU13194/M8:g
29    Net 494                                                   n9504
         X26/X405/M4(617.725,93.020):g
         X26/X404/M4(593.455,86.300):g
         X26/X403/M4(594.625,87.300):g
         X26/X402/M4(584.215,93.020):g
         X26/X401/M4(578.935,93.020):g
         X26/X400/M4(576.955,86.300):g
         X26/X399/M4(572.335,80.580):g
         X25/X186/M4(589.345,73.860):g
         X25/X188/M4(619.045,73.860):g
         X25/X187/M4(611.125,73.860):g
         X25/X186/M9(589.345,75.330):g
         X26/X405/M9(617.725,91.550):g
         X26/X404/M9(593.455,84.830):g
         X26/X403/M9(594.625,88.770):g
         X26/X402/M9(584.215,91.550):g
         X26/X401/M9(578.935,91.550):g
         X26/X400/M9(576.955,84.830):g
         X26/X399/M9(572.335,82.050):g
         X25/X188/M9(619.045,75.330):g
         X25/X187/M9(611.125,75.330):g
       X26/X1035/M0(694.465,87.145):s                            ** missing connection **
       ** missing connection **                                  (_nand2v):in2
        XU13191/M6:g
        XU13191/M1:g
        XU13195/M6:g
        XU13195/M1:g
        XU13194/M6:g
        XU13194/M1:g
        XU13193/M6:g
        XU13193/M1:g
        XU13198/M6:g
        XU13198/M1:g
        XU13199/M6:g
        XU13199/M1:g
        XU13200/M6:g
        XU13200/M1:g
        XU13197/M6:g
        XU13197/M1:g
        XU13196/M6:g
        XU13196/M1:g
        XU13201/M6:g
        XU13201/M1:g
       ** missing connection **                                  XU12512/M0:s
       (_nand2v):in2                                             ** unmatched connection **
         X26/X929/M4(588.865,91.115):g
         X26/X929/M1(588.865,93.020):g
       (_sdw2v):out1                                             ** unmatched connection **
         X26/X1035/M2(693.145,87.145):s
       ** unmatched connection **                                (_nand2v):in1
        XU11217/M3:g
        XU11217/M0:g
       ** unmatched connection **                                (_sdw2v):out1
        XU12512/M2:s
30    Net 499                                                   N933
         X25/X187/M5(608.455,75.765):g
         X25/X187/M0(608.455,73.860):g
        XU13197/M3:g
        XU13197/M8:g
31    Net 501                                                   N802
         X25/X188/M5(616.375,75.765):g
         X25/X188/M0(616.375,73.860):g
        XU13248/M3:g
        XU13248/M8:g
32    Net 517                                                   n11975
         X26/X407/M4(716.875,79.580):g
         X26/X407/M9(716.875,78.110):g
        XU11282/M6:g
        XU11282/M1:g
       (_nand3v):in2                                             ** unmatched connection **
         X26/X1058/M4(714.715,78.110):g
         X26/X1058/M1(714.715,79.580):g
       ** unmatched connection **                                (_nand3v):in2
        XU13727/M4:g
        XU13727/M1:g
33    Net 520                                                   add_251_carry[2]
         X26/X549/M1(726.725,79.580):d
         X26/X549/M10(726.725,78.110):d
        XU8430/M0:s
        XU8430/M9:s
34    Net 522                                                   n11973
         X26/X409/M4(734.035,79.580):g
         X26/X409/M9(734.035,78.110):g
        XU11283/M6:g
        XU11283/M1:g
35    Net 523                                                   N689
         X26/X409/M5(736.705,77.675):g
         X26/X409/M0(736.705,79.580):g
        XU13297/M3:g
        XU13297/M8:g
36    Net 526                                                   n9474
         X26/X1036/M4(745.945,78.095):g
       (_invx2v):out                                             ** missing connection **
         X25/X230/M0(741.115,73.860):d
         X25/X230/M1(741.115,75.330):d
         X26/X1036/M1(745.945,79.735):g
       ** missing connection **                                  (SPUP_2_1):output
        XU15797/M4:d
        XU15797/M5:s
       ** missing connection **                                  (_sdw2v):out1
        XU15797/M2:s
       ** missing connection **                                  XU15797/M0:s
37    Net 525                                                   n11974
       (SPUP_2_1):output                                         ** missing connection **
         X26/X1036/M4(745.945,78.095):d
         X26/X1036/M5(745.285,78.095):s
       (_sdw2v):out1                                             ** missing connection **
         X26/X1036/M2(745.285,79.735):s
       X26/X1036/M0(746.605,79.735):s                            ** missing connection **
        XU15797/M4:g
       ** missing connection **                                  (_invx2v):out
        XU15798/M0:d
        XU15798/M1:d
       ** missing connection **                                  (_sdw2v):in1
        XU15797/M1:g
         X25/X294/M6(744.415,75.330):g
        XU15796/M5:g
38    Net 680                                                   n9455
       (_nand2v):in2                                             ** missing connection **
         X27/X344/M6(748.585,102.645):g
         X27/X344/M1(748.590,100.740):g
        XU13664/M4:g
       ** missing connection **                                  (_smp2v):in2
        XU13664/M9:g
39    Net 678                                                   n9453
         X27/X344/M3(747.235,100.740):g
         X27/X344/M8(747.235,102.210):g
        XU13664/M5:g
        XU13664/M0:g
       (_nor2v):out                                              ** unmatched connection **
         X27/X971/M1(730.105,114.040):s
         X27/X971/M0(730.765,114.040):d
         X27/X971/M4(730.105,115.650):d
         X26/X535/M0(752.335,99.740):g
         X26/X535/M1(752.335,98.270):g
       ** unmatched connection **                                (_nor2v):out
        XU13709/M1:s
        XU13709/M0:d
        XU13709/M4:d
        XU11295/M0:g
        XU11295/M1:g
40    Net 679                                                   n11094
         X26/X1054/M0(748.585,94.020):g
         X26/X1055/M1(749.245,87.300):g
       X26/X1054/M3(748.585,95.505):g                            ** missing connection **
        XU13669/M2:g
        XU13672/M0:g
        XU13669/M5:g
       ** missing connection **                                  XU13672/M3:g
         X26/X1056/M5(752.545,95.505):g
       (_smp2v):in1                                              ** unmatched connection **
         X26/X1055/M4(749.245,88.785):g
        XU13673/M4:g
41    Net 535                                                   n2788
         X27/X334/M3(72.565,107.460):g
         X27/X334/M8(72.565,108.930):g
        XU13323/M5:g
        XU13323/M0:g
         X26/X33/M16(82.465,99.895):d
         X26/X33/M31(82.465,98.255):d
         X27/X782/X1/X1/M5(149.095,102.225):g
        Xdata_ch0_reg_9_/M16:d
        Xdata_ch0_reg_9_/M31:d
        XU14018/M6:g
42    Net 415                                                   n11061
         X42/X668/M3(1133.365,151.595):g
         X42/X668/M0(1133.365,153.500):g
         X26/X1034/M1(462.805,99.895):g
         X42/X686/M1(1137.115,133.495):g
         X33/X468/M1(793.255,93.175):g
         X34/X365/M1(868.045,100.585):g
         X35/X610/M1(950.335,133.495):g
         X27/X864/M1(683.245,106.615):g
        XU11219/M4:g
        XU11219/M1:g
       (_nand2v):in1                                             ** unmatched connection **
         X26/X928/M3(149.965,84.395):g
         X26/X928/M0(149.965,86.300):g
         X33/X460/M3(842.305,97.835):g
         X33/X460/M0(842.305,99.740):g
         X27/X827/M3(712.735,102.645):g
         X27/X827/M0(712.735,100.740):g
         X49/X580/M3(1516.615,156.405):g
