查看: 11096|回复: 14
谁能制作UCAMX 1.7 64bit破解文件?
发表于 2017-5-21 10:16:02 | 显示全部楼层 |阅读模式
我有安装文件,破解后给我一份破解文件.
能破解的请与我联系.
 楼主| 发表于 2017-5-21 16:23:41 | 显示全部楼层
UcamX170413x64.part01.rar (15 MB , 下载次数: 53 ) UcamX170413x64.part02.rar (15 MB , 下载次数: 41 ) UcamX170413x64.part03.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part04.rar (15 MB , 下载次数: 35 ) UcamX170413x64.part05.rar (15 MB , 下载次数: 33 ) UcamX170413x64.part06.rar (15 MB , 下载次数: 33 ) UcamX170413x64.part07.rar (15 MB , 下载次数: 33 ) UcamX170413x64.part08.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part09.rar (15 MB , 下载次数: 35 ) UcamX170413x64.part10.rar (15 MB , 下载次数: 32 ) UcamX170413x64.part11.rar (15 MB , 下载次数: 34 ) UcamX170413x64.part12.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part13.rar (15 MB , 下载次数: 30 ) UcamX170413x64.part14.rar (15 MB , 下载次数: 34 ) UcamX170413x64.part15.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part16.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part17.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part18.rar (15 MB , 下载次数: 30 ) UcamX170413x64.part19.rar (15 MB , 下载次数: 31 ) UcamX170413x64.part20.rar (12.16 MB , 下载次数: 32 )
 楼主| 发表于 2017-5-22 14:00:22 | 显示全部楼层
New Ground Breaking CAM Software for Rigid, Flex and HDI PCB’s
Zero-Defect Tooling
UcamX captures not just layout data but also netlist information, customer specifications, mechanical drawings and manufacturing rules in a single smart engineering database. From the database launch automatic DRC and DFM checks without vendor limitations. Optimize plant yields using automated DFM routines. UcamX deploys powerful automatic security tools to detect accidental operator errors. For flexible circuitry see our Ucam uFlex brochure.
Integration into any environment
We provide our customers with all interfaces, upstream to CAD/DFM, downstream to manufacturing and quality control. UcamX outputs fully-automated machine-optimized tooling for all industry-standard electrical testers and AOI systems, photo plotters, drilling and routing equipment and direct imagers. Product parameters can easily be uploaded into corporate production management databases, or in various formats for other CAD/CAM systems.
VHS Editor
Parallel Processing
At the heart of UcamX are its newly designed 64 bit core engine and a smart new feature called Parallel Processing (PP). They are the key to the software’s astonishing performance. The 64 bit UCAMX core addresses more computer memory and allows high layer count jobs or massive data volumes to process without a hitch. In the Parallel Processing concept, highly efficient new algorithms split up CPU-intensive CAM tasks between various CPUs of a multicore workstation and complete within a fraction of the time standard CAM software packages would need. The more CPUs on the workstation, the faster the software.
Docked Dialog
Job Workspace
High-level automation without limits
UcamX Hypertool scripting delivers in-depth custom automation without limits. Unlike batch-sequencers, HyperTools give you access to full core CAM functionality. Simplify and accelerate your process automation. Write new CAM routines to automate your new technologies or to integrate CAM deeply into your business systems. The Java™ carrier means that HyperTools are structured, robust and reliable, fully integrated into the UcamX GUI.
Out-of-the-Box CAM Productivity
UcamX is delivered ready-automated with built-in dynamic functionality for a fast roll-out and a fully customized smart workflow. Labor-saving functions include automated board structuring, netlist and test-point generation without manual intervention,  & dynamic yield-driven auto-panelization. Working on one job and need to look at others? No need to close down: just use Load Balanced Sessions to open as many extra jobs as you need on your workstation.
UcamX Visual HyperScript (VHS) scripting delivers operator level automation without limits. Record repetitive tasks or write new CAM routines to automate your CAM flow or to integrate CAM deeply into your business systems. The VHS function library contains more than 1000 commands.
The VHS Editor (see picture) offers a complete programming and debugging environment to test created or recorded scripts. Scripts can be attached to custom toolbars and launch pads.
Positioning within Ucamco products
UcamX is Ucamco’s latest generation of CAM software for the Rigid, Flex and HDI PCB manufacturing industries. It takes advantage of modern day multicore and 64 bit workstation technology to set new standards in performance and throughput, and comes with a clever and highly intuitive new user interface that adapts itself functionality-wise as a job progresses through the CAM workflow.
New Intuitive User Interface
UcamX’ most eye-catching novelty is undoubtedly its new graphical user interface. It excels at comfort, ease-of-use and convenience and abounds with sparkling widgets and surprising can dos… We call it Workspace GUI. It lets you layout, store and reload different configurations of dialogues and toolbars, depending on which stage of the CAM process a job has reached. As it enters the next stage, just call up the workspace to go with it and Workspace GUI does the rest: it re-arranges itself to bring the required functionality within easy reach.: it re-arranges itself to bring all required functionality for the task at hand within easy reach: multiple rows of toolbars – side by side or stacked on top of each other, HYPERTOOL or VISUAL HYPERSCRIPT programs directly accessible from a toolbar icon, a slick “pin bar” where dialogues slide in to and out of, it is all there for you to discover and make the interaction with the program a real joy… UcamX comes with a set of pre-defined workspaces right out of the box so you can hit the ground running. And should something not be entirely the way your CAM department is used to going about things, all it takes is a couple of drag’n’drops to adapt an existing workspace to your exact needs or to create an entirely new one.
发表于 2017-5-23 21:15:42 | 显示全部楼层
这货用那些ecc patch没反应啊,而且没license,这才是最坑的
发表于 2017-5-27 10:26:39 | 显示全部楼层
可以讨论下使用经验
发表于 2017-5-27 10:30:05 | 显示全部楼层
楼主搞定了么?
发表于 2017-5-27 10:31:17 | 显示全部楼层
回复 1# zxdr5
现在用UCAM的人少了啊
发表于 2019-2-13 16:36:01 | 显示全部楼层
i want crack for this please
 楼主| 发表于 2019-2-13 19:54:24 | 显示全部楼层
发表于 2020-6-21 09:44:09 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-26 12:50 , Processed in 0.024266 second(s), 6 queries , Gzip On, Redis On.
