查看: 3241|回复: 5
[原创] 此处电容是否可以省掉
发表于 2016-4-21 11:05:17 | 显示全部楼层 |阅读模式
bandgap
bandgap
请教高手,从理论上看这个电容可以去掉,为啥要加上这个电容,从上电环路上分析分析零极点没有意思,因为开环增益<1.望高手解答疑惑!
发表于 2016-4-21 11:11:07 | 显示全部楼层
1.>This is Decoupling Capacitor, the Purpose is to make OP of the PSRR Better.
2.> you can simulate the OP PSRR, with this Decoupling Capacitor , the PSRR better.
3.> Generally, Always at Decoupling Capacitor at "BIAS node"
 楼主| 发表于 2016-4-21 11:23:22 | 显示全部楼层
回复 2# billlin
您好,我刚刚做了一个仿真,条件为是否加上上图中的电容,发现没有这个电容PSRR和加上电容PSRR 结果一样,请看下面仿真结果图
PSRR 仿真结果图
PSRR 仿真结果图
发表于 2016-4-21 11:31:10 | 显示全部楼层
You can try Power(AVDD) has a Step Response
AVDD+200mV --> AVDD-200mV --> AVDD+200mV to see if has different ?
 楼主| 发表于 2016-4-21 13:23:09 | 显示全部楼层
回复 4# billlin
仿真的时候对VDD加的是1V step response,加200mV step Response ,PSRR在是否有电容的情况下还是一样。
发表于 2016-4-21 13:53:13 | 显示全部楼层
the AVDD decoupling Capacitor should be workable if the AVDD has a step response Noise.
If the capacitor value too small ?
generally,
the capacitor value need greater than 1pF .
GMT+8, 2025-12-30 00:16 , Processed in 0.022866 second(s), 7 queries , Gzip On, Redis On.