         X49/X580/M0(1516.615,154.500):g
       (_sdw2v):in1                                              ** unmatched connection **
         X33/X467/M1(784.675,93.175):g
       ** unmatched connection **                                (_nand2v):in2
        XU11222/M4:g
        XU11222/M1:g
        XU11225/M4:g
        XU11225/M1:g
        XU11228/M4:g
        XU11228/M1:g
        XU11216/M4:g
        XU11216/M1:g
       ** unmatched connection **                                (_sdw2v):in1
        XU12516/M1:g
        XU12523/M1:g
        XU12520/M1:g
        XU12514/M1:g
        XU12517/M1:g
        XU12510/M1:g
        XU12511/M1:g
43    Net 2995                                                  n2670
         X26/X400/M3(577.615,86.300):g
         X26/X400/M8(577.615,84.830):g
        XU13194/M5:g
        XU13194/M0:g
         X26/X87/M16(562.435,86.455):d
         X26/X87/M31(562.435,84.815):d
         X26/X946/X1/M0(573.475,87.300):g
         X26/X946/X1/M1(573.475,88.770):g
         X27/X588/M5(542.665,118.415):g
        XU13878/M0:g
        XU13878/M1:g
        Xdata_ch12_reg_7_/M16:d
        Xdata_ch12_reg_7_/M31:d
        XU15753/M6:g
44    Net 2998                                                  n2672
         X26/X401/M3(579.595,93.020):g
         X26/X401/M8(579.595,91.550):g
        XU13196/M5:g
        XU13196/M0:g
         X26/X88/M16(586.045,87.145):d
         X26/X88/M31(586.045,88.785):d
         X26/X947/X1/M0(586.675,86.300):g
         X26/X947/X1/M1(586.675,84.830):g
         X27/X823/X1/M5(584.905,115.665):g
        XU13848/M0:g
        XU13848/M1:g
        Xdata_ch12_reg_5_/M16:d
        Xdata_ch12_reg_5_/M31:d
        XU14624/M6:g
45    Net 670                                                   N667
         X26/X406/M5(714.055,97.835):g
         X26/X406/M0(714.055,99.740):g
        XU13303/M3:g
        XU13303/M8:g
46    Net 677                                                   n9454
         X27/X344/M4(746.575,100.740):g
         X27/X344/M9(746.575,102.210):g
        XU13664/M6:g
        XU13664/M1:g
47    Net 88                                                    n12907
         X47/X212/M4(1343.875,87.300):g
         X47/X212/M9(1343.875,88.770):g
        XU13732/M6:g
        XU13732/M1:g
48    Net 2478                                                  n11283
       X26/X1036/M0(746.605,79.735):g                            ** missing connection **
       ** missing connection **                                  (_sdw2v):in2
        XU15797/M2:g
       (SPUP_2_1):input                                          ** unmatched connection **
         X26/X1036/M3(746.605,78.095):g
         X33/X299/M0(860.125,93.020):d
         X33/X299/M1(860.125,91.550):d
       ** unmatched connection **                                (SPUP_2_1):input
        XU15797/M5:g
        XU11325/M0:d
        XU11325/M1:d
49    Net 2480                                                  n11284
       (SPDW_2_1_1):input                                        ** missing connection **
         X26/X1070/M0(759.805,87.300):g
       X26/X1070/M4(759.805,88.770):g                            ** missing connection **
       ** missing connection **                                  (SPDW_2_1_1):input
        XU13713/M3:g
        XU13713/M7:g
         X26/X535/M0(752.335,99.740):d
         X26/X535/M1(752.335,98.270):d
        XU11295/M0:d
        XU11295/M1:d
50    Net 2482                                                  n9471
         X26/X1056/M1(753.205,94.020):g
         X26/X1070/M2(758.485,87.300):g
         X26/X1070/M6(758.485,88.770):g
         X26/X1056/M4(753.205,95.505):g
        XU13673/M0:g
        XU13713/M1:g
       ** missing connection **                                  XU13673/M3:g
       ** missing connection **                                  XU13713/M5:g
       (_nand2v):out                                             ** unmatched connection **
         X40/X561/M2(1212.355,88.785):d
         X40/X561/M3(1213.015,88.785):s
         X40/X561/M0(1212.355,87.145):s
       ** unmatched connection **                                (_nand2v):out
        XU11323/M3:s
        XU11323/M2:d
        XU11323/M1:s
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:              85         85            0            0
   Nets:            20896      20896         5355         5355
   Instances:         337        337           20           20    MN(NCH)
                     5067       5067          809          809    MP(PCH)
                        1          1            0            0    OAI_3_1
                        1          1            0            0    SDW3
                        2          2            0            0    SUP3
                       26         26          186          186    SPDW_2_1
                        1          1            2            2    SPDW_2_1_1
                     2888       2888          165          165    SPDW_2_2
                       10         10            0            0    SPDW_2_2_1
                      150        150            0            0    SPDW_2_2_2
                        2          2            0            0    SPDW_3_2
                      186        186            2            2    SPUP_2_1
                        1          1            0            0    SPUP_2_1_1
                      163        163            0            0    SPUP_2_2
                      151        151            0            0    SPUP_2_2_1
                        1          1            0            0    SPUP_3_2
                    13996      13996          894          894    _invv
                      550        550           47           47    _invx2v
                      184        184          194          194    _nand2v
                       32         32            2            2    _nand3v
                      168        168            0            0    _nand4v
                      217        217            3            3    _nor2v
                       25         25            0            0    _nor3v
                      165        165            0            0    _nor4v
                      812        812           20           20    _sdw2v
                    10596      10596          672          672    _smn3v
                    17218      17218          853          853    _smp2v
                        4          4            0            0    _smp3v
                      145        145           16           16    _xr2v
                        1          1            0            0    _xra2v
   Total Inst:      53100      53100         3885         3885
o Statistics:
   1406 layout mos transistors were reduced to 352.
     1054 mos transistors were deleted by parallel reduction.
   1406 source mos transistors were reduced to 352.
   53 nets and 172 instances were matched arbitrarily.
o Initial Correspondence Points:
   Ports:        VDD VSS OUT[3] OUT[2] SHL SW2[3] OUT[13] OUT[15] SW2[2] SW2[5] calib2 START[4]
                 start DATA[1] DATA[0] OUT[14] START[11] OUT[1] SW1[0] SW1[1] SW1[2] SW1[3]
                 SW1[4] SW1[5] SW1[6] SW1[7] SW1[8] SW1[9] SW1[10] SW1[11] SW1[12] SW1[13]
                 SW1[14] SW2[0] OUT[8] SEN_EN RST SMP OUT[4] OUT[5] OUT[6] OUT[7] CLK SW2[1]
                 SW2[4] SW2[6] OUT[11] OUT[9] OUT[10] OUT[12]
o Ambiguity Resolution Points:
      (Each one of the following objects belongs to a group of indistinguishable objects.
       The listed objects were matched arbitrarily by the Ambiguity Resolution feature of LVS.
       Arbitrary matching may be prevented by assigning names to these objects or to adjacent nets).
