查看: 1500|回复: 0
[求助] power strap did not connect to metal 1 in standard cell rows
发表于 2017-2-7 00:51:35 | 显示全部楼层 |阅读模式
in IC compiler:I did floorplanning, p/g ring, VSS and VDD, then
create_power_straps  -direction vertical -layer M4
then
preroute_standard_cells -route_pins_on_layer M1 -connect horizontal
but I later found that the straps to ring connections are perfect, but straps to M1 VDD/VSS connection was not
there, I did try M4, M6, and M8,
Please help
GMT+8, 2025-9-15 04:32 , Processed in 0.012293 second(s), 4 queries , Gzip On, Redis On.
