查看: 2180|回复: 6
[求助] Ubuntu中安装installer3.1失败 help !!!!!!!!
发表于 2017-3-30 11:11:54 | 显示全部楼层 |阅读模式
安装installer3.0:
1) ./setup.sh 失败,显示(bash:./setup.sh: /bin/csh:  坏的解释器:权限不够);
2)安装好了c-shell(apt-get install csh),用root登陆,chmod也试过了,还是显示和1)一样的错误;
3)尝试直接bash setup.sh 显示错误:(行 30: 语法错误:未预期的文件结尾)
 楼主| 发表于 2017-3-30 11:12:35 | 显示全部楼层
大神么教教新手呗,help ~~~~~~~~~~~~~~~~~~~~
 楼主| 发表于 2017-3-30 11:17:24 | 显示全部楼层
#! /bin/csh -f
if ( ! $?DISPLAY ) then
    echo ""
    echo "Note: The DISPLAY environment variable is not set."
    echo "      Set this variable to proceed with the graphical"
    echo "      installation."
    echo ""
    exit 1
endif
set cmdpath = "$0"
set cmd = "$cmdpath:t"
if ( "$cmd" == "$cmdpath" ) then
  set cddir = "."
else
  set cddir = "$cmdpath:h"
endif
set cddir_path = $cddir
if ( $cddir_path == "." ) then
  set cddir_path = `pwd`
endif
$cddir_path/installer -gui $argv
 楼主| 发表于 2017-3-30 11:18:25 | 显示全部楼层
三楼是贴出来的setup.sh的脚本内容,大神们帮我看看有什么错误
 楼主| 发表于 2017-3-30 14:58:00 | 显示全部楼层
别沉啊,亲
发表于 2017-3-31 18:34:48 | 显示全部楼层
good post brother!
 楼主| 发表于 2017-3-31 19:11:16 | 显示全部楼层
I had overcome the problem
GMT+8, 2025-12-25 00:49 , Processed in 0.016476 second(s), 4 queries , Gzip On, Redis On.