       Layout                                                    Source
                                     Nets
       X40/X477/17                                               Xtim_cnt_reg_5_/13
       X28/X74/20                                                Xdata_ad8_reg_134_/16
       X47/X14/20                                                Xdata_ad8_reg_139_/16
       X34/X21/20                                                Xdata_ad8_reg_132_/16
       X27/X69/20                                                Xdata_ad8_reg_144_/16
       X34/X20/20                                                Xdata_ad8_reg_149_/16
       X34/X17/20                                                Xdata_ad8_reg_142_/16
       X27/593                                                   Xadd_508/carry[7]
       X28/650                                                   Xadd_508/carry[5]
       X28/651                                                   Xadd_508/carry[4]
       X47/X15/20                                                Xdata_ad8_reg_145_/16
       X28/X72/20                                                Xdata_ad8_reg_143_/16
       X29/X61/20                                                Xdata_ad8_reg_140_/16
       X29/X58/20                                                Xdata_ad8_reg_146_/16
       X27/X73/20                                                Xdata_ad8_reg_147_/16
       X26/X37/7                                                 Xdata_ch6_reg_5_/2
       X26/X30/7                                                 Xdata_ch11_reg_6_/2
       X27/X18/7                                                 Xdata_ch5_reg_4_/2
       X27/X22/7                                                 Xdata_ch10_reg_1_/2
       X27/X19/7                                                 Xdata_ch4_reg_9_/2
       X26/X34/7                                                 Xdata_ch6_reg_8_/2
       X30/X25/7                                                 Xdata_ad8_reg_7_/2
       X30/X1194/X0/7                                            Xdata_ad8_reg_8_/2
       X47/X0/7                                                  Xdata_ad8_reg_0_/2
       X30/X29/7                                                 Xdata_ad8_reg_1_/2
       X30/X1193/X0/7                                            Xdata_ad8_reg_9_/2
       X28/X41/7                                                 Xdata_ad8_reg_2_/2
       X64/X1/7                                                  Xdata_ad8_reg_3_/2
       X61/X2/7                                                  Xdata_ad8_reg_4_/2
       X63/X0/7                                                  Xdata_ad8_reg_5_/2
       X42/363                                                   Xadd_673/carry[9]
       X51/326                                                   Xadd_658/carry[9]
       X40/380                                                   Xadd_643/carry[9]
       X33/287                                                   Xadd_732/carry[9]
       X30/836                                                   Xadd_583/carry[9]
       X30/806                                                   Xadd_553/carry[9]
       X29/1163                                                  Xadd_538/carry[9]
       X28/1142                                                  Xadd_523/carry[9]
       X27/590                                                   Xadd_508/carry[9]
       2933                                                      Xadd_717/carry[9]
       X54/251                                                   Xadd_673/carry[6]
       X43/393                                                   Xadd_673/carry[8]
       X51/330                                                   Xadd_688/carry[8]
       X30/844                                                   Xadd_658/carry[8]
       X30/819                                                   Xadd_717/carry[8]
       X30/802                                                   Xadd_732/carry[8]
       X40/381                                                   Xadd_658/carry[3]
       489                                                       Xadd_643/carry[8]
       X28/1136                                                  Xadd_598/carry[5]
       1909                                                      Xadd_583/carry[8]
                                   Instances
       (_xr2v)                                                   (_xr2v)
       Devices:
         X26/X538/M14(91.220,95.880)  MP(pch)                      Xadd_613/XU1_1_1/M14  MP(PCH)
         X26/X538/M15(91.970,95.510)  MP(pch)                      Xadd_613/XU1_1_1/M15  MP(PCH)
         X26/X538/M6(92.220,94.005)  MN(nch)                       Xadd_613/XU1_1_1/M6  MN(NCH)
         X26/X538/M5(91.485,94.005)  MN(nch)                       Xadd_613/XU1_1_1/M5  MN(NCH)
         X26/X538/M17(93.680,95.510)  MP(pch)                      Xadd_613/XU1_1_1/M17  MP(PCH)
         X26/X538/M8(93.680,94.135)  MN(nch)                       Xadd_613/XU1_1_1/M8  MN(NCH)
         X26/X538/M13(90.525,95.880)  MP(pch)                      Xadd_613/XU1_1_1/M13  MP(PCH)
         X26/X538/M4(90.530,93.925)  MN(nch)                       Xadd_613/XU1_1_1/M4  MN(NCH)
         X26/X538/M16(92.950,95.510)  MP(pch)                      Xadd_613/XU1_1_1/M16  MP(PCH)
         X26/X538/M7(92.950,94.295)  MN(nch)                       Xadd_613/XU1_1_1/M7  MN(NCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X25/X3/M26(98.415,71.370)  MP(pch)                        Xdata_ad7_reg_158_/M26  MP(PCH)
         X25/X3/M27(98.845,71.370)  MP(pch)                        Xdata_ad7_reg_158_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X25/X2/M26(77.955,71.370)  MP(pch)                        Xdata_ad7_reg_150_/M26  MP(PCH)
         X25/X2/M27(78.385,71.370)  MP(pch)                        Xdata_ad7_reg_150_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X28/X1516/X0/M26(78.615,142.550)  MP(pch)                 Xdata_ad7_reg_157_/M26  MP(PCH)
         X28/X1516/X0/M27(79.045,142.550)  MP(pch)                 Xdata_ad7_reg_157_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X27/X21/M26(99.075,115.670)  MP(pch)                      Xdata_ad7_reg_155_/M26  MP(PCH)
         X27/X21/M27(99.505,115.670)  MP(pch)                      Xdata_ad7_reg_155_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X26/X41/M26(124.085,78.090)  MP(pch)                      Xdata_ad7_reg_151_/M26  MP(PCH)
         X26/X41/M27(123.655,78.090)  MP(pch)                      Xdata_ad7_reg_151_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X28/X2/M26(96.435,135.830)  MP(pch)                       Xdata_ad7_reg_152_/M26  MP(PCH)
         X28/X2/M27(96.865,135.830)  MP(pch)                       Xdata_ad7_reg_152_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X28/X1/M26(80.595,135.830)  MP(pch)                       Xdata_ad7_reg_154_/M26  MP(PCH)
         X28/X1/M27(81.025,135.830)  MP(pch)                       Xdata_ad7_reg_154_/M27  MP(PCH)
       (_smp2v)                                                  (_smp2v)
       Devices:
         X26/X35/M26(100.395,98.250)  MP(pch)                      Xdata_ad7_reg_153_/M26  MP(PCH)
         X26/X35/M27(100.825,98.250)  MP(pch)                      Xdata_ad7_reg_153_/M27  MP(PCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X802/M18(485.245,131.615)  MP(pch)                    Xdata_adc_reg_153_/M18  MP(PCH)
         X28/X802/M1(485.245,133.195)  MN(nch)                     Xdata_adc_reg_153_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X48/X251/M18(1408.585,104.735)  MP(pch)                   Xdata_adc_reg_142_/M18  MP(PCH)
         X48/X251/M1(1408.585,106.315)  MN(nch)                    Xdata_adc_reg_142_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X27/X546/M18(655.315,111.455)  MP(pch)                    Xdata_adc_reg_84_/M18  MP(PCH)
         X27/X546/M1(655.315,113.035)  MN(nch)                     Xdata_adc_reg_84_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X54/X365/M18(1855.855,82.305)  MP(pch)                    Xdata_adc_reg_127_/M18  MP(PCH)
         X54/X365/M1(1855.855,80.725)  MN(nch)                     Xdata_adc_reg_127_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X34/X257/M18(961.555,104.735)  MP(pch)                    Xdata_adc_reg_40_/M18  MP(PCH)
