查看: 7245|回复: 6
可用的LICENSE为什么不能启动DC
发表于 2007-6-9 09:50:38 | 显示全部楼层 |阅读模式
[root@localhost ~]# design_vision
        Beginning 2003.03, design_vision command processing is now TCL by default.
        Type 'design_vision -dcsh_mode' to use the dcsh command language.
Unable to obtain feature 'Design-Vision ' because:
Error: This site is not licensed for 'Design-Vision'. (SEC-51)
Please contact root at [email=root@(none]root@(none[/email]), who is
your local Synopsys license administrator for Synopsys site 000.
Unable to obtain feature 'Design-Analyzer-DAP ' because:
Error: This site is not licensed for 'Design-Analyzer-DAP'. (SEC-51)
Unable to obtain feature 'Design-Analyzer ' because:
Error: Internal licensing error number -42: Invalid parameter
Feature:       Design-Analyzer
License path:  27000@localhost.localdomain
FLEXlm error:  -42,147
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".. (SEC-17)
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer-DAP, Design-Analyzer. (DCSH-10)
发表于 2007-6-9 14:59:56 | 显示全部楼层
好象还是你的LIC不是完全的
发表于 2007-12-16 12:42:34 | 显示全部楼层
发表于 2007-12-17 21:12:24 | 显示全部楼层
是你机子的hostid跟lic里的hostid不一致吧,要统一成lic里的hostid,
或者你的lic就是无效的,呵呵
如果lic确实有效的,需要修改机子的mac地址了
[ 本帖最后由 zenoone 于 2007-12-17 21:13 编辑 ]
发表于 2010-6-2 20:05:15 | 显示全部楼层
License path:  27000@localhost.localdomain中的
”localhost.localdomain“可以用任意名字代替吗?
谢谢~~
发表于 2012-4-11 14:41:36 | 显示全部楼层
回复 1# zhaopeng309
    我的打开design_vision的时候,可以出来界面,就是在终端显示
ERRor:you do not have licence key
求教
发表于 2016-9-30 12:06:59 | 显示全部楼层
回复 6# wsh086
    你的问题解决了吗?我也遇到了同样的问题
GMT+8, 2025-12-21 20:27 , Processed in 0.025119 second(s), 8 queries , Gzip On, Redis On.
