查看: 2736|回复: 1
[招聘] Synopsys 2016 实习生招聘 火热持续中!!!
发表于 2016-7-13 14:31:43 | 显示全部楼层 |阅读模式
如果你是2017届或2018届毕业生,
如果你想为自己赢得一份有价值的实习经历,
如果你想接触EDA行业最前沿的技术,
那就赶快加入Synopsys 2016 实习项目!
申请方式:
将中英文简历以“姓名_学校_专业_期望实习地点_岗位名称_可以实习的时间”的格式投递到邮箱zhuqin.tang@synopsys.com
职位介绍:
职位1Synopsys软件研发实习生(VCS, C++ programming)
实习地点:上海
实习时间:9个月
Job description:
build a stand-alone virtual filesystem and deploy it to a tool to replace current file system.
Requirement:
1. Master/Ph.D student with CSbackground
2. is proficient inC/C++ programing
3. full time with 4working days per week at least.
职位2Synopsys软件研发实习生(SPICE circuit simulation, C/C++
实习地点:上海
实习时间:6个月
Jobdescription:
• Based on the conducted physical effects studies and manufacturingprocesses, jointly develop compact model(s) for novel devices (tunneling FET,Nanowire, PCM memory, and novel NAND Flash memory cells, etcs) for efficientand effective SPICE simulation.
Requirement:
• Senior level of graduate student in Microelectronics or EE, withmajor or research topic(s) on or related to advanced semiconductor devices,novel memory.
• Has knowledge on C/C++, VerilogA, SPICE circuit simulation
职位3Synopsys 软件研发实习生(C/C++, Compiler, Makefile
实习地点:上海
实习时间:6个月
As a Software Engineer, you will take part indeveloping a generic profile tool which is widely used in Synopsys's products(VCS, VERDI, ZEBU ...).
This profile tool is very powerful, it givesaccurate CPU time/memory report in a fancy GUI using only one command andwithout much overhead.
During this intern project, you will get theopportunities to learn the core technology of it, and make it better.
The successful candidate will possess thefollowing combination of education and experience:
• Master/Phd Student in CS/EE.
• Strong C/C++ programming skills.
• Excellent written and oral communication skills are expected.
• Experience with software development on UNIX/Linux platform.
• Knowledge of parallel programing is a plus.
• Knowledge of compiler (GCC/Clang) and Makefile is plus.
职位4Synopsys 软件研发实习生(multi-threading)
实习地点:上海
实习时间:3个月
The candidate will be designing threadinginfrastructures for the product, and focus on runtime performanceprofile/tuning.
The candidate should have:
a) Good knowledge of multi-threading.
b) Strong problem solving skills.
c) Good programming skills and self-motivated.
职位5Synopsys 软件研发实习生(ICV,C/C++)
地点:上海
实习时间:3个月
JobDescription
The project is to research graph isomorpsimoptimation for ICV UNBOUNDED pattern match.
The project will be divided into 3 stages.
The first is to set up the performance benchmarkcases and collect the intial data
The second is to study the boost graph isomorpsimfunction and propose 3-5 enhancement s
The third is to implement 1-2 performanceenhancement in ICV PM and evluate the improvement
Job Requirement
Familiar with Linux/Unix system
Experience in Programming is required
Experience in C/C++ Programming is a plus
Experience in Graph Theory is a plus
Good communication skills in both Chinese andEnglish
职位6Synopsys PV Intern (Hercules/IC Validator)
实习地点:上海
实习时间:3个月
This person will work within the quality assurancegroup for the Hercules/IC Validator Physical Verification (PV) product line. Heor she will build a new automation testing flow to test LVS blackbox
Requirements:
-Familiar Unix/Linux environment
-Perl programming capability
-High motivation to learn new skills and exploredifferent technologies
-CS background
职位7Synopsys Product Validation (Python, PRS)
实习地点:上海
实习时间:3个月
Write tests on PRS configparser. (Python, PRS)
Write Python programs to usePRS config parser to build PRS config files from input flow switches. (Python,PRS)
Write Python programs to do PRSrun data cleanup, culprit finder, PRS-to-STAR script generator. (Python, Tcl)
Enhance PRS flow submissionscripts to do 24x7 branch disk selection automatically. (Python or Perl)
Build webpages to demonstrateQoR result. (HTML, JavaScript)
职位8Synopsys ARC软件研发实习生(Java/HTML/CSS/Git/Shell)
实习地点:武汉
实习时间:3个月
Job Description:
This person will work with embARC team from SG ARCgroup to implement web or mobile application for IoT demo. He or she will needto write application development plan to meet the requirement  of  theIoT demo, he or she will be responsible for developing and testing the web or mobileapplication. This project will provide an easy to use, out-of-box, Web/mobileapplication to users. User can interact the IoT device easily through theweb/mobile application.
a)  Basic skills: JavaScript/HTML/CSS/Git/Shell,  experience on Android and web applicationdevelopment is strongly needed
b)  Goodknowledge of network, IoT application and IoT Protocols.
c)  Strong problem solving skills, and teamwork
d)  Goodprogramming skills and self-motivated
e)   GoodEnglish communication and writing skills
职位9Synopsys 模拟电路实习生ESD
实习地点:武汉
实习时间:3个月
Job description:
1. Learn the knowledge of ESD structure and Presentto MISP Wuhan team.
2. Learn the snapback feature of ggnmos and build asample model by Verilog-A.
3.  Learnpower-clamp structure, and give a proposal of power-clamp.
Requirement:
1)      Havethe experience with ESD protection structure.
2)      Havea good knowledge of ESD physical mechanism.
3)     Master Hspice or other simulation tools.
4)     Familiar with CMOS process.
职位10Synopsys 财务部实习生
实习地点:北京
实习时间:6个月及以上
工作职责:
进行财务凭证整理、装订;
辅助会计做其他相关工作;
职位要求:
财务、经济及相关专业本科在读学生;
工作细致、耐心有责任感;
熟悉Excel和其他Office软件的基础操作
良好的书面英语能力
乐于沟通
诚实可靠、专注力高、对工作富有热情
可以保证一周出勤2-3天。
Synopsys公司是为全球集成电路设计提供电子设计自动化(EDA)软件工具的企业,作为电子设计自动化(EDA)和半导体知识产权(IP)领域内的领导者,公司的各类产品和服务加速了全球电子市场的创新。近年来,Synopsys先后收购了世界领先的软件开发测试验证工具厂商Coverity与主动性安全解决方案供应商Codenomicon等一系列公司,将公司的领先技术进一步拓宽到了软件质量与安全等领域。
  公司总部位于美国加州硅谷,并且在北美、欧洲、日本、亚洲和印度设有约90个办公室。自1995年进入中国以来,Synopsys在北京、上海、深圳、厦门和武汉等地成立研发中心,建立了完善的支持服务体系和世界级的先进技术研发机构。
发表于 2016-7-22 18:34:18 | 显示全部楼层
我来看看的
GMT+8, 2025-12-25 10:59 , Processed in 0.013820 second(s), 4 queries , Gzip On, Redis On.