         X34/X257/M1(961.555,106.315)  MN(nch)                     Xdata_adc_reg_40_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X798/M18(456.865,124.895)  MP(pch)                    Xdata_adc_reg_12_/M18  MP(PCH)
         X28/X798/M1(456.865,126.475)  MN(nch)                     Xdata_adc_reg_12_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X804/M18(497.785,131.615)  MP(pch)                    Xdata_adc_reg_152_/M18  MP(PCH)
         X28/X804/M1(497.785,133.195)  MN(nch)                     Xdata_adc_reg_152_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X1186/X1/M18(459.295,185.375)  MP(pch)                Xdata_adc_reg_143_/M18  MP(PCH)
         X29/X1186/X1/M1(459.295,186.955)  MN(nch)                 Xdata_adc_reg_143_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X30/X1080/X1/M18(514.735,209.985)  MP(pch)                Xdata_adc_reg_21_/M18  MP(PCH)
         X30/X1080/X1/M1(514.735,208.405)  MN(nch)                 Xdata_adc_reg_21_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X805/M18(515.605,156.225)  MP(pch)                    Xdata_adc_reg_87_/M18  MP(PCH)
         X28/X805/M1(515.605,154.645)  MN(nch)                     Xdata_adc_reg_87_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X795/M18(429.595,129.345)  MP(pch)                    Xdata_adc_reg_33_/M18  MP(PCH)
         X28/X795/M1(429.595,127.765)  MN(nch)                     Xdata_adc_reg_33_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X794/M18(425.185,124.895)  MP(pch)                    Xdata_adc_reg_109_/M18  MP(PCH)
         X28/X794/M1(425.185,126.475)  MN(nch)                     Xdata_adc_reg_109_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X793/M18(424.525,156.225)  MP(pch)                    Xdata_adc_reg_63_/M18  MP(PCH)
         X28/X793/M1(424.525,154.645)  MN(nch)                     Xdata_adc_reg_63_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X806/M18(517.585,136.065)  MP(pch)                    Xdata_adc_reg_157_/M18  MP(PCH)
         X28/X806/M1(517.585,134.485)  MN(nch)                     Xdata_adc_reg_157_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X709/M18(340.705,189.825)  MP(pch)                    Xdata_adc_reg_95_/M18  MP(PCH)
         X29/X709/M1(340.705,188.245)  MN(nch)                     Xdata_adc_reg_95_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X48/X261/M18(1508.905,104.735)  MP(pch)                   Xdata_adc_reg_59_/M18  MP(PCH)
         X48/X261/M1(1508.905,106.315)  MN(nch)                    Xdata_adc_reg_59_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X61/X307/M18(1895.665,89.025)  MP(pch)                    Xdata_adc_reg_80_/M18  MP(PCH)
         X61/X307/M1(1895.665,87.445)  MN(nch)                     Xdata_adc_reg_80_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X63/X407/M18(1892.365,151.775)  MP(pch)                   Xdata_adc_reg_81_/M18  MP(PCH)
         X63/X407/M1(1892.365,153.355)  MN(nch)                    Xdata_adc_reg_81_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X789/M18(407.365,122.625)  MP(pch)                    Xdata_adc_reg_123_/M18  MP(PCH)
         X28/X789/M1(407.365,121.045)  MN(nch)                     Xdata_adc_reg_123_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X788/M18(397.465,142.785)  MP(pch)                    Xdata_adc_reg_150_/M18  MP(PCH)
         X28/X788/M1(397.465,141.205)  MN(nch)                     Xdata_adc_reg_150_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X787/M18(379.645,122.625)  MP(pch)                    Xdata_adc_reg_145_/M18  MP(PCH)
         X28/X787/M1(379.645,121.045)  MN(nch)                     Xdata_adc_reg_145_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X48/X265/M18(1521.235,102.465)  MP(pch)                   Xdata_adc_reg_121_/M18  MP(PCH)
         X48/X265/M1(1521.235,100.885)  MN(nch)                    Xdata_adc_reg_121_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X27/X522/M18(378.985,104.735)  MP(pch)                    Xdata_adc_reg_91_/M18  MP(PCH)
         X27/X522/M1(378.985,106.315)  MN(nch)                     Xdata_adc_reg_91_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X743/M18(617.905,158.495)  MP(pch)                    Xdata_adc_reg_65_/M18  MP(PCH)
         X29/X743/M1(617.905,160.075)  MN(nch)                     Xdata_adc_reg_65_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X30/X654/M18(428.935,212.255)  MP(pch)                    Xdata_adc_reg_136_/M18  MP(PCH)
         X30/X654/M1(428.935,213.835)  MN(nch)                     Xdata_adc_reg_136_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X30/X644/M18(379.645,205.535)  MP(pch)                    Xdata_adc_reg_77_/M18  MP(PCH)
         X30/X644/M1(379.645,207.115)  MN(nch)                     Xdata_adc_reg_77_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X30/X683/M18(615.265,205.535)  MP(pch)                    Xdata_adc_reg_119_/M18  MP(PCH)
         X30/X683/M1(615.265,207.115)  MN(nch)                     Xdata_adc_reg_119_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X782/M18(336.745,156.225)  MP(pch)                    Xdata_adc_reg_14_/M18  MP(PCH)
         X28/X782/M1(336.745,154.645)  MN(nch)                     Xdata_adc_reg_14_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X724/M18(454.225,169.665)  MP(pch)                    Xdata_adc_reg_159_/M18  MP(PCH)
         X29/X724/M1(454.225,168.085)  MN(nch)                     Xdata_adc_reg_159_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X812/M18(555.865,138.335)  MP(pch)                    Xdata_adc_reg_37_/M18  MP(PCH)
         X28/X812/M1(555.865,139.915)  MN(nch)                     Xdata_adc_reg_37_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X1181/X1/M18(393.295,178.655)  MP(pch)                Xdata_adc_reg_10_/M18  MP(PCH)
         X29/X1181/X1/M1(393.295,180.235)  MN(nch)                 Xdata_adc_reg_10_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X58/X355/M18(1647.295,223.425)  MP(pch)                   Xdata_adc_reg_15_/M18  MP(PCH)
         X58/X355/M1(1647.295,221.845)  MN(nch)                    Xdata_adc_reg_15_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X61/X309/M18(1912.165,89.025)  MP(pch)                    Xdata_adc_reg_78_/M18  MP(PCH)
         X61/X309/M1(1912.165,87.445)  MN(nch)                     Xdata_adc_reg_78_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X28/X778/M18(309.025,151.775)  MP(pch)                    Xdata_adc_reg_60_/M18  MP(PCH)
         X28/X778/M1(309.025,153.355)  MN(nch)                     Xdata_adc_reg_60_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X27/X544/M18(636.175,109.185)  MP(pch)                    Xdata_adc_reg_25_/M18  MP(PCH)
         X27/X544/M1(636.175,107.605)  MN(nch)                     Xdata_adc_reg_25_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X710/M18(342.025,176.385)  MP(pch)                    Xdata_adc_reg_122_/M18  MP(PCH)
         X29/X710/M1(342.025,174.805)  MN(nch)                     Xdata_adc_reg_122_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X58/X360/M18(1687.765,223.425)  MP(pch)                   Xdata_adc_reg_115_/M18  MP(PCH)
         X58/X360/M1(1687.765,221.845)  MN(nch)                    Xdata_adc_reg_115_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X1500/X1/M18(321.565,171.935)  MP(pch)                Xdata_adc_reg_134_/M18  MP(PCH)
         X29/X1500/X1/M1(321.565,173.515)  MN(nch)                 Xdata_adc_reg_134_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X34/X263/M18(1020.955,118.175)  MP(pch)                   Xdata_adc_reg_100_/M18  MP(PCH)
         X34/X263/M1(1020.955,119.755)  MN(nch)                    Xdata_adc_reg_100_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X29/X731/M18(484.585,176.385)  MP(pch)                    Xdata_adc_reg_126_/M18  MP(PCH)
         X29/X731/M1(484.585,174.805)  MN(nch)                     Xdata_adc_reg_126_/M1  MN(NCH)
       (_invv)                                                   (_invv)
       Devices:
         X30/X648/M18(398.125,196.545)  MP(pch)                    Xdata_adc_reg_129_/M18  MP(PCH)
         X30/X648/M1(398.125,194.965)  MN(nch)                     Xdata_adc_reg_129_/M1  MN(NCH)
                             DETAILED INSTANCE CONNECTIONS
          (This section contains detailed information about connections of
           matched instances that are involved in net discrepancies).
