查看: 6227|回复: 9
[求助] 有人能给我解释一下这段fft的verilog代码的问题吗
发表于 2016-4-11 13:24:52 | 显示全部楼层 |阅读模式
//移位处理单元模块
module shift_process(clk,rst,shift_in_valid,shift_ctrl,up_in_real,up_in_image,
                     dn_in_real,dn_in_image,
                                                        shift_out_valid,up_out_real,up_out_image,dn_out_real,
                                                        dn_out_image);
input clk,rst,shift_in_valid,shift_out_valid;
input shift_ctrl[1:0],
      up_in_real[11:0],up_in_image[11:0], dn_in_real[11:0],  dn_in_image[11:0];
                //分别是上一级和下一级RAM中的复数的实部和虚部输入
output up_out_real[9:0],up_out_image[9:0],dn_out_real[9:0],        dn_out_image[9:0];
       //分别是进行移位操作后的复数的实部和虚部输出
endmodule
Error (10773): Verilog HDL error at shift_process.v(10): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
Error (10773): Verilog HDL error at shift_process.v(11): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
Error (10773): Verilog HDL error at shift_process.v(13): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
 楼主| 发表于 2016-4-11 13:26:19 | 显示全部楼层
手动顶
发表于 2016-4-11 13:59:14 | 显示全部楼层
Yeah, you must know what packed arrays and unpacked arrays are. Packed arrays are something like this: input [1:0]shift_ctrl; while unpacked arrays are something like this: input shift_ctrl[1:0]. The difference is that when you index some bit like shift_ctrl[0], if you define shift_ctrl as a packed array, then shift_ctrl[0] is just a bit. However, if you define shift_ctrl as an unpacked array, then shift_ctrl[0] is just an int type which takes 4-8 bytes depending on your machine. So maybe in this case, you should use packed arrays.
 楼主| 发表于 2016-4-11 14:45:44 | 显示全部楼层
回复 3# 411123879
    谢谢,但还是会报错Error (10170): Verilog HDL syntax error at shift_process.v(11) near text "[";  expecting an identifier
 楼主| 发表于 2016-4-11 14:48:17 | 显示全部楼层
回复 3# 411123879
 楼主| 发表于 2016-4-11 14:49:04 | 显示全部楼层
回复 3# 411123879
改完之后报
Error (10170): Verilog HDL syntax error at shift_process.v(13) near text "[";  expecting an identifier
Error (10112): Ignored design unit "shift_process" at shift_process.v(4) due to previous errors
发表于 2016-4-11 15:22:15 | 显示全部楼层
                                                         dn_out_image);
input [11:0]up_in_real;
output [9:0]up_out_image;
output [9:0]dn_out_real;
output [9:0]dn_out_image;
endmodule
Try this.
发表于 2016-4-11 15:25:33 | 显示全部楼层
Or you could move input output identifiers into your module I/O list like this:
module arbiter(
    input clk,
    input req0,
    input req1,
    input rst,
    ouput gnt0,
    output gnt1
发表于 2016-4-12 16:56:44 | 显示全部楼层
input shift_ctrl[1:0] :
改为input 【1:0】 shift_ctrl;
发表于 2016-4-12 16:58:50 | 显示全部楼层
verilog 可综合的代码没有数组,只有数据位宽,在input 和端口名中间,并且其他的reg和wire型数据类型也类似,希望对你有帮助。
GMT+8, 2025-12-25 10:09 , Processed in 0.030790 second(s), 8 queries , Gzip On, Redis On.
