查看: 19402|回复: 59
[资料] Design of Analog Circuits through Symbolic Analysis
发表于 2016-5-30 12:18:22 | 显示全部楼层 |阅读模式
Symbolic analysis techniques offer a complementary way to analyze analog
integrated circuits. Since the results of symbolic analysis are analytic equations that
explicitly describe the functionality (e.g. transfer function, impedance, pole/zero...) of
the circuit as a symbolic expression of the design variables, it lends itself more for
designers to gain insight into the behavior of the circuit. Questions like “how does the
circuit actually work?”, “at what node is the dominant pole located?”, “what is the
relation between the bias current and the gain-bandwidth?”, “what is the impact of
device mismatch on the PSRR of this circuit”, “which transistor(s) actually is the
dominant noise source?”, “which nonlinearity is creating the most third-order
distortion?” etc. can be answered by means of symbolic analysis. Originally
hampered by the exponential complexity of the symbolic analysis problem,
approximation techniques that typically exploit designer intent or common design
practice had to be developed to make the results interpretable for humans. Symbolic
expressions are however also useful in many other applications that require the
repeated evaluation of circuit characteristics for a wide range of parameter values,
such as for example encountered in circuit optimization or in yield analysis. Not
requiring interpretation by humans, a wide range of efficient algorithmic techniques
iv
has been developed in the past years to overcome the complexity issue and to make
symbolic analysis tractable for circuits of practical size.
1608050955.part1.rar (14 MB , 下载次数: 803 )
1608050955.part2.rar (1.69 MB , 下载次数: 450 )
发表于 2016-5-30 19:42:28 | 显示全部楼层
kankan
发表于 2016-5-30 19:49:01 | 显示全部楼层
Thanks a lot
发表于 2016-5-31 08:36:29 | 显示全部楼层
下载看看!
发表于 2016-5-31 08:48:38 | 显示全部楼层
好书,下载看看
发表于 2016-5-31 10:43:01 | 显示全部楼层
文字版,质量很高。
从简介看,是介绍一种电路分析方法。
多谢分享。
发表于 2016-5-31 12:08:19 | 显示全部楼层
感謝樓主的分享
发表于 2016-5-31 20:05:41 | 显示全部楼层
看看,谢谢。。。
发表于 2016-6-1 08:56:57 | 显示全部楼层
回复 1# spwedasd
   谢谢分享
发表于 2016-6-4 12:06:50 | 显示全部楼层
THANK YOU
GMT+8, 2025-12-29 17:25 , Processed in 0.023204 second(s), 7 queries , Gzip On, Redis On.