       X26/M24(741.805,97.240)  MP(pch)                          XU13670/M5  MP(PCH)
         s: X26/581                                                d: n9459
         d: VDD                                                    s: VDD
         b: VDD                                                    b: VDD
         g: X26/586                                                ** no similar net **
         ** SEN_EN **                                              g: SEN_EN
       X26/X1054/M3(748.585,95.505)  MP(pch)                     XU13669/M3  MP(PCH)
         s: VDD                                                    s: VDD
         d: X26/902                                                d: n9458
         b: VDD                                                    b: VDD
         g: 679                                                    ** n11094 **
         ** no similar net **                                      g: n9456
       (_smp2v)                                                  (_smp2v)
         in2: 678                                                  in1: n9453
         out1: X26/902                                             out1: n9458
         out2: VDD                                                 out2: VDD
         in1: 2469                                                 ** no similar net **
         ** 679 **                                                 in2: n11094
       Devices:
         X26/X1054/M5(747.265,95.505)  MP(pch)                     XU13669/M4  MP(PCH)
         X26/X1054/M4(747.925,95.505)  MP(pch)                     XU13669/M5  MP(PCH)
       (_smp2v)                                                  (_smp2v)
         in1: X26/582                                              in1: XU13670/2
         out1: X26/581                                             out1: n9459
         out2: VDD                                                 out2: VDD
         in2: SEN_EN                                               ** SEN_EN **
         ** no similar net **                                      in2: calibr
       Devices:
         X26/M23(741.145,97.240)  MP(pch)                          XU13670/M6  MP(PCH)
         X26/M22(740.485,97.240)  MP(pch)                          XU13670/M7  MP(PCH)
       (_sdw2v)                                                  (_sdw2v)
         in1: 227                                                  in1: n11060
         out2: VSS                                                 out2: VSS
         in2: OUT[3]                                               ** OUT[3] **
         out1: 192                                                 ** no similar net **
         ** no similar net **                                      in2: n11640
         ** no similar net **                                      out1: n9484
       Devices:
         X33/X469/M1(825.595,86.455)  MN(nch)                      XU12522/M1  MN(NCH)
         X33/X469/M2(826.255,86.455)  MN(nch)                      XU12522/M2  MN(NCH)
       (_invv)                                                   (_invv)
         out: X44/X568/6                                           out: XTX_STB2_tri/3
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         in: SHL                                                   ** SHL **
         ** no similar net **                                      in: TX_STB_OUT
       Devices:
         X44/X568/M6(1200.685,205.790)  MP(pch)                    XTX_STB2_tri/M6  MP(PCH)
         X44/X568/M0(1200.685,207.000)  MN(nch)                    XTX_STB2_tri/M0  MN(NCH)
       (_invv)                                                   (_invv)
         out: X44/X566/6                                           out: Xcalib2_tri/3
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         in: SHL                                                   ** SHL **
         ** no similar net **                                      in: calib_OUT
       Devices:
         X44/X566/M6(1178.035,219.230)  MP(pch)                    Xcalib2_tri/M6  MP(PCH)
         X44/X566/M0(1178.035,220.440)  MN(nch)                    Xcalib2_tri/M0  MN(NCH)
       (_invv)                                                   (_invv)
         in: X26/X31/20                                            in: Xdata_ch7_reg_9_/16
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         out: X26/600                                              ** n2727 **
         ** 414 **                                                 out: n2718
       Devices:
         X26/X31/M31(81.805,95.505)  MP(pch)                       Xdata_ch7_reg_9_/M31  MP(PCH)
         X26/X31/M16(81.805,93.865)  MN(nch)                       Xdata_ch7_reg_9_/M16  MN(NCH)
       (_invv)                                                   (_invv)
         in: X26/X549/10                                           in: XU8430/8
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         out: X26/897                                              ** no similar net **
         ** 520 **                                                 out: add_251_carry[2]
       Devices:
         X26/X549/M9(727.465,78.110)  MP(pch)                      XU8430/M9  MP(PCH)
         X26/X549/M0(727.465,79.580)  MN(nch)                      XU8430/M0  MN(NCH)
       (_invv)                                                   (_invv)
         in: X26/X549/7                                            in: XU8430/5
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         out: 520                                                  ** add_251_carry[2] **
         ** no similar net **                                      out: N292
       Devices:
         X26/X549/M10(726.725,78.110)  MP(pch)                     XU8430/M10  MP(PCH)
         X26/X549/M1(726.725,79.580)  MN(nch)                      XU8430/M1  MN(NCH)
       (_invv)                                                   (_invv)
         in: X30/X38/20                                            in: Xdata_ch7_reg_7_/16
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         out: X30/690                                              ** no similar net **
         ** 402 **                                                 out: n2720
       Devices:
         X30/X38/M31(484.405,212.495)  MP(pch)                     Xdata_ch7_reg_7_/M31  MP(PCH)
         X30/X38/M16(484.405,214.135)  MN(nch)                     Xdata_ch7_reg_7_/M16  MN(NCH)
       (_nor2v)                                                  (_nor2v)
         in2: X44/X568/6                                           in2: XTX_STB2_tri/3
         out: X44/X568/9                                           out: XTX_STB2_tri/6
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         in1: 2695                                                 ** no similar net **
         ** SHL **                                                 in1: SHL
       Devices:
         X44/X568/M9(1197.950,205.420)  MP(pch)                    XTX_STB2_tri/M9  MP(PCH)
         X44/X568/M10(1197.520,205.420)  MP(pch)                   XTX_STB2_tri/M10  MP(PCH)
         X44/X568/M3(1197.950,207.000)  MN(nch)                    XTX_STB2_tri/M3  MN(NCH)
         X44/X568/M4(1197.290,207.000)  MN(nch)                    XTX_STB2_tri/M4  MN(NCH)
       (_nor2v)                                                  (_nor2v)
         in2: X44/X566/6                                           in2: Xcalib2_tri/3
         out: X44/X566/9                                           out: Xcalib2_tri/6
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         in1: 254                                                  ** no similar net **
         ** SHL **                                                 in1: SHL
       Devices:
         X44/X566/M9(1180.770,218.860)  MP(pch)                    Xcalib2_tri/M9  MP(PCH)
         X44/X566/M10(1181.200,218.860)  MP(pch)                   Xcalib2_tri/M10  MP(PCH)
         X44/X566/M3(1180.770,220.440)  MN(nch)                    Xcalib2_tri/M3  MN(NCH)
         X44/X566/M4(1181.430,220.440)  MN(nch)                    Xcalib2_tri/M4  MN(NCH)
       (_nand2v)                                                 (_nand2v)
         out: X42/X668/6                                           out: Xadd_688/XU1_1_2/5
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         in1: 415                                                  ** n11061 **
         in2: 1553                                                 ** no similar net **
         ** no similar net **                                      in1: n9011
         ** no similar net **                                      in2: Xadd_688/carry[2]
       Devices:
         ** unmatched instance **                                  Xadd_688/XU1_1_2/M3  MN(NCH)
         ** unmatched instance **                                  Xadd_688/XU1_1_2/M2  MN(NCH)
         ** unmatched instance **                                  Xadd_688/XU1_1_2/M12  MP(PCH)
         ** unmatched instance **                                  Xadd_688/XU1_1_2/M11  MP(PCH)
         X42/X668/M0(1133.365,153.500)  MN(nch)                    ** unmatched instance **
         X42/X668/M1(1132.705,153.500)  MN(nch)                    ** unmatched instance **
         X42/X668/M3(1133.365,151.595)  MP(pch)                    ** unmatched instance **
         X42/X668/M4(1132.705,151.595)  MP(pch)                    ** unmatched instance **
       (_nand2v)                                                 (_nand2v)
         sup1: VDD                                                 sup1: VDD
         sup2: VSS                                                 sup2: VSS
         in1: X40/374                                              ** no similar net **
         in2: X40/363                                              ** no similar net **
         out: X40/X415/7                                           ** no similar net **
         ** no similar net **                                      in1: n9500
         ** 415 **                                                 in2: n11061
         ** unmatched net **                                       out: XU11219/2
       Devices:
         ** unmatched instance **                                  XU11219/M0  MN(NCH)
         ** unmatched instance **                                  XU11219/M1  MN(NCH)
         ** unmatched instance **                                  XU11219/M3  MP(PCH)
         ** unmatched instance **                                  XU11219/M4  MP(PCH)
         X40/X415/M2(1168.275,93.115)  MN(nch)                     ** unmatched instance **
         X40/X415/M3(1168.875,93.115)  MN(nch)                     ** unmatched instance **
         X40/X415/M11(1168.175,91.160)  MP(pch)                    ** unmatched instance **
         X40/X415/M12(1168.935,91.160)  MP(pch)                    ** unmatched instance **
