查看: 1853|回复: 0
[求助] ICC could not go beyond floorplanning
发表于 2016-12-22 03:23:39 | 显示全部楼层 |阅读模式
I went through the following in icc_shell1. libraries setup
2. import dc_shell generated gate level netlist
3. read in top level DEF
I could see that the area was defined, with pins at the border, and standard cells in the lower left corner of
the design area.
but every time I tried coarse placement, I got the following error message, I don't know how to tackle the problem
Please help,
icc_shell> create_placement
Information: linking reference library : /houston/users/sguo/gucdownload/TSMCHOME/digital/Back_End/milkyway/tcbn28hpmbwp35hvt_120a/frame_only_HVH_0d5_0/tcbn28hpmbwp35hvt. (PSYN-878)
Error: No valid link library specified, please check library setup. (PSYN-958)
Error: Could not read the following target libraries:
your_library.db
GMT+8, 2025-9-13 14:19 , Processed in 0.015255 second(s), 3 queries , Gzip On, Redis On.