       (SPUP_2_1)                                                (SPUP_2_1)
         input: 415                                                input: n11061
         output: 398                                               ** no similar net **
         input: OUT[8]                                             ** OUT[8] **
         input: 609                                                ** no similar net **
         ** no similar net **                                      output: n9494
         ** no similar net **                                      input: n11638
         ** OUT[8] **                                              input: OUT[8]
       Transistors:
         X26/X1034/M4(462.805,98.255)  MP(pch)                     XU12517/M4  MP(PCH)
         X26/X1034/M5(462.145,98.255)  MP(pch)                     XU12517/M5  MP(PCH)
         X26/X1034/M3(463.465,98.255)  MP(pch)                     XU12517/M3  MP(PCH)
         output: 494                                               output: n9504
         input: 276                                                input: n9481
         input: OUT[13]                                            ** OUT[13] **
         input: 663                                                ** no similar net **
         ** no similar net **                                      input: n11633
         ** OUT[13] **                                             input: OUT[13]
       Transistors:
         X26/X1035/M4(693.805,88.785)  MP(pch)                     XU12512/M4  MP(PCH)
         X26/X1035/M5(693.145,88.785)  MP(pch)                     XU12512/M5  MP(PCH)
         X26/X1035/M3(694.465,88.785)  MP(pch)                     XU12512/M3  MP(PCH)
       (SPDW_2_1_1)                                              (SPDW_2_1_1)
         output: 2477                                              ** no similar net **
         input: 2482                                               ** n9471 **
         input: X26/894                                            ** sense **
         input: 2480                                               ** n11284 **
         input: 675                                                ** no similar net **
         ** no similar net **                                      output: n9472
         ** no similar net **                                      input: n9469
         ** 2480 **                                                input: n11284
         ** X26/894 **                                             input: sense
         ** 2482 **                                                input: n9471
       Transistors:
         X26/X1070/M2(758.485,87.300)  MN(nch)                     XU13713/M3  MN(NCH)
         X26/X1070/M3(757.825,87.300)  MN(nch)                     XU13713/M2  MN(NCH)
         X26/X1070/M0(759.805,87.300)  MN(nch)                     XU13713/M1  MN(NCH)
         X26/X1070/M1(759.145,87.300)  MN(nch)                     XU13713/M0  MN(NCH)
         output: 672                                               ** no similar net **
         input: OUT[5]                                             ** OUT[5] **
         input: 661                                                ** no similar net **
         ** no similar net **                                      output: n9488
         ** no similar net **                                      input: n11641
         ** OUT[5] **                                              input: OUT[5]
       Transistors:
         X27/X864/M4(683.245,104.975)  MP(pch)                     XU12520/M4  MP(PCH)
         X27/X864/M5(682.585,104.975)  MP(pch)                     XU12520/M5  MP(PCH)
         X27/X864/M3(683.905,104.975)  MP(pch)                     XU12520/M3  MP(PCH)
         output: 691                                               output: n9479
         input: OUT[1]                                             ** OUT[1] **
         input: 2950                                               ** no similar net **
         ** no similar net **                                      input: n11639
         ** OUT[1] **                                              input: OUT[1]
       Transistors:
         X27/X862/M4(101.785,108.945)  MP(pch)                     XU12524/M4  MP(PCH)
         X27/X862/M5(101.125,108.945)  MP(pch)                     XU12524/M5  MP(PCH)
         X27/X862/M3(102.445,108.945)  MP(pch)                     XU12524/M3  MP(PCH)
         output: 1491                                              ** no similar net **
         input: OUT[4]                                             ** OUT[4] **
         input: 2993                                               ** no similar net **
         ** no similar net **                                      output: n9486
         ** no similar net **                                      input: n11636
         ** OUT[4] **                                              input: OUT[4]
       Transistors:
         X27/X863/M4(535.405,111.695)  MP(pch)                     XU12521/M4  MP(PCH)
         X27/X863/M5(534.745,111.695)  MP(pch)                     XU12521/M5  MP(PCH)
         X27/X863/M3(536.065,111.695)  MP(pch)                     XU12521/M3  MP(PCH)
         output: 971                                               ** no similar net **
         input: OUT[10]                                            ** OUT[10] **
         input: 667                                                ** no similar net **
         ** no similar net **                                      output: n9498
         ** no similar net **                                      input: n11628
         ** OUT[10] **                                             input: OUT[10]
       Transistors:
         X28/X1332/M4(704.365,145.295)  MP(pch)                    XU12515/M4  MP(PCH)
         X28/X1332/M5(703.705,145.295)  MP(pch)                    XU12515/M5  MP(PCH)
         X28/X1332/M3(705.025,145.295)  MP(pch)                    XU12515/M3  MP(PCH)
         output: 975                                               ** no similar net **
         input: OUT[15]                                            ** OUT[15] **
         input: 681                                                ** no similar net **
         ** no similar net **                                      output: n9508
         ** no similar net **                                      input: n11634
         ** OUT[15] **                                             input: OUT[15]
       Transistors:
         X34/X365/M4(868.045,102.225)  MP(pch)                     XU12510/M4  MP(PCH)
         X34/X365/M5(867.385,102.225)  MP(pch)                     XU12510/M5  MP(PCH)
         X34/X365/M3(868.705,102.225)  MP(pch)                     XU12510/M3  MP(PCH)
         output: 2496                                              ** no similar net **
         input: OUT[12]                                            ** OUT[12] **
         input: 1237                                               ** no similar net **
         ** no similar net **                                      output: n9502
         ** no similar net **                                      input: n11629
         ** OUT[12] **                                             input: OUT[12]
       Transistors:
         X35/X609/M4(779.605,129.105)  MP(pch)                     XU12513/M4  MP(PCH)
         X35/X609/M5(778.945,129.105)  MP(pch)                     XU12513/M5  MP(PCH)
         X35/X609/M3(780.265,129.105)  MP(pch)                     XU12513/M3  MP(PCH)
         output: 1105                                              ** no similar net **
         input: OUT[6]                                             ** OUT[6] **
         input: 669                                                ** no similar net **
         ** no similar net **                                      output: n9490
         ** no similar net **                                      input: n11637
         ** OUT[6] **                                              input: OUT[6]
       Transistors:
         X29/X1229/M4(701.065,178.895)  MP(pch)                    XU12519/M4  MP(PCH)
         X29/X1229/M5(700.405,178.895)  MP(pch)                    XU12519/M5  MP(PCH)
         X29/X1229/M3(701.725,178.895)  MP(pch)                    XU12519/M3  MP(PCH)
         output: 1142                                              output: n9482
         input: OUT[2]                                             ** OUT[2] **
         input: 1191                                               ** no similar net **
         ** no similar net **                                      input: n11635
         ** OUT[2] **                                              input: OUT[2]
       Transistors:
         X33/X467/M4(784.675,91.535)  MP(pch)                      XU12523/M4  MP(PCH)
         X33/X467/M5(785.335,91.535)  MP(pch)                      XU12523/M5  MP(PCH)
         X33/X467/M3(784.015,91.535)  MP(pch)                      XU12523/M3  MP(PCH)
         output: 1400                                              ** no similar net **
         input: OUT[9]                                             ** OUT[9] **
         input: 674                                                ** no similar net **
         ** no similar net **                                      output: n9496
         ** no similar net **                                      input: n11631
         ** OUT[9] **                                              input: OUT[9]
       Transistors:
         X33/X468/M4(793.255,91.535)  MP(pch)                      XU12516/M4  MP(PCH)
         X33/X468/M5(793.915,91.535)  MP(pch)                      XU12516/M5  MP(PCH)
         X33/X468/M3(792.595,91.535)  MP(pch)                      XU12516/M3  MP(PCH)
         input: 227                                                input: n11060
         output: 192                                               ** no similar net **
         input: OUT[3]                                             ** OUT[3] **
         input: 95                                                 ** no similar net **
         ** no similar net **                                      output: n9484
         ** no similar net **                                      input: n11640
         ** OUT[3] **                                              input: OUT[3]
       Transistors:
         X33/X469/M4(825.595,84.815)  MP(pch)                      XU12522/M4  MP(PCH)
         X33/X469/M5(826.255,84.815)  MP(pch)                      XU12522/M5  MP(PCH)
         X33/X469/M3(824.935,84.815)  MP(pch)                      XU12522/M3  MP(PCH)
         output: 210                                               output: n9492
         input: OUT[7]                                             ** OUT[7] **
         input: X34/338                                            ** no similar net **
         ** no similar net **                                      input: n11642
         ** OUT[7] **                                              input: OUT[7]
       Transistors:
         X34/X366/M4(877.075,118.415)  MP(pch)                     XU12518/M4  MP(PCH)
         X34/X366/M5(877.735,118.415)  MP(pch)                     XU12518/M5  MP(PCH)
         X34/X366/M3(876.415,118.415)  MP(pch)                     XU12518/M3  MP(PCH)
         output: 257                                               ** no similar net **
         input: OUT[11]                                            ** OUT[11] **
         input: 3256                                               ** no similar net **
         ** no similar net **                                      output: n9500
         ** no similar net **                                      input: n11632
         ** OUT[11] **                                             input: OUT[11]
       Transistors:
         X35/X610/M4(950.335,131.855)  MP(pch)                     XU12514/M4  MP(PCH)
         X35/X610/M5(950.995,131.855)  MP(pch)                     XU12514/M5  MP(PCH)
         X35/X610/M3(949.675,131.855)  MP(pch)                     XU12514/M3  MP(PCH)
         output: 1553                                              ** no similar net **
         input: OUT[14]                                            ** OUT[14] **
         input: 1172                                               ** no similar net **
         ** no similar net **                                      output: n9506
         ** no similar net **                                      input: n11630
         ** OUT[14] **                                             input: OUT[14]
       Transistors:
         X42/X686/M4(1137.115,131.855)  MP(pch)                    XU12511/M4  MP(PCH)
         X42/X686/M5(1137.775,131.855)  MP(pch)                    XU12511/M5  MP(PCH)
         X42/X686/M3(1136.455,131.855)  MP(pch)                    XU12511/M3  MP(PCH)
       (SPDW_2_1)                                                (SPDW_2_1)
         output: X26/581                                           output: n9459
         input: X26/582                                            input: XU13670/2
         input: SEN_EN                                             ** SEN_EN **
         input: X26/586                                            ** no similar net **
         ** no similar net **                                      input: calibr
         ** SEN_EN **                                              input: SEN_EN
       Transistors:
         X26/M7(740.485,99.140)  MN(nch)                           XU13670/M3  MN(NCH)
         X26/M8(741.145,99.140)  MN(nch)                           XU13670/M2  MN(NCH)
         X26/M9(741.805,99.140)  MN(nch)                           XU13670/M1  MN(NCH)
         output: X26/903                                           ** no similar net **
         input: 679                                                ** n11094 **
         input: X26/904                                            ** no similar net **
         ** no similar net **                                      output: n7137
         ** no similar net **                                      input: n9470
         ** 679 **                                                 input: n11094
       Transistors:
         X26/X1055/M0(749.905,87.300)  MN(nch)                     XU13672/M0  MN(NCH)
         X26/X1055/M1(749.245,87.300)  MN(nch)
         X26/X1055/M2(748.585,87.300)  MN(nch)
        XU13672/M1  MN(NCH)
        XU13672/M2  MN(NCH)
         output: X26/902                                           output: n9458
         input: 678                                                input: n9453
         input: 2469                                               ** no similar net **
         ** no similar net **                                      input: n9456
       Transistors:
         X26/X1054/M1(747.925,94.020)  MN(nch)                     XU13669/M2  MN(NCH)
         X26/X1054/M2(747.265,94.020)  MN(nch)                     XU13669/M1  MN(NCH)
         X26/X1054/M0(748.585,94.020)  MN(nch)                     XU13669/M0  MN(NCH)
         input: 679                                                input: n11094
         output: X26/904                                           ** no similar net **
         ** no similar net **                                      output: n9470
       Transistors:
         X26/X1056/M1(753.205,94.020)  MN(nch)                     XU13673/M2  MN(NCH)
         X26/X1056/M2(752.545,94.020)  MN(nch)                     XU13673/M1  MN(NCH)
         X26/X1056/M0(753.865,94.020)  MN(nch)                     XU13673/M0  MN(NCH)
                                  UNMATCHED OBJECTS
       LAYOUT                                                    SOURCE
       488                                                       ** unmatched net **
       491                                                       ** unmatched net **
       666                                                       ** unmatched net **
       819                                                       ** unmatched net **
       831                                                       ** unmatched net **
       976                                                       ** unmatched net **
       103                                                       ** unmatched net **
       1100                                                      ** unmatched net **
       1102                                                      ** unmatched net **
       1111                                                      ** unmatched net **
       1238                                                      ** unmatched net **
       1397                                                      ** unmatched net **
       1497                                                      ** unmatched net **
       1500                                                      ** unmatched net **
       1549                                                      ** unmatched net **
       1913                                                      ** unmatched net **
       1969                                                      ** unmatched net **
       1975                                                      ** unmatched net **
       X25/X4/7                                                  ** unmatched net **
       X25/X4/11                                                 ** unmatched net **
       X25/X4/14                                                 ** unmatched net **
       X25/X4/17                                                 ** unmatched net **
       X25/X12/7                                                 ** unmatched net **
       X25/X12/11                                                ** unmatched net **
       X25/X12/14                                                ** unmatched net **
       X25/X12/17                                                ** unmatched net **
       X25/X185/8                                                ** unmatched net **
       X25/X186/8                                                ** unmatched net **
       X25/X187/8                                                ** unmatched net **
       X25/X188/8                                                ** unmatched net **
       X25/X285/8                                                ** unmatched net **
       X25/X285/11                                               ** unmatched net **
       X25/X285/14                                               ** unmatched net **
       X26/837                                                   ** unmatched net **
       X26/596                                                   ** unmatched net **
       X26/839                                                   ** unmatched net **
       X26/838                                                   ** unmatched net **
       X26/825                                                   ** unmatched net **
       X26/834                                                   ** unmatched net **
       X26/X33/7                                                 ** unmatched net **
       X26/X33/8                                                 ** unmatched net **
       X26/X33/11                                                ** unmatched net **
       X26/X33/14                                                ** unmatched net **
       X26/X33/17                                                ** unmatched net **
       X26/X36/17                                                ** unmatched net **
       X26/X38/17                                                ** unmatched net **
       X26/X39/17                                                ** unmatched net **
       X26/X40/17                                                ** unmatched net **
       X26/X42/17                                                ** unmatched net **
       X26/X43/17                                                ** unmatched net **
       X51/X541/M4(1522.105,209.730)  MP(pch)                    ** unmatched instance **
       X51/X541/M5(1521.445,209.730)  MP(pch)                    ** unmatched instance **
       X50/X651/M4(1369.435,176.130)  MP(pch)                    ** unmatched instance **
       X50/X651/M5(1370.095,176.130)  MP(pch)                    ** unmatched instance **
       X50/M0(1352.275,174.505)  MN(nch)                         ** unmatched instance **
       X50/M1(1352.935,174.505)  MN(nch)                         ** unmatched instance **
       X26/X1070/M4(759.805,88.770)  MP(pch)                     ** unmatched instance **
       X26/X1070/M5(759.145,88.770)  MP(pch)                     ** unmatched instance **
       X25/X4/M19(142.075,71.205)  MP(pch)                       ** unmatched instance **
       X25/X4/M25(137.355,71.205)  MP(pch)                       ** unmatched instance **
       X25/X12/M19(593.905,71.205)  MP(pch)                      ** unmatched instance **
       X25/X12/M25(598.625,71.205)  MP(pch)                      ** unmatched instance **
       X25/X185/M7(83.275,75.330)  MP(pch)                       ** unmatched instance **
       X25/X186/M7(588.025,75.330)  MP(pch)                      ** unmatched instance **
       X25/X187/M7(609.805,75.330)  MP(pch)                      ** unmatched instance **
       X25/X188/M7(617.725,75.330)  MP(pch)                      ** unmatched instance **
       X25/X285/M19(756.535,71.205)  MP(pch)                     ** unmatched instance **
       X26/X33/M19(73.165,98.085)  MP(pch)                       ** unmatched instance **
       X26/X33/M25(77.885,98.085)  MP(pch)                       ** unmatched instance **
       X26/X36/M25(105.605,88.955)  MP(pch)                      ** unmatched instance **
       X26/X38/M25(109.565,95.675)  MP(pch)                      ** unmatched instance **
       X26/X39/M25(126.065,88.955)  MP(pch)                      ** unmatched instance **
       X26/X40/M25(124.155,98.085)  MP(pch)                      ** unmatched instance **
       X26/X42/M25(124.815,91.365)  MP(pch)                      ** unmatched instance **
       X26/X43/M25(134.645,84.645)  MP(pch)                      ** unmatched instance **
       X26/X44/M19(134.545,77.925)  MP(pch)                      ** unmatched instance **
       X26/X44/M25(139.265,77.925)  MP(pch)                      ** unmatched instance **
       X26/X86/M19(571.735,77.925)  MP(pch)                      ** unmatched instance **
       X26/X86/M25(567.015,77.925)  MP(pch)                      ** unmatched instance **
       X26/X87/M19(571.735,84.645)  MP(pch)                      ** unmatched instance **
       X26/X87/M25(567.015,84.645)  MP(pch)                      ** unmatched instance **
       X26/X88/M19(576.745,88.955)  MP(pch)                      ** unmatched instance **
       X26/X88/M25(581.465,88.955)  MP(pch)                      ** unmatched instance **
       X26/X89/M19(578.725,95.675)  MP(pch)                      ** unmatched instance **
       X26/X89/M25(583.445,95.675)  MP(pch)                      ** unmatched instance **
       X26/X90/M19(593.905,95.675)  MP(pch)                      ** unmatched instance **
       X26/X90/M25(598.625,95.675)  MP(pch)                      ** unmatched instance **
       X26/X91/M19(598.525,82.235)  MP(pch)                      ** unmatched instance **
       X26/X91/M25(603.245,82.235)  MP(pch)                      ** unmatched instance **
       X26/X92/M19(599.185,77.925)  MP(pch)                      ** unmatched instance **
       X26/X92/M25(603.905,77.925)  MP(pch)                      ** unmatched instance **
       X26/X93/M19(609.745,84.645)  MP(pch)                      ** unmatched instance **
       X26/X93/M25(614.465,84.645)  MP(pch)                      ** unmatched instance **
       X26/X96/M19(626.905,77.925)  MP(pch)                      ** unmatched instance **
       X26/X96/M25(631.625,77.925)  MP(pch)                      ** unmatched instance **
       X26/X105/M25(694.985,95.675)  MP(pch)                     ** unmatched instance **
       X26/X106/M19(698.845,91.365)  MP(pch)                     ** unmatched instance **
       X26/X106/M25(703.565,91.365)  MP(pch)                     ** unmatched instance **
       X26/X107/M19(718.645,95.675)  MP(pch)                     ** unmatched instance **
       X26/X107/M25(723.365,95.675)  MP(pch)                     ** unmatched instance **
       ** unmatched net **                                       n9435
       ** unmatched net **                                       n9396
       ** unmatched net **                                       n9395
       ** unmatched net **                                       n8895
       ** unmatched net **                                       n8891
       ** unmatched net **                                       n8905
       ** unmatched net **                                       n8904
       ** unmatched net **                                       n8903
       ** unmatched net **                                       n8902
       ** unmatched net **                                       n8901
       ** unmatched net **                                       n8900
       ** unmatched net **                                       n8899
       ** unmatched net **                                       n8916
       ** unmatched net **                                       n8915
       ** unmatched net **                                       n8913
       ** unmatched net **                                       n8911
       ** unmatched net **                                       n8910
       ** unmatched net **                                       n8909
       ** unmatched net **                                       n8923
       ** unmatched net **                                       n8931
       ** unmatched net **                                       n8930
       ** unmatched net **                                       n8929
       ** unmatched net **                                       n8946
       ** unmatched net **                                       n8945
       ** unmatched net **                                       n8942
       ** unmatched net **                                       n8941
       ** unmatched net **                                       n8940
       ** unmatched net **                                       n8939
       ** unmatched net **                                       n8956
       ** unmatched net **                                       n8955
       ** unmatched net **                                       n8953
       ** unmatched net **                                       n8952
       ** unmatched net **                                       n8951
       ** unmatched net **                                       n8950
       ** unmatched net **                                       n8949
       ** unmatched net **                                       n8961
       ** unmatched net **                                       n8971
       ** unmatched net **                                       n8970
       ** unmatched net **                                       n8969
       ** unmatched net **                                       n8986
       ** unmatched net **                                       n8985
       ** unmatched net **                                       n8984
       ** unmatched net **                                       n8983
       ** unmatched net **                                       n8982
       ** unmatched net **                                       n8981
       ** unmatched net **                                       n8980
       ** unmatched net **                                       n8979
       ** unmatched net **                                       n8996
       ** unmatched net **                                       n8995
       ** unmatched net **                                       n8994
       ** unmatched instance **                                  XU13906/M0  MN(NCH)
       ** unmatched instance **                                  XU13906/M1  MN(NCH)
       ** unmatched instance **                                  XU13713/M5  MP(PCH)
       ** unmatched instance **                                  XU13750/M4  MP(PCH)
       ** unmatched instance **                                  XU13750/M5  MP(PCH)
       ** unmatched instance **                                  XU12567/M4  MP(PCH)
       ** unmatched instance **                                  XU12567/M5  MP(PCH)
       ** unmatched instance **                                  XU12514/M0  MN(NCH)
       ** unmatched instance **                                  XU12522/M0  MN(NCH)
       ** unmatched instance **                                  XU12521/M0  MN(NCH)
       ** unmatched instance **                                  XU12518/M0  MN(NCH)
       ** unmatched instance **                                  XU12516/M0  MN(NCH)
       ** unmatched instance **                                  Xdata_ad8_reg_102_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_103_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_104_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_105_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_106_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_107_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_108_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_109_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_110_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_111_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_112_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_113_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_114_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_115_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_116_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_117_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_118_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_119_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_120_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_121_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_122_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_123_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_124_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_125_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_126_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_127_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_128_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_129_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_130_/M19  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_130_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_133_/M19  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_133_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_135_/M19  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_135_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_136_/M19  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_136_/M25  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_137_/M19  MP(PCH)
       ** unmatched instance **                                  Xdata_ad8_reg_137_/M25  MP(PCH)
                                         SUMMARY
Total CPU Time:      6 sec
Total Elapsed Time:  6 sec
发表于 2017-6-22 07:49:33 | 显示全部楼层
看起来没有实质性的错误。
发表于 2017-6-22 11:33:05 | 显示全部楼层
看看ERC、softconnect、extraction results 里有没有线索
用hcell跑一次比较容易定位
 楼主| 发表于 2017-6-22 20:40:51 | 显示全部楼层
回复 2# Hyacinth1292
   这是个好消息,但是这个问题要怎么解决呢?求给个方向
发表于 2017-6-23 17:24:35 | 显示全部楼层
出gds前加filler了吗?
 楼主| 发表于 2017-6-23 17:57:25 | 显示全部楼层
回复 5# IC_laborer
insert_stdcell_filler -cell_without_metal "FEED1" -connect_to_power VDD -connect_to_ground VSS
insert_metal_filler  -bounding_box { {70.000 70.000} {2099.500 221.200} }  -out self  -routing_space 2 -width {m1 1.2 m2 1.2 m3 1.2 m4 1.2} -space {m1 1.2 m2 1.2 m3 1.2 m4 1.2} -min_length {m1 1 m2 1 m3 1 m4 1} -max_length {m1 500 m2 500 m3 500 m4 500} -space_to_route {m1 2 m2 2 m3 2 m4 2} -space_to_pg {m1 2 m2 2 m3 2 m4 2} -stagger {m1 m2 m3 m4} -to_metal 4
 楼主| 发表于 2017-6-23 17:58:55 | 显示全部楼层
回复 5# IC_laborer
   这样算是加filler了吧。我现在改网表,但是感觉是设置的问题,要不改的地方太多了。您好,可以私信联系吗
 楼主| 发表于 2017-6-26 15:22:31 | 显示全部楼层
大大们求指教
发表于 2017-6-26 22:25:20 | 显示全部楼层
输出的网表需要包含电源地,物理cell只要包含decap,其他不需要包含,网表生成的对吗?
 楼主| 发表于 2017-6-27 17:21:17 | 显示全部楼层
回复 9# 珠angel
微信截图_20170627172152.png 我在用v2lvs生成spice网表的时候定义了电源线,输出的如图所示,您看没有问题吗?我可以加您联系方式进一步咨询吗
GMT+8, 2025-12-15 02:05 , Processed in 0.036076 second(s), 4 queries , Gzip On, Redis On.
